kkinney
Posted: Sat Sep 09, 2006 7:18 am Post subject: Fuel Pump Switch(es) |
I'm planning a left/right fuel system each with an on/off valve and an aux pump on each incoming line.
I'm thinking of using an on/off/on switch for pumps rather than an on/off switch for each pump.
Can anyone offer any thoughts on the downside of this?
Kevin Kinney
Non-parent - I don't see how you can raise children & stay sane.
Parent - You don't. You pick one and go with it.
Bob McC
Posted: Sat Sep 09, 2006 12:40 pm Post subject: Fuel Pump Switch(es) |
Kevin;
One downside is "single point of failure". If the switch fails you loose
both pumps. Also, if one pump fails and blows the fuse you loose both pumps.
Two switches allows two fuses, two circuits, redundancy.
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
frank.hinde(at)hp.com Guest
Posted: Sat Sep 09, 2006 5:43 pm Post subject: Fuel Pump Switch(es) |
Sure!.. if the single point of failure (namely the
switch)...er...fails...You crash!
If you are dependant on those electric pumps (like I am) always wire
them seperatly all the way back to the battery...If you have two
batteries make sure they are isolated and feed one pump from each
battery.
Frank RV7a, IO360 electic pump in each wing root. No mechanical pump,
single Odyssey and dual alternator.
Flying as of yesterday.
FLYaDIVE(at)aol.com Guest
Posted: Sun Sep 10, 2006 3:42 am Post subject: Fuel Pump Switch(es) |
In a message dated 9/9/06 11:21:44 AM Eastern Daylight Time, kkinney(at)fuse.net
writes:
Kevin Kinney
WHY!
Kevin:
There are thousands of planes out there with a ONE PUMP boost system running
off on the one common line going to the engine or from the fuel selector.
What I would do though is put a fuel filter on each tank. And then if you want
to go crazy put in a parallel boost pump. That will give you redundancy and of
course more weight and maintenance.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Sun Sep 10, 2006 6:00 am Post subject: Fuel Pump Switch(es) |
Hi Kevin-
| Quote: | I'm planning a left/right fuel system each with an on/off valve and an aux
pump
| Quote: | on each incoming line.
switch
| Quote: | Can anyone offer any thoughts on the downside of this?
Yup, there are a few. Other folks have touched on most of them already.
The fusing issue could be handled by either putting the FP fuses downstream
of a SPDT center off switch with a larger fuse at the bus (for a total of
3), or by using a DPDT center off switch and two feeds from 2 fuses at the
bus(ses). The former arrangement would have the single feed wire, the
connectors at each end, the big fuse at the bus, and the switch itself as
'single point of failure' nodes. The latter arrangement would reduce the
single point of failure nodes to just the switch itself, rather than all
the other stuff . The most bullet proof system would indeed involve
separate switches for the individual pumps, which would ideally be fed by
separate busses. On balance, having one fuse, one feed wire, and one
switch controlling two pumps leaves you with no less redundancy than my
single pump system, and actually has a smidge more. Unless, of course,
your pumps are inherently less reliable than mine. I have no info on that,
tho-
Having typed this all out, and considering that the electric fuel pumps are
already a back up for the mechanical pump, I'd personally stick with the
single electric pump solution. Especially if one only had one bus to draw
power from. If you are committed to two pumps, I'd probably be perfectly
happy with the single switch, three fuse arrangement. Two electric fuel
pumps gets into the 'belts and suspenders' zone, and complete independent
power systems seems to get into the 'belt, suspenders, and duct tape' zone.
As ever, this is worth precisely what you've paid for it-
glen matejcek
aerobubba(at)earthlink.net
brian-av(at)lloyd.com Guest
Posted: Sun Sep 10, 2006 9:59 am Post subject: Fuel Pump Switch(es) |
On Sun, 2006-09-10 at 04:41, FLYaDIVE(at)aol.com wrote:
| Quote: | > I'm planning a left/right fuel system each with an on/off valve and an aux
Kevin, I think your approach is just fine. Yes, the switch is a
single-point-of-failure but it shouldn't cause your engine to stop
running as the engine-driven fuel pump should be able to keep the engine
running. To lose the engine you would have to lose the both halves of
the switch, both electric fuel pumps, and the engine driven fuel pump.
| Quote: | There are thousands of planes out there with a ONE PUMP boost system running
Barry, I think Kevin's idea of two pumps, each right at the tank, is a
good one. That approach means that your boost pump is never having to
suck against a fuel line thus reducing the chance for vapor lock to
almost zero. (I have experienced a vapor lock in flight on the
engine-driven fuel pump. It gets your attention.) If he is thinking of
running mogas, this might be a very good idea. Most automotive systems
now immerse the fuel pump right in the fuel. This ensures that the pump
has prime and that there is no chance for vapor lock.
