dan(at)azshowersolutions. Guest
Posted: Sun Aug 20, 2006 5:21 am Post subject: Handheld Trancievers |
Last December I purchased one of the Icom A-24 Nav Coms. I had used it several times to monitor frequencies, yet I hadn't used it to transmit until our radio went south on the way back from Oshkosh this year. The receiving (voice)does ok, however, transmitting is a different story. I couldn't raise anyone. I found that towers couldn't receive me until I was direct line of sight and within 2 miles. My $50 walkie talkies beat the heck out of that!
I wasn't impressed with the Nav end of it either. I have tried it on several occasions flying to and from VOR's and if I rated it on a scale of 1-10 I would give it a 2. I certainly couldn't depend on it.... If I did I would end up in Timbuktu.
I sent the radio in to Icom believing that there was a problem with it. I got it back with a note indicating that it checked out fine on the bench and that I should always use a well charged battery...hmmm. Sound advice, that is if I hadn't already tested it with a freshly charged battery. Of course it didn't work any better after I got it back.
So I was wondering if anyone else has tried using this unit with better success?
Dan B.
Mesa
Kitfox IV (building) 314DW
dosmythe(at)cox.net Guest
Posted: Sun Aug 20, 2006 5:39 am Post subject: Handheld Trancievers |
Yes, but only with an external antenna and power. Mine wouldn't work that well in the cockpit using the rubber duckie only. Now, it works fine out to at least 15+ miles and the tower has no problem receiving (I've asked them several times). I've never even tried the Nav portion.
Don Smythe
taildragon(at)msn.com Guest
Posted: Sun Aug 20, 2006 9:14 am Post subject: Handheld Trancievers |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
We use a IC-A22 with internal whip antenna in the Champ (no battery electrical system) and regularly make calls entering Class Delta from about 10 miles out with no problems. We keep the A22 on the re-charger when it is not flying so we always go out with a fresh charge.
Roger
Float Flyr
Posted: Sun Aug 20, 2006 5:18 pm Post subject: Handheld Trancievers |
The problem with using the "rubber ducky" inside the cockpit of your kit fox is called parasitic interference. To try to put it into simple terms this means the the frame of the aircraft is absorbing some of the output of the transmitter and almost like judo is using the transmitters own power against itself.
The one really great thing you can do for your transmission is to use a tuned antenna. Get an avionics tech or a ham who is active on VHF to hook up a "Bird Watt Meter" between your transceiver and the connection where your antenna plugs into the transceiver. This instrument will tell the teckkie how to set up your antenna for the best performance. One thing that can really affect the range is the size of the ground plane for your antenna. The ground plane for air band should be around 47.24" in diameter or a series of 23.6" radials stretching out from the base of the antenna. It can be made of just about any conductive metal and should be grounded via the braid on your antenna coax. I think there are even some ground planes that are simply foil adhered to the inside of aircraft skin ( if the skin isn't metal). Of course the frame of the aircraft can also make a very good ground plane too.
VHF for most intents and purposes is a line of sight transmission. There is a formula for the distance that can be transmitted under normal conditions. Aircraft tend to fly over objects so range is pretty good. But.... If you get into a deep valley or behind a mountain or some other large obstruction don't expect your little VHF radio to punch through for you.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Aug 20, 2006 6:31 pm Post subject: Handheld Trancievers |
Wow Noel...that is great information...thanks! Almost sounds like you know what you are talking about.:>) It certainly looks like I will need to hook it up to the outside antenna. Since I have your ear, what are your thoughts on placing the comm antenna inside the vertical stab? Some of the guys here in Phx have done that and seem to do fine. Would you expect to see any performance loss doing this? Thanks again and to all who responded.
Dan B
Mesa, AZ
Noel Loveys <noelloveys(at)yahoo.ca> wrote:
[quote] The problem with using the "rubber ducky" inside the cockpit of your kit fox is called parasitic interference. To try to put it into simple terms this means the the frame of the aircraft is absorbing some of the output of the transmitter and almost like judo is using the transmitters own power against itself.
