cartaire(at)hotmail.com Guest
Posted: Mon Sep 04, 2006 7:55 am Post subject: a few q's for the experienced builders |
I really did try to figure this out myself, but...
The rudder is the first sub-assembly to use AD-41 and CS4-4 pulled rivets.
Both get drilled to #30, I presume?
And do you countersink, dimple, or both for the CS4? 120 degrees?
Anyone have an online source for this info? (I didn't find in mil-spec or
other google attempts)
Thanks, Carter
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
vitez(at)carolina.rr.com Guest
Posted: Mon Sep 04, 2006 8:33 am Post subject: a few q's for the experienced builders |
Yes, #30... and CS4-4 are dimpled (or countersunk, depending on material
thickness)... Using your regular #30 dimple die set will work.
Radomir
-7A Finish
coop85(at)bellsouth.net Guest
Posted: Mon Sep 04, 2006 1:20 pm Post subject: a few q's for the experienced builders |
One other suggestion since you are just getting started with some of the pop
rivets. I bought a pneumatic rivet puller from Harbor Freight and I have no
doubt it saved my hands, especially on the fuselage floorboards. It's the
same gun sold by lots of folks for a whole lot more money, if you watch for
it, Harbor Freight often has them on sale for about $19 if I remember right.
Marcus
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Sep 04, 2006 3:37 pm Post subject: a few q's for the experienced builders |
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Lenleg(at)aol.com Guest
Posted: Tue Sep 05, 2006 1:48 pm Post subject: a few q's for the experienced builders |
I bought one from Northern Tools locally and it works like a charm !!
Len
In a message dated 9/4/2006 5:21:56 P.M. Eastern Standard Time, coop85(at)bellsouth.net writes:
| Quote: | One other suggestion since you are just getting started with some of the pop
Marcus
Posted: Tue Sep 05, 2006 4:45 pm Post subject: a few q's for the experienced builders |
While you're at HF, pick up one of their elcheapo swivel head pullers,
too. If you're building RV-x fuel tanks, you will need to grind off
about 40% of the puller snout & it's nowhere nearly as painful to
destroy a $5 tool. And, it will still work to pull rivets in places no
other puller can reach, using the swivel head.
Lenleg(at)aol.com wrote:
| Quote: | I bought one from Northern Tools locally and it works like a charm !!
Len
of the pop
I have no
It's the
watch for
remember right.
Marcus
rwayne(at)gamewood.net Guest
Posted: Tue Sep 05, 2006 6:36 pm Post subject: a few q's for the experienced builders |
Got mine off eBay real cheap.
A must have!
Wayne
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Lenleg(at)aol.com
Sent: Tuesday, September 05, 2006 5:48 PM
To: rvsoutheast-list(at)matronics.com
Subject: Re: a few q's for the experienced builders
Len
Marcus |
01234567890123