Brian Lloyd
George McNutt
Posted: Sun Sep 10, 2006 1:19 pm Post subject: Fuel Pump Switch(es) |
Kevin, aside from the on/off switch debate, an on/off valve on each
tank introduces problems and complexity into emergency procedures for a
fuel delivery interruption. For example if you had a blockage or
inadvertently ran a tank dry you will have to reposition two fuel
valves, presumably on opposite sides of the cockpit.
Also check valves may be required to prevent fuel transfer if both tank
valves were inadvertently left open?
George in Langley BC
Kevin Kinney wrote:
Kevin Kinney
Posted: Sun Sep 10, 2006 6:38 pm Post subject: Fuel Pump Switch(es) |
I have an electric pump in each wing root and NO mechanical pump...I
assumed this system was the same but if it has a mechanical pump then
sure a single switch would be just fine.
Frank
Posted: Sun Sep 10, 2006 8:24 pm Post subject: Fuel Pump Switch(es) |
On Sep 10, 2006, at 7:39 PM, Hinde, Frank George (Corvallis) wrote:
(Corvallis)" <frank.hinde(at)hp.com>
On my electric only system I simply switch pumps to switch tanks...No
selector valve...Just a non return valve in each line joining to a tee
then up to the standards vans selector that has been plumbed to act as
an on-off valve.
My only concern with that would be that a pump failure could render
1/2 your fuel unavailable. Several aircraft have been lost on long
over-water flights when electric transfer pumps have failed thus
rendering necessary fuel unavailable. Something to think about.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Posted: Mon Sep 11, 2006 12:23 am Post subject: Fuel Pump Switch(es) |
Hi all,
| Quote: | >
> an on-off valve.
I had to design a fuel circuit for an electrically dependant engine :
in order to achieve true redundancy I had to run each pump from a
separate battery. The main pump runs from the main battery, and is on
whenever the mags are "on". The boost pump runs from the auxiliary
battery, and has a switch. The fuel valve works the normal way. For the
pilot, everything works as in a engine with mechanical pump.
No single electric failure can deprive the engine of its fuel supply.
A schematic of my setup can be seen at
http://contrails.free.fr/engine_pierburg.php
(Scroll down to the bottom of the page)
FWIW
Gilles Thesee
Grenoble, France
Posted: Mon Sep 11, 2006 6:45 am Post subject: Fuel Pump Switch(es) |
George / Kevin-
George- "... an on/off valve on each
tank introduces problems and complexity..."
Boy, am I glad you wrote that! I completely missed the part about
independent fuel valves. Kevin, besides all the good points George makes,
and as someone pointed out a while back on one of these lists, you will
only find a "BOTH" position on a fuel selector in a high wing single engine
airplane. The low wing planes have left, right, and off. With a high wing
plane, you will sometimes see quite an imbalance develop when drawing fuel
from both tanks simultaneously, even with the head pressure caused by the
tank location. This effect could be much greater in a low wing
installation. If you had the ability to have both tanks plumbed to the
engine at the same time, when one tank emptied you could suck air into the
system. Obviously, this would not be good. I would definitely recommend
against two fuel valves.
Sorry for not catching that sooner-
glen matejcek
oldbob(at)BeechOwners.com Guest
Posted: Mon Sep 11, 2006 7:27 am Post subject: Fuel Pump Switch(es) |
Good Morning Frank,
I've been away for a few days and am just catching up
on my E-mail so I have not yet digested this thread.
However, the following statement piques my curiosity.
"Basically you have to allow a small reserve in each
tank, For normal flying that means 0.5 hours
in each tank...For out in the badlands that might be a
bit more... "
Would you mean by this statement that you do not want
to run a tank dry or that you feel it is actually
dangerous to do so?