Noel
kirkhull(at)sbcglobal.net Guest
Posted: Sun Aug 20, 2006 6:37 pm Post subject: Handheld Trancievers |
I use an Icom A4 with a whip antenna in the kitfox ten miles easy. An aircraft antenna with a ground plane would be better
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Roger Standley
Sent: Sunday, August 20, 2006 12:13 PM
Subject: Re: Handheld Trancievers
Roger
Float Flyr
Posted: Sun Aug 20, 2006 7:31 pm Post subject: Handheld Trancievers |
There are a lot of aircraft out there that have the com antennas built into the vertical fins. most of them have vertical dipole (Two equal poles set up one opposite the other) glassed into a composite fin. In the kit fox the fin has metal frame which will act exactly as the rubber ducky in the cabin. The upright parts of the tail frame will become parasitic elements which can change the pattern of radiation and no doubt some power absorption.
Stick with a single vertical monopole in the middle of the back of the plane. Have it tuned for the best performance around the middle of the aviation com band. The K9itfox isn't a mach 3 fireball, a few inches of antenna won't affect it's flight envelope significantly
You are right I have more paper in electronics and avionics than I like to admit. As a Canadian Advanced Amateur Radio Operator antenna design and tuning. Believe it or not Amateur Radio is where the real learning and experimentation is done. Amateur pioneered little things like Packet radio ( data routers )
Noel [quote]
Kitfox III-A
jimlc(at)att.net Guest
Posted: Sun Aug 20, 2006 8:55 pm Post subject: Handheld Trancievers |
Regarding handheld radios with rubber duckies, during my more active ham radio days I was using a 2 meter radio and also a business band radio that used an adjoining frequency and as in aircraft when inside of a automobile, the effectiveness of the radios was greatly reduced. I purchased a magnetic antenna mount with attached antenna cable. One could attach an antenna of choice via a baronet coupling. I found that attaching the rubber duckie antenna from the handheld was as good as any much longer antenna and greatly improved the radio performance when set a top the vehicle roof using the magnetic mount.
With a aircraft, one could install a baronet compatible receptacle with an appropriate length cable to the inside of the aircraft and then when needed, attach it to the radio. The small rubber duckie antenna could when need be attached to the mount and would display a small profile for wind resistance.
Jim Crowder
At 09:29 PM 8/20/2006, you wrote:
[quote]There are a lot of aircraft out there that have the com antennas built into the vertical fins. most of them have vertical dipole (Two equal poles set up one opposite the other) glassed into a composite fin. In the kit fox the fin has metal frame which will act exactly as the rubber ducky in the cabin. The upright parts of the tail frame will become parasitic elements which can change the pattern of radiation and no doubt some power absorption.
Noel
Lynn Matteson
Posted: Mon Aug 21, 2006 4:20 am Post subject: Handheld Trancievers |
I had one in my IV until I bought and installed the A200 panel-mount
unit. The A24 worked fine for me, and none of my test pilots for the 40
hours complained.
Lynn
On Sunday, August 20, 2006, at 09:20 AM, Dan Billingsley wrote:
| Quote: | Last December I purchased one of the Icom A-24 Nav Coms. I had used it
back.
better success?
Dan B.
Mesa
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Mon Aug 21, 2006 4:39 am Post subject: Handheld Trancievers |
Oops, I should have added to my previous comment (about having no
problems with the A24) that I had an external antenna mounted on the
'fox.
Lynn
back.
better success?
Dan B.
Mesa
N369LM |
Float Flyr
Posted: Mon Aug 21, 2006 7:02 am Post subject: Handheld Trancievers |
Another neat idea from a ham! I never thought of that because I generally only used the ducks portable.
Noel [quote]
Kitfox III-A
Float Flyr
Posted: Mon Aug 21, 2006 7:12 am Post subject: Handheld Trancievers |
The only problem I've had with my A24 was when my resistor plugs shorted
out.... Don't ask. The ignition noise was that high on transmit that 2000'
away from the tower antenna they still couldn't copy me. I could hear them
strength 5. Luckily the cleared me to leave the zone.
The last time I used the radio, with new plugs amongst other things, I was
strength 5 at 26 miles and 500'asl.
