djones(at)northboone.net Guest
Posted: Wed Sep 13, 2006 9:21 am Post subject: Radio shields |
I’m wiring the harness for a Terra TX-760D radio. My question is the interconnect diagram shows the shield for the mic. audio, mic. key and the headphone attach to the ground. I plan on using the daisy chain system shown by Bob, however I’m confused about the shields connecting into the ground wire itself or do they connect to the shield of the ground wire?
Dennis
brian-av(at)lloyd.com Guest
Posted: Wed Sep 13, 2006 1:16 pm Post subject: Radio shields |
rOn Wed, 2006-09-13 at 10:12, Dennis Jones wrote:
Quote: | I?m wiring the harness for a Terra TX-760D radio. My question is the
system shown by Bob, however I?m confused about the shields connecting
ground wire?
If the radio itself has separate sheild and ground connections (most
don't) then you would connect the shield and ground to their respective
connections. Most radios just have a ground connection so both the
shield and the ground wire (if they are separate) should connect to the
ground pin(s) at the radio.
Normally I would run separate wire for mic/ptt and headphone. Speaking
specifically of the mic/ptt wiring, you can use the shield of the mic
cable as your mic and ptt ground wiring if you wish. If your mic wiring
has three conductors plus shield, I would probably use one conductor for
ground and then not attach anything to the shield (except at the radio).
If you are using an intercom you will probably have separate mic/ptt
wiring for each mic jack. (Most intercoms provide mic isolation when you
hit the PTT for one mic, the other mics are muted to keep noise from
getting into the transmit audio.)
If you are not using an intercom then you may daisy-chain your mic and
PTT connections. Just continue ground, shield, PTT, and mic hot.
Whatever you choose to do be sure you insulate the mic jacks from the
airframe.
Headphone wiring does not need to be shielded. I would use twisted pair.
You can get away with using airframe ground for the ground side of your
headphone but you are more likely to get some noise pick-up. This may
become objectionable if you are trying to have high-fidelity audio. Best
to insulate the headphone jacks as well.
Brian Lloyd
nuckollsr(at)cox.net Guest
Posted: Wed Sep 13, 2006 3:22 pm Post subject: Radio shields |
At 12:12 PM 9/13/2006 -0500, you wrote:
Quote: | I m wiring the harness for a Terra TX-760D radio. My question is the
shown by Bob, however I m confused about the shields connecting into the
Can you scan the wiring from the instruction manual
and send it to me?
It would be useful to see how they've depicted their
suggestions for the installation.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Sep 14, 2006 10:48 am Post subject: Radio shields |
At 06:21 PM 9/13/2006 -0500, you wrote:
Quote: |
<nuckollsr(at)cox.net>
>system shown by Bob, however I m confused about the shields connecting
>ground wire?
and send it to me?
Okay, got the scans. Great.
I guess I'm not sure what the question is. The schematic shows
two aircraft ground (A/C Ground) connections to pins 4 and 15.
Wires that the manufacturer recommends be shielded have their
shield grounds returned to specific pins. They also show how
the shield can double as a ground return for mic, headphone,
speaker leads, etc. Further, their wiring suggests exactly
the same daisy-chaining technique I described in:
http://aeroelectric.com/articles/pigtail/pigtail.html
OOPS! I just re-read your question and I think missed
something the first time. You talk about a "shield of
the ground wire".
The drawings show single strands of wire from pins 4 and
15 to ground. Your pigtails would either solder onto the
shared solder cups or splice into the ground wires immediately
adjacent to where they drop into the crimped on pin pocket.
The ground wires are not shielded.
Posted: Thu Sep 14, 2006 1:15 pm Post subject: Radio shields |
Thanks Bob
If one solders the wire to the cup, would the pig tail solder literally
onto the
side of the cup or in the cup and would you join the wires first? If I splice
the wires using the pin pocket what would be the best way to splice the wires
together prior to installing into the pocket, i.e. wrapped, soldered?
Dennis
Quoting "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>:
>> daisy chain system shown by Bob, however I m confused about the
> and send it to me?
the ground wire".
Posted: Thu Sep 14, 2006 1:27 pm Post subject: Radio shields |
Bob
When you speak of the "shield grounds return to specific pins" are you talking
about pins 4 and 15? The shield doubling as a ground return are you
refering to
the shield attaching to the mic and headphone jack lugs?
Dennis
> and send it to me?
the ground wire".
Posted: Thu Sep 14, 2006 2:57 pm Post subject: Radio shields |
At 04:26 PM 9/14/2006 -0500, you wrote:
Quote: |
Bob
Yes . . . the schematic clearly shows that both shield grounds -and-
power grounds to airframe connect to pins 15 and 4.
Quote: | The shield doubling as a ground return are you refering to
Yes . . . the outer shield braid doubles as electrostatic
shield -AND- signal ground for the remote components.
This is a common technique. I use it several places in
the wiring diagrams shown in.
http://www.aeroelectric.com/Catalog/AEC/9009/9009-700J.pdf
Posted: Thu Sep 14, 2006 3:00 pm Post subject: Radio shields |
At 04:14 PM 9/14/2006 -0500, you wrote:
Quote: |
Thanks Bob
onto the
The cups are obviously too small to accept a pair of wires.
I usually tack solder the shield pigtails to the side of the
cup after the main wire is installed inside the cup.
For crimped pins, I'd probably include the airframe ground wires
into the inner-most cluster of the daisy chain so that shields
and ground wire all come together at the end of the shielded wire.
Then, the pigtail for the shields can do double duty and crimp
into the d-sub pin.
Posted: Thu Sep 14, 2006 5:52 pm Post subject: Radio shields |
For crimped pins with the ground wires as the inermost wouldn't the
pigtail and
ground wire ends come together and then crimp into the d-sub pin.
Dennis
> Thanks Bob
> literally onto the
> I splice
> the wires
into the d-sub pin.
Posted: Fri Sep 15, 2006 2:16 am Post subject: Radio shields |
At 08:51 PM 9/14/2006 -0500, you wrote:
pigtail and
Dennis
Shielded ground wires? Don't know why anyone would do that.
Grounded wires are, by definition, immune to the effects
of electrostatic noise coupling.
Two classes of wiring benefit from the addition of shielding
(which is grounded at least at one end).
(1) wires that carry strong potentially antagonistic
signals (high voltage, fast risetime waveforms).
Magneto p-leads are always worth shielding unless
you're building a day vfr machine with no radios.
(2) wires that carry small, potentially victim signals
(low voltages that carry intelligence in the form
of voice, data or display signals). These will be
circuits like microphones and small signal lines
between various black boxes of a system.
Wires that are used for grounding do no fall into
either of these categories.
Posted: Fri Sep 15, 2006 9:25 am Post subject: Radio shields |
Bob
I was refering to the schematic for the Terra radios where the phone and mic
jack shielded wires come into the radio and the shield of those wires are tied
into the ground wire going into the radio using the daisy chain system and the
pig tail attaches to the ground.
Dennis
> pigtail and
> Dennis
