Deems Davis
Posted: Fri Aug 25, 2006 12:21 pm Post subject: Forest of Tabs |
Where have people mounted their forest of grounding tabs?
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
jesse(at)itecusa.org Guest
Posted: Fri Aug 25, 2006 12:44 pm Post subject: Forest of Tabs |
On the Firewall into a nutplate.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Dick Sipp
Posted: Fri Aug 25, 2006 8:11 pm Post subject: Forest of Tabs |
146.72 KB |
285 Time(s) |
dlm46007(at)cox.net Guest
Posted: Sat Aug 26, 2006 7:21 am Post subject: Forest of Tabs |
One thing to consider here is that there are now two extra holes in a
structural piece that were not envisioned by the aircraft designers. I
usually try to avoid putting any additional holes in pieces that hold the
engine or gear or flight surfaces securely
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sat Aug 26, 2006 4:13 pm Post subject: Forest of Tabs |
Where did you find those connectors?
steve
Deems Davis # 406
Here is one option. There are two similar ground connectors mounted above
and below the triangular reinforcement where the firewall and top longeron
meet. There are at least thirty ground pins available in each connector.
The paint was removed under the mounting. I am planning to also terminate
the large ground lead from the engine on the same triangular reinforcement.
Dick Sipp #65
Finishing
Dick Sipp
Posted: Sun Aug 27, 2006 6:56 am Post subject: Forest of Tabs |
dmasys(at)cox.net Guest
Posted: Mon Aug 28, 2006 8:08 am Post subject: Forest of Tabs |
B&C has several different configurations of 'forest of tabs' grounding plates:
http://www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?26X358218
-Dan Masys
FWF and panel
---- Steven DiNieri <capsteve(at)adelphia.net> wrote:
steve
> Deems Davis # 406
Dick Sipp #65
Finishing