The VOR is a nice little feature for headings just remember the radials are
true and the compass is magnetic. I find my radial and then fly the compass
keeping everything on the ground "looking right". I also carry a GPS but to
be honest I think it takes the fun out of navigation and I tend to fixate on
it a little if it try to navigate by it alone. It's handy to document the
flight as it records position speed and altitude.
Now if they could add a mode "C" transponder to it.... ;^}
Noel
[quote] --
Kitfox III-A
wingsdown(at)comcast.net Guest
Posted: Mon Aug 21, 2006 12:58 pm Post subject: Handheld Trancievers |
I had one for a back up. Made a little adaptor plate with a bulkhead BNC, small hanger mount for the radio and a composite flute antenna under the glare shield. Worked extremely well and also doubled for a VOR since the antenna was a com/nav antenna. The radio has the switching device built in so no need for any type of transfer device. Still have the set up if anyone is interested.
Rick
jack(at)comconn.com Guest
Posted: Tue Aug 22, 2006 4:52 pm Post subject: Handheld Trancievers |
Oddly- I recently donated my sporty's JD-200 to the local neighborhood around my hangar,
and ended up purchasing an Icom A-24 on Ebay.
I thought I'd been "had"- the system would receive, but not transmit.
Whenver I attempted to transmit, I'd get a "low battery" indication..
and no-one could hear me. In, or out of the plane.
I stopped by the local ham supply store- and purchased the alkaline battery pack..
no difference. I, too, happen to be a ham (kc5cyb), and had an Icom VHF 2 meter,
close enough to allow swaps. When I use *that* rubber ducky- all was well*.
I could now be heard (except the alkaline pack still doesn't work right-
different problem?), at least for the first hour after a recharge, and then we're
back to null transmission. My next step is to rig a dipole inside the plane fuselage.
Given it all to do again, I'd buy the big, clunky, functional Sporty's SP-200..
Icom doesn't seem to be what it used to be, when I purchased my IC-2SAT.
$.02
Jack
KF 1(.5)
N79JW
Float Flyr
Posted: Tue Aug 22, 2006 6:27 pm Post subject: Handheld Trancievers |
There is something wrong there.... I'd send the A-24 back for testing. Mine
works great.
Noel
V01-PL
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Aug 22, 2006 6:30 pm Post subject: Handheld Trancievers |
Oh yes remember to vertical polarize the dipole so you have an omni
directional transmission pattern.
Noel
[quote] --
Kitfox III-A
Posted: Tue Aug 22, 2006 7:06 pm Post subject: Handheld Trancievers |
Jack,
That is quite interesting...same thing going on here. I even stood outside my car in direct line of sight to the tower and they didn't hear transmission. After hearing this I wouldnt give two cents for another one. Thanks for the reply.
Dan B
Jack L Bell <jack(at)comconn.com> wrote:
[quote]--> Kitfox-List message posted by: Jack L Bell
no difference. I, [quote][b]
Posted: Tue Aug 22, 2006 7:07 pm Post subject: Handheld Trancievers |
Noel, I did send mine back and they said it checked out fine on the bench. Same thing going on. Don't make sence.
Dan B.
[quote]--> Kitfox-List message posted by: "Noel Loveys"
works great.
Noel
V01-PL
[quote] --
Float Flyr
Posted: Wed Aug 23, 2006 5:17 am Post subject: Handheld Trancievers |
That is not normal for any hand held radio. Send the radio with the antenna back to Icom I'll bet they'll do good for you. The problem could even be in the rubber duck.
Noel [quote]
Kitfox III-A
FLIER(at)sbcglobal.net Guest
Posted: Wed Aug 23, 2006 6:24 am Post subject: Handheld Trancievers |
I have an A6 and use it all the time in my Nieuport.
No problem talking to towers from miles away.
ICOM makes great radios. I agree, send it to them
and let them fix it.
--- Original Message ---
Subject: RE: RE: Handheld Trancievers
| Quote: | That is not normal for any hand held radio. Send
the radio with the =
| Quote: | antenna
problem could even =
[quote]be in
the rubber duck.
Noel
