rondefly(at)rtriano.com Guest
Posted: Mon Jan 23, 2006 7:42 am Post subject: OV Module |
Hi, Could someone please point me in the right direction on the parts needed
for the OV Module, My question is on the Potentiometer R2, the parts list
calls it out as
3292W501, DigiKey has no such number. I am not electronically qualified to
guess at what it is.
Ron Triano
http://bld01.ipowerweb.com/contentmanagement/websites/rtrianoc/page10.html
nuckollsr(at)cox.net Guest
Posted: Mon Jan 23, 2006 9:07 am Post subject: OV Module |
calls it out as
I'm glad you posted this note. The search phrase to find it in Digikey
is 3192W-501. I'm pleased that this error was called to my attention
because it highlights another more serious error on my part. The 3292 series
pots are unnecessarily expensive (15.00/ea!) for this task. I'm going to
change the call-out to a 3296W-501 for $2.70 each in single lots.
Appreciate the heads-up on this!
Posted: Mon Jan 23, 2006 9:19 am Post subject: OV Module |
At 11:07 AM 1/23/2006 -0600, you wrote:
Quote: |
<nuckollsr(at)cox.net>
>calls it out as
series
The drawing has been fixed and Rev D posted at:
http://aeroelectric.com/articles/Crowbar_OV_Protection/Crowbar_D.pdf
Posted: Thu Jan 26, 2006 6:48 am Post subject: OV Module |
I could not get the listed resistors at Digikey and went to Frys, was not
able to get the 1% but was able to get some 2% and 5 %, also on the
BC1.62KZCT could only get a 1.6. I am having problems getting up to the
voltage stated in the troubleshooting area. Is it the tolerance of the
resistors or that 1.62 one maybe? I have checked all my solder joints and
went completely through the troubleshooting guide Bob has with the parts
list. Any help is appreciated.
Ron Triano
Posted: Thu Jan 26, 2006 11:09 am Post subject: OV Module |
Seems Digikey has shuffled the deck again on catalog numbers.
The recommended parts list has been updated to reflect current
offerings at:
http://aeroelectric.com/articles/Crowbar_OV_Protection/Crowbar_E.pdf
It's not possible to troubleshoot your project without seeing
it. If you'll mail it to me with some cash for return postage,
I'll look it over.
6936 Bainbridge Road
Wichita, KS 67226-1008
Posted: Sat Jan 28, 2006 4:54 pm Post subject: OV Module |
Thanks Bob, for the generous offer to look over my OV module. I checked over
everything one more time and saw I forgot to add the 392 resistor, that was
another one I could not locate. I was able to get a 360 Ohm one and tried
it. Now I can get to the 1870 ohms with R2 turned up, and I am around 57
something on the ground side. Did not go any further with the test. Do you
think I can get to the listed ohms if I find a 392 ohm resistor?
Ron Triano
klehman(at)albedo.net Guest
Posted: Sun Jan 29, 2006 5:50 am Post subject: OV Module |
Ron
Digi-key will have numerous resistors that will do the job under various
part numbers. 2% and 5% resistors will change value more with
temperature changes but I doubt that will cause any problem for you.
Exact resistance values are not necessary. The resistors form a voltage
divider. The voltage will be the same ratio as the resistance that you
use if you wish to do the math. Or just assemble what you have and
measure the voltage. As long as you can adjust the trip voltage to the
correct value you should be fine. If it won't adjust to the correct
value then you should only have to change one resistor.
Ken
>Ron Triano
Posted: Wed Feb 01, 2006 11:16 am Post subject: OV Module |
Hi Bob
Below I believe the link below should be to rev E at:
http://www.aeroelectric.com/articles/Crowbar_OV_Protection//Crowbar_E.pdf
On page one I see you've revised R5 to 6.04K probably to reduce the
number of different parts. However on page 3 it is still shown as the
old 10K value.
On page 4, paragraph 2 refers to the 12 volt reference measured at (C).
However the diagram on page 3 now shows TWO C points and it shows them
as the revised added capacitors. It might be less confusing to designate
the capacitors in some other way and put point C back as designating the
reference voltage point.
thanks again
Ken
>>calls it out as
>series
Posted: Thu Feb 02, 2006 6:12 am Post subject: OV Module |
At 04:27 PM 1/31/2006 -0500, you wrote:
Correct.
Quote: | On page 4, paragraph 2 refers to the 12 volt reference measured at (C).
Agreed. The "A", "B", and "C" with arrows are keyed with the
text as test points while smaller, standalone bubbles are
revision flags. The neophyte observer could easily mix the
two. I think I'll change "A", "B" and "C" test points to
numbered values.
I've had quite a bit of feedback from individuals who
had various start up problems with this project . . most
had to do with packaging. I'm thinking about offering an
etched circuit board that uses thru-hole parts and
gets the critter down to a 1.25" square board that will
fit into the same package as
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1.pdf
I just ordered a couple hundred potting shells for this
and other projects. I could offer a kit of board and
potting shell which would fix the packaging issues and
improve on probability of having it work right the first
time.
Thanks!
Posted: Fri Feb 03, 2006 9:05 am Post subject: OV Module |
Thanks for the help guys. I started to check and found closer resistors to
the ones called out and changed the ones per Bobs latest revision. The
module works as it should and cuts the power at 16V.
Ron Triano