May I ask what sort of an engine is being fed and why
you feel the need for it to never be allowed to run
dry?
Many light aircraft, both certified and experimental,
have multiple fuel tanks. Some Bonanzas have six
separate fuel tanks. If a half hours worth of fuel is
to be considered unusable in each tank, a lot of
payload and range is being lost.
The vast majority of commonly used light plane engines
are driving a solidly connected propellor that will
windmill quite well following a loss of fuel flow. I
understand that some of the experimental airplanes do
have propellors that will declutch or otherwise not
drive the engine if power is lost, but that is not
true of most.
Running a fuel tank dry is a very viable fuel
management operation if it is done correctly.
Any more information or thoughts you would care to
mention?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Stearman N3977A
Downers Grove, IL
LL22
--- "Hinde, Frank George (Corvallis)"
<frank.hinde(at)hp.com> wrote:
Frank George (Corvallis)" <frank.hinde(at)hp.com>
Absolutely correct Brian,
That is the one downside I came up with too.
tank, For normal flying that means 0.5 hours in each
tank...For out in the badlands that might be a bit
more...
Frank
Posted: Mon Sep 11, 2006 7:30 am Post subject: Fuel Pump Switch(es) |
Well that depends.
On a carbed engine it does not matter if you run a tank dry with Both
tanks feeding the engine.
The pump that draws air will simply airlock and cease to pump
anything...It can't pump against the other pump that is pumping fuel.
Secondly...even if the pump did pump air it simply gets flushed out of
the float bowl in the carb.
I have proved this over 400 hours in my last airplane.
In my new FI'd airplane, Getting air to the servo would not be great but
I really doubt the pump will pump any air against the 30 psi made by the
other pump...I haven't tried to prove this yet.
The really neat thing about this install is that you can even lose all
the fuel out of one tank on take off, plug a fuel filter etc, and the
engine will still run normaly.
Frank
Posted: Mon Sep 11, 2006 7:46 am Post subject: Fuel Pump Switch(es) |
On Sep 11, 2006, at 7:43 AM, glen matejcek wrote:
| Quote: | airplane. The low wing planes have left, right, and off. With a
high wing
drawing fuel
by the
installation.
The Nanchang CJ6A and Yak-52 both are low-wing airplanes with a
single on/off fuel selector. The wing tanks gravity feed to a header
tank at the low point in the fuselage. The header tank feeds the carb
through a manual wobble pump, the firewall fuel shut-off, and the
engine-driven fuel pump. All three tanks share a common vent. The
header tank has small flapper valves to prevent fuel from flowing
back out to a tank.
Many complain of uneven fuel feed but I have found that keeping the
ball in the center solves the problem. And even if you do get a
substantial imbalance, getting the ball back into the center causes
the fuel to feed from the more-full tank. It seems to work pretty well.
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Sep 11, 2006 7:57 am Post subject: Re: Fuel Pump Switch(es) |
| aerobubba(at)earthlink.ne wrote: | George / Kevin-
glen matejcek
aerobubba(at)earthlink.net |
RE: Kevin, besides all the good points George makes,
airplane.
JFTR: New Cessna 172's have a Left/Right/Both fuel selector
Posted: Mon Sep 11, 2006 8:12 am Post subject: Fuel Pump Switch(es) |
See below....
Posted: Mon Sep 11, 2006 12:37 pm Post subject: Fuel Pump Switch(es) |
On Mon, 2006-09-11 at 08:57, Bill Denton wrote:
| Quote: | RE: Kevin, besides all the good points George makes,
airplane.
Well, it is probably not safe to use the words "always", "never", and
"only" when describing systems. As I pointed out earlier, both the
Nanchang CJ6A and Yak-52 are low-wing aircraft that have only an on/off
fuel selector at the firewall. There is no way on either of these
aircraft to select a left or right tank. They are always on "both".
Brian Lloyd
martorious(at)charter.net Guest
Posted: Mon Sep 11, 2006 2:22 pm Post subject: Fuel Pump Switch(es) |
Bob, I think the reason he wanted to leave a reserve in each tank is in case
the fuel pump in the opposite tank quit and he was therefore denied access
to the fuel in that tank he would have the reserve fuel in the 'good' tank.
Marty
