RobHickman(at)aol.com Guest
Posted: Sat Jan 21, 2006 8:50 am Post subject: Artificial Horizon Uncertified |
In a message dated 1/21/2006 6:38:47 AM Pacific Standard Time,
Bruce(at)glasair.org writes:
I really don't understand this rush to go out and bet your life on untested,
uncertified instrumentation.
Bruce
www.glasair.org
Yet you will go out and bet your life on an untested, uncertified plastic
airplane?
Sorry, I could not resist....
Rob Hickman
Bruce(at)glasair.org Guest
Posted: Sat Jan 21, 2006 9:14 am Post subject: Artificial Horizon Uncertified |
OK, I'll go there......
We build our airplanes, be they plastic or aluminum, from proven
designs/kits using accepted methods of construction and, most of us,
certified engines. The only thing left to test, after your FAA inspection
(which is to insure no parts are going to fall off), is the airworthiness of
the beast. That can be determined in the standard 25/40 hour test period. If
you built a known kit your chances of success are good, if it's your own
design you did on the back of a napkin, don't fly over my house.
The same cannot be said for the latest crop of electronic game screens.
They're untested, uncertified, and just plane dangerous for all except
strictly VFR airplanes.
Bruce
www.glasair.org
fstringham
Posted: Sat Jan 21, 2006 11:43 am Post subject: Artificial Horizon Uncertified |
steam gages / vacuum pumps / and slide rules according to this old chemsitry
teacher should be all you need..................bull...............computer
technology on the ground or in the air is here to stay. One person poison is
anothers delicious cake. So like all opinions lets here them and then by
are one experience evaluate the opiinions factuality. Glass panels have now
and will in the future become the standard just as the hand held calculator
forced me to side line my beloved slide rule. Oh and by the way good friends
don't let their friend fly plastic airplanes!!!!!!!!!!!
Frank (at) SGU and SLC RV7A under construction....fuse/fininsh/all glass panel
DON"T ARCHIVE
[quote]From: "Bruce Gray" <Bruce(at)glasair.org>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: RE: Re: Artificial Horizon Uncertified Date: Sat, 21 Jan
2006 12:16:20 -0500
of
If
Bruce
www.glasair.org
Posted: Sat Jan 21, 2006 12:10 pm Post subject: Artificial Horizon Uncertified |
Now, Now, I haven't thrown any stones at your 'beer can' airplanes. We all
make our choices and have our reasons. You can load up your RV with all the
computer gizmo's you want, fly off into the nearest cloud bank, merrily on
your way to your next ILS approach. Just don't think all that stuff makes
you safer (it doesn't), or less prone to an accident (it doesn't). When that
hypnotic HITS (Highway in the sky) symbology leads you to a premature
arrival 1 mile short of the runway because you were flying computed data
rather than raw data, just say, "Oh well, I guess the programer didn't catch
that one!", that's if you can.
Bruce
www.glasair.org
cjensen(at)dts9000.com Guest
Posted: Sat Jan 21, 2006 1:00 pm Post subject: Artificial Horizon Uncertified |
Bruce,
I installed a rearview mirror on my Velocity....so I can keep an eye on
those RVs!!!
Chuck
<fstringham(at)hotmail.com>
Oh and by the way good friends don't let their friend fly plastic
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sat Jan 21, 2006 1:42 pm Post subject: Artificial Horizon Uncertified |
But throw a stone at a plastic aeroplane and and you get low impact damage and possible
delamination. Need then resort to an extensive coin test (now we're talking sophisticated testing)
to ensure the integrity of the structure.
Then there is the Glass Transition temperature at about 2x the cure temperature. So if the structure
is assembled in the garage and cures at 25C - the GTT is about 50C. New Years day 2006 at my home
(in shade) was 44.5C pretty close to that GTT.
Then there is the potential to have the materials go off or become contaminated before use
(hygroscopic -> moisture contamination).
A software bug with an EFIS will not cause the aircraft to fall from the sky unless you are in solid
IFR at the time. Like always you should have a backup TC or other if you are entering IFR (legally
or not).
The probability of being in IFR and having a horizon failure is slight especially if the intention
is for it to be a VFR aircraft and the IFR penetration was inadvertent. Interestingly such failures
are documented for vac systems with alarming frequency.
A major risk for electrical electronic and mechanical systems is failure due to the environment -
high vibration, thermal and pressure cycling. This is an acknowledged risk, but we have to accept it.
Software bugs is another significant problem. The Dynon 'leans' was a classic example but was
rapidly rectified as soon as the problem became apparent.
What about the GPS's we fly? Do they all have RAIM display? Do they have the certification, and
then there is the GPS satellite system?
