brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Aug 22, 2006 1:35 pm Post subject: Ergonomics (was: Flap switches/relay wiring) |
A lot of people seem to want to move functions onto their stick or their
throttle. I would counsel some thought about how you use that function
before you rush to put it on your stick.
The first question is; how much do you use that function? One of the
popular functions to put on the stick seems to be the IDENT function of
the transponder. How often does ATC ask you to squawk IDENT? Not very
often. How hard is it to reach over and press the ident button on the
xpdr? Probably not too hard. An IDENT button on your stick or yoke
requires you do add wiring and a switch. How much is that likely to gain
you in terms of ease of use? I bet that the total amount of effort
required to push the IDENT button every time ATC asks you for the life
of your airplane is less than the time it will take you to wire the
switch. Not a great return on investment.
Now, about the flaps. Again, this is not something you are going to be
using over and over again in one flight. You are going to use it once or
twice per flight. Again, no big impact to have to move your hand to a
flap switch on the panel or near your throttle.
Likewise something like that radio active/standby frequency toggle.
Since you have to put your hand up to the radio to change the frequency
anyway, you may as well press the button to toggle between active and
standby.
So think about the kinds of things you use over and over again in
flight. The short list that comes to mind:
1. radio PTT
2. intercom PTT
3. speed brakes
4. trim
5. weapons select
6. weapons release
There just isn't a whole lot more you are going to use enough to justify
putting it on the stick or throttle so maybe you just want to keep it
simple.
Brian
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
chaztuna(at)adelphia.net Guest
Posted: Tue Aug 22, 2006 2:40 pm Post subject: Ergonomics (was: Flap switches/relay wiring) |
---- Brian Lloyd <brian-yak(at)lloyd.com> wrote:
standby.
1. radio PTT
2. intercom PTT
3. speed brakes
4. trim
5. weapons select
6. weapons release
simple.
Brian
Listers,
I suggest that having radio station Flip/Flop and Station Scan switch ( a single pole double throw momentary switch) is a very useful item to have on the stick. If the radio stack is located away from the co-pilot, it is a necessity for them.
Charlie Kuss
standby.
1. radio PTT
2. intercom PTT
3. speed brakes
4. trim
5. weapons select
6. weapons release
simple.
Brian
Listers,
Charlie Kuss
peter(at)sportingaero.com Guest
Posted: Tue Aug 22, 2006 5:42 pm Post subject: Ergonomics (was: Flap switches/relay wiring) |
| Quote: | So think about the kinds of things you use over and over again in
1. radio PTT
2. intercom PTT
3. speed brakes
4. trim
5. weapons select
6. weapons release
| Quote: | There just isn't a whole lot more you are going to use enough to
justify
| Quote: | putting it on the stick or throttle so maybe you just want to keep it
simple.
Well, if we're going off on this tack I would add
-Master mode select (air-to-ground, air-to-air, nav, approach)
-AAM cage/uncage
-Waypoint step up
-Weapon aiming sensor select
-Sensor slew/zoom/track/scan
-Autopilot/stabs disconnect
-Chaff/flare release
What's appropriate to small airplanes (as well as those Brian
mentioned)?
Autopilot disconnect
Possibly waypoint step up if your GPS/EFIS allows
Where's the flap switch? On the panel in front of the throttle
Radio tune/flip flop? On the up front controller (just below the HUD)
Waypoint insert/select? Up front controller
So for those actions that are done a lot (radio tune), where you have to
look in, put the box just below the glare shield so that you move your
eyes a minimum distance.
Might as well learn something from all those taxpayer $$$!
BTW some 2 seat Pitts' had the PTT on the throttle - always seemed like
a good idea if you expect to have an autopilot in the right seat.
Pete
Posted: Tue Aug 22, 2006 6:29 pm Post subject: Ergonomics (was: Flap switches/relay wiring) |
Hear, hear!
Maybe add AP disconnect in lieu of the weapons switches....
Rob Wright
Bruce(at)glasair.org Guest
Posted: Tue Aug 22, 2006 7:12 pm Post subject: Ergonomics (was: Flap switches/relay wiring) |
In my rather sedate Glasair III I have speed brakes, coolie hat trim
(aileron and elevator), CWS (control wheel steering for the AP), PTT,
Xponder Ident, and AP disconnect. The CP has duplicate switches but all
except PTT are disabled by a panel mounted transfer switch.
Bruce
www.glasair.org
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Wed Aug 23, 2006 4:24 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Given that this started as a discussion of the hazards of having the flap
control mounted on the stick, wouldn't mounting the speed brake control on
the stick pose a similar hazard?
tgesele(at)optonline.net Guest
Posted: Wed Aug 23, 2006 5:41 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Based on the normal crew I plan on having in my plane (wife and two young
daughters) - I'm planning on putting the pilot isolate switch for the
intercom on the stick grip.
It's what I've always dreamed of - a mute switch for the girls in my life...
please... do not archive
brian-av(at)lloyd.com Guest
Posted: Wed Aug 23, 2006 5:42 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
On Aug 23, 2006, at 5:22 AM, Bill Denton wrote:
<bdenton(at)bdenton.com>
the flap
control on
IMHO, no. Speed brakes can be used at any speed without danger to the
aircraft. Speed brakes don't produce a pitching moment nor do they
change the capability of the structure to carry the load. If you
inadvertently deploy the speed brakes in flight you can just feel
stupid and laugh it off. If you inadvertently deploy the speed brakes
on final you will increase the rate of descent but you could deal
with that by increasing thrust (or retracting them again).