We all do our personal risk assessments (well I hope we do) when we launch a flight or decide to
build an aircraft ourselves. We may not think of them formally like a system engineer may do, but we
do assess according to what we can reasonably know.
I have made my own assessment, that is why I am building a metal aeroplane, installing a Lycoming
with a GRT EIS, with an unproven EFIS/GPS/AP for **strictly** VFR use only.
Sorry for the log rambling post - and the slight against plastic aircraft but this is after all the
rv-list.
Doug Gray
RV-6 instrument selection and decision making.
Bruce
www.glasair.org
Mark Sletten
Joined: 10 Jan 2006 Posts: 43 Location: St. Jacob, IL (Near St. Louis, MO)
Posted: Sun Jan 22, 2006 5:30 am Post subject: Artificial Horizon Uncertified |
Touche!
Mark
DO NOT ARCHIVE
untested,
Bruce
www.glasair.org
plastic
airplane?
Rob Hickman
_________________ Mark Sletten
Legacy FG N828LM
http://www.legacyfgbuilder.com |
Posted: Sun Jan 22, 2006 5:49 am Post subject: Artificial Horizon Uncertified |
Would you like to race? Or perhaps try an outside loop? How about a vertical
cuban eight? Or fly your next trip at 240 KTAS.
Bruce
www.glasair.org
ebundy(at)speedyquick.net Guest
Posted: Sun Jan 22, 2006 7:05 am Post subject: Artificial Horizon Uncertified |
At the risk of wasting bandwidth or encouraging you further, I have to
wonder exactly what you are trying to accomplish.
Personally, I think Glasair's are fine airplanes. However your comments are
a little silly. Sure, I'll race you, but we get to factor in the difference
in fuel bills and MPG once we get there. Outside loops? Ugh, no thanks.
But lets head over to some of the incredible mountain airstrips in my neck
of the woods. One of my favorites is 1500' long, sort of rough, and has
water on both ends. Also, if there are 1200 Glasairs flying as the factory
claims (is there still a factory? They've "restructured" so many times I'm
not sure) why is it that I rarely catch a glimpse of one? I guess they're
so fast it just makes them seem elusive. By contrast, with "only" 3.5x as
many RV's flying I see them at virtually every airport I visit.
Anyway, my point is that all airplanes have their uses and supporters, pros
and cons, and everyone makes their choice based on personal preference. Do
you really think that you are going to convert anyone on the RV LIST? Or
are you just trolling? Or perhaps they kicked you off the Glasair list.
Anyway, if you're ever out in the Boise area, I'd love to go for a ride, and
I'd be happy to reciprocate. Then I'll buy you a beer, and we can have a
good-natured discussion of our findings.
Ed Bundy
| Quote: | Would you like to race? Or perhaps try an outside loop? How about
a vertical
Bruce
shempdowling2(at)earthlin Guest
Posted: Sun Jan 22, 2006 7:49 am Post subject: Artificial Horizon Uncertified |
Hey, plastic planes are great. I just wouldnt buy a used one. These things
are amateur built with no way of proving the glass work was done correctly.
So you have 6 figures into them with no way of proving its worth.
I just need an inspection mirror and, if necessary, a rivet gauge. Oh yeah,
and I can do that in 40 years as well
If I had the money to throw away, I would build a plastic plane, like a
Lancair IVP. I dont.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
Posted: Sun Jan 22, 2006 8:14 am Post subject: Artificial Horizon Uncertified |
I have no axe to grind, I think RV's are great airplanes, someone else just
started tweaking my fiber glass nose though.
What I was trying to accomplish, was this. I was trying to dampen some of
the enthusiasm for all this low cost glass by pointing out the risks
involved. You, or anyone else, can fly whatever panel you like. Just
understand the ramifications and limitations of your decisions.
That's all. Now, with a collective sigh of relief heard from all, I'm done
with this topic.
Bruce
www.glasair.org
Posted: Sun Jan 22, 2006 8:53 am Post subject: Artificial Horizon Uncertified |
Bruce,
Yes, the RV v. plastic planes stuff was good natured, tongue in cheek
stuff that a couple interpreted as being more serious than it really was
(or at least I thought it was tongue in cheek!!!).
While I like my Velocity a lot, the RVs have some very fun
characteristics about them (that obviously make them very popular) that
I envy. It's all about mission profile. For me the Velocity is
perfect, for the next person, the RV is the only thing that works. I
know this with certainty; if I wanted to go into a 1500' mountain strip,
I ain't going there in a Velocity...though I may overfly the strip at
good speed and in considerable comfort, even after a several hour flight
getting there.
Chuck Jensen
just
of
done
with this topic.
Bruce
www.glasair.org
PFolbrecht(at)starkinvest Guest
Posted: Sun Jan 22, 2006 9:23 am Post subject: Artificial Horizon Uncertified |
Well said!
JetPilot
Posted: Sun Jan 22, 2006 10:19 am Post subject: Re: Artificial Horizon Uncertified |
The author of the origional thread has a very limited, narrow view of things. Just because something is "certified" does not make it better or safer. That kind of backwards thinking just hindres progress.
And yes, having a moving map IS safer, as it increases situational awareness. There are many many dead people that have flown into terrain that would have lived had they had a moving map display. Failures of people are much more common than failures of moving map displays. For safety, I would take the best moving map display with terrain displayed over "certified" round dials and vacuum pumps any day.
Vacuum pumps are famous for failing, their antique design is very limited and they fail more much more often than pizo-electric gyros. Only a complete moron with the inability to adapt to anything new would say something is safer just because it is "certified".
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
Posted: Sun Jan 22, 2006 10:29 pm Post subject: Artificial Horizon Uncertified |
Mr. Bigelow,
I can assure you that my view of things are just as wide as yours. My
profession requires me often to think "outside the box". You may disagree
with some of my statements or ideas, but don't even try to denigrate my
intelligence.
The new electronics coming on the market are great, I have 2 moving maps on
my panel (G530/430), well 3 actually if you count the EHSI. I never said
that certified was better, I said that certified implied that the product
had gone through a known level of testing and would deliver its specified
function. How long it would function (MTBF) was not addressed. Certification
implies that it will do what its supposed to do, no more.
In my narrow world view of things, I'll take the promise of certification
over the words of a basement engineer any day. Yea, yea, I know,
electro-wizzies last 10,000 hours MTBF. There's a elegant engineering
principal that states, "The more complex solution is not as reliable as a
simple, low parts count solution". Or to put it another way, reliability is
inversely proportional to the parts count.
One other thing, a properly maintained vacuum system is just as reliable as
your electro-whizzy. Wet oil pumps last 2-3,000 hours. And those vacuum
gyros just keep spinning when everything else goes dark.
My Glasair III has vacuum and electric gyros, 2 compass systems, 2
alternators, 2 vacuum systems and one battery. I fly a lot of hard IFR.
Bruce
www.glasair.org
michele.delsol(at)microsi Guest
Posted: Mon Jan 23, 2006 3:24 am Post subject: Artificial Horizon Uncertified |
Good thing this thread was not started in France - As a builder of a tin can
airplane (RV8), I frequently engage in friendly arguments with wood/cloth
airplanes such as Ministrel, Emeraude (from which the CAP 10 was derived)
and plenty of others. There never is a winner but we have lots of fun
battling things out.
Michele
RV8 - Fuselage
PS would never build a plastic airplane or a match-stick/rags one.
n395v
Posted: Mon Jan 23, 2006 5:10 am Post subject: Re: Artificial Horizon Uncertified "Electro Whizzies&qu |
| Quote: | I'll take the promise of certification
electro-wizzies...... |
Below is a short BIO of Greg Richter of Blue Mountain one of those "basemant engineers"
“Richter is a graduate of Georgia Tech holding a Bachelor of Electrical Engineering and is a Grumman Aerospace scholar and a member of the IEEE. Richter has been involved in software, systems engineering, RF, analog and digital electronic design for over 20 years. “
I have 2 BMA EFIS, 2 external comnavs, 1 alternator 2 batteries and a flight Cheetah 210 with solid state harddrive in my F1. I fly a lot of IFR when there is no chance of icing and no TSTMs.
As I have 2 separate electro whizzie systems I do so with confidence and, in my mind, the same degree of safety I would have with a certified system or 3.
The word certified to me instills no confidence the certification standards put out by the FAA are just as likely to have been developed by a lifelong anministrative engineer as by a techno geek.
If you have been around long enough you have encountered "Certified "Flight Instructors, "Certified" mechanics, "Certified" Doctor's, etc,etc...................
Some of whom are idiots.
The key to safety is to have backup and to understand the limitations of the systems you are using. These electro whizzies have been around long enough to have a track record that "implies" they are safe and reliable.
Now I must go and install some rear view mirrors on my Rocket so I can enjoy the look of awe on the face of Velocity drivers as I whizzzzzz by them.
My next plane is going to be a plastic Radial Rocket with Bluemountain whizzies. I reallly the Glasairs but can't fit in one.