No, I don't see the accidental deployment of speed brakes and the
accidental deployment of flaps in the same category.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
jpleasants(at)bellsouth.n Guest
Posted: Wed Aug 23, 2006 7:02 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
FLYaDIVE(at)aol.com Guest
Posted: Wed Aug 23, 2006 7:41 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
In a message dated 8/23/06 11:08:57 AM Eastern Daylight Time,
jpleasants(at)bellsouth.net writes:
| Quote: | So, has anyone developed an after-market for sidewinder/rocket rails, or
MERs/TERs for an RV? And, we will need a gunsight.
DO NOT ARCHIVE
Jim Pleasants
I have hard points for an AA-5.
mlas(at)cox.net Guest
Posted: Wed Aug 23, 2006 9:51 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Or speed brakes...
Posted: Thu Aug 24, 2006 1:40 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
My speed brake deployment has been tested to Vne. Accendital deployment only
causes the airplane to slow down.
Bruce
www.glasair.org
khorton01(at)rogers.com Guest
Posted: Thu Aug 24, 2006 2:38 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
What happens if there is an accidental deployment during the landing
flare?
Kevin Horton
On 23 Aug 2006, at 09:05, Bruce Gray wrote:
<Bruce(at)glasair.org>
deployment only
Bruce
www.glasair.org
Bill Denton
Posted: Thu Aug 24, 2006 4:15 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
I was thinking more in terms of the other end of the spectrum...
What would happen if the speed brakes were accidentally deployed on short
final?
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Aug 24, 2006 4:32 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Bill Denton a écrit :
final?
The end result would be "interesting"
Fighters have speed brakes on the throttle, because they need it for
formation flying, in-flight refuelling, etc. Their jet engines do not
allow for quick speed reduction.
On other types, airliners or gliders, the speed brakes do have a
dedicated and (hopefully) unmistakeable lever.
On a piston single, unless the owner is a nostalgic ex-fighter pilot, is
a throttle switch really desirable ? Piston engines and props allow for
quick speed reduction for formation flying, for instance.
Any time you add a switch on the stick or throttle, provision must be
made to avoid inadvertent actuation.
I know of at least one clever guy who installed the starter switch on
the throttle...
Gilles Thesee
Grenoble, France
http://contrails.free.fr
George W Braly
Posted: Thu Aug 24, 2006 4:58 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
We have installed several dozen sets of speed brakes on aircraft as an
option with the turbo normalizing systems for the Bonanzas.
There have been lots of variations in the locations of the activation
switches.
I have flown all of these different locations - - from the yoke to the
panel.
My thoughts:
Don't put anything on the stick that you will normally use once or twice
during each flight. That is a mistake and generates more problems.
Things that will be used multiple times - - trim, mic button, are the
two most important - - are appropriate.
Regards, George
mprather(at)spro.net Guest
Posted: Thu Aug 24, 2006 6:21 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Speed brakes are usually very small drag producers that provide energy
control while at high indicated airspeeds. Once slowed to a low airspeed,
speed brakes represent a very small portion of airframe drag. Sometimes,
takeoff performance isn't even particularly degraded with the brakes
extended.
Matt-
final?
Posted: Thu Aug 24, 2006 6:35 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Mr. Thesee,
I just posted another message. Yours reminds me that I didn't mention a
few things...
Early (modern?) fighter jets often flew their final approach with speed
brakes at least partially extended. This allowed them to carry nearly
full power on the engine while on approach. If they had to abort an
approach, the speed brakes could be stowed much more quickly than climb
power could be attained from the jet. The speed brakes were relatively
large, and not designed to be deployed at high airspeeds.
Gliders often have truly enormous speed brakes/spoilers which allow steep
approaches to be flown - drastically reducing their glide ratio. All of
the ones I have seen are mechanically actuated by a large lever in the
cockpit.
The speed brakes that I was thinking of are like the Precise Flight units
commonly installed on higher performance piston singles like Mooney's,
Lancairs, Glassairs, Bonanzas and Cessna 210's. These are electrically
actuated. Mounting the control switch either near/on the throttle or on
the control wheel/stick might make the most sense. These units are
approved for airspeeds up to Vne.
http://preciseflight.com/viewpage.php?pID=10
Matt-
<Gilles.Thesee(at)ac-grenoble.fr>
> short
> final?
the throttle...
Gilles Thesee
Grenoble, France
Posted: Thu Aug 24, 2006 6:42 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Matt and all,
| Quote: | Speed brakes are usually very small drag producers that provide energy
extended.
Thanks for the info.
This type of speed brakes must be particular to some type of airplanes ?
High drag but bigger engine ?
I'm flying sleek airplanes with low over all drag when flaps are up, so
in my opinion, even you low drag brakes would make a difference with them.
Some slower airplanes with weak flap action, or even without flaps,
resort to speed brakes to increase drag during approach.
Gilles Thesee
Grenoble, France