_________________ Milt |
steve(at)newtech.com Guest
Posted: Mon Jan 23, 2006 5:32 am Post subject: Artificial Horizon Uncertified |
Hi Bruce,
I am building an RV-7A and really appreciate you coming over to our RV
building list to try and save our lives. Are you doing this for all of
the aircraft type specific mail lists? One can only hope so. There are
so many lives to save and so little time to do it you must be a very
busy man. So that you don't have to spend so much time participating in
the hundreds of type specific mail lists, even though I am sure they all
welcome your participation as much as we do, may I suggest you leave our
group and hang out at the ExperimentalAvionics(at)yahoogroups.com mail
list. That way you can have an audience of people interested in
discussing experimental avionics.
I would like to take this opportunity to thank you for all of your
carefully thought out posts warning us of the perils of using
experimental avionics and look forward to your participation in the
ExperimentalAvionics(at)yahoogroups.com mail list.
DO NOT ARCHIVE
Steve Eberhart
U.S. Air Force trained Instrument System Technician,
Software Engineer, RV-7A builder
Bruce Gray wrote:
Mr. Bigelow,
intelligence.
Bruce
www.glasair.org
Posted: Mon Jan 23, 2006 7:26 am Post subject: Artificial Horizon Uncertified |
I can see the reasons that the RV list has a reputation for driving out
those brave souls who don't blindly follow the group mindset. Good luck, you
guys. I hope all have a sound backup plan. If not, there's always the 'cat
and duck' method of IFR flying.
For those not familure with the 'cat and duck' method, here's a description,
THE CAT & DUCK METHOD OF IFR FLYING:
Today's flight age is an era highlighted with increasing emphasis
on safety. Instrumentation in the cockpit and in the traffic
control tower has reached new peaks of electronic perfection to
assist the pilot during take-offs , flight , and landings. For
whimsical contrast to these and other marvels of scientific
flight engineering , it is perhaps opportune to remind pilots of
the basic rules concerning the so-called Cat-and-Duck Method of
Flight , just in case something goes wrong with any of these new-
fangled flying instruments you find in today's aircraft.
Place a live cat on the cockpit floor. Because a cat always
remains upright , he or she can be used in lieu of a needle and
ball. Merely watch to see which way the cat leans to determine
if a wing is low and , if so , which one.
The duck is used for the instrument approach and landing.
Because any sensible duck will refuse to fly under instrument
conditions, it is only necessary to hurl your duck out of the
plane and follow her to the ground.
There are some limitations to the Cat-and-Duck Method, but
by rigidly adhering to the following check list , a degree of
success will be achieved.
1. Get a wide-awake cat. Most cats do not want to stand up
at all, at any time. It may be necessary to get a large fierce
dog in the cockpit to keep the cat at attention.
2. Make sure your cat is clean. Dirty cats will spend all
their time washing. Trying to follow a cat licking itself
usually results in a tight snap roll, followed by an inverted (or
flat) spin. You can see this is very unsanitary.
3. Old cats are best. Young cats have nine lives, but an
old used-up cat with only one life left has just as much to lose
an you do and will therefore be more dependable.
4. Beware of cowardly ducks. If the duck discovers that
you are using the cat to stay upright - or straight and level-
she will refuse to leave without the cat. Ducks are no better on
instruments than you are.
5. Be sure the duck has good eyesight. Nearsighted ducks
sometimes will go flogging off into the nearest hill. Very
short-sighted ducks will not realize they have been thrown out
and will descend to the ground in a sitting position. This
maneuver is quite difficult to follow in an airplane.
6. Use land-loving ducks. It is very discouraging to break
out and find yourself on final approach for some farm pound in
Iowa. Also, the farmers there suffer from temporary insanity
when chasing crows off their corn fields and will shoot anything
that flies.
7. Choose your duck carefully. It is easy to confuse ducks
with geese because many water birds look alike. While they are
very competent instrument flyers , geese seldom want to go in the
same direction you do. If your duck heads off for the Okefenokee
Swamp, you may be sure you have been given the goose.
From: http://www.anvari.org/shortjoke/Aviation/1404.html
Keep your sense of humor, guys.
Bruce
www.glasair.org
ronlee(at)pcisys.net Guest
Posted: Mon Jan 23, 2006 8:40 am Post subject: Artificial Horizon Uncertified |
I don't know that people leave this list because of disagreements. Personally
I take grief for flying high whereas other RV pilots fly closer to the
ground. A
recent close encounter with a Cessna at 9500' (low in my book) just reinforces
my belief that it is safer higher.
I do have a question about the Dynon system. Some say that it is acceptable
for use in IFR flight. Is there anything in writing that confirms that
assertion?
I also am of the impression that the issue of certified or not is not that
important.
Look at the NTSB accident reports and see the boneheaded, Darwin-tempting
things that pilots do that kill themselves and others. If you want to reduce
accidents, figure out how to keep pilots from making STUPID decisions that
result in fatalities.
Ron Lee
