Speedy11(at)aol.com Guest
Posted: Mon Aug 21, 2006 8:40 pm Post subject: Pullable 80A Circuit Breaker |
Does anybody know a source for a pullable 80A CB to use for the alternator? I've checked several sources and have found 80A CBs that cannot be pulled - they can only be reset, but none that are pullable.
I bought one at Sun n Fun only to discover later that it is 28v.
Stan Sutterfield
khorton01(at)rogers.com Guest
Posted: Tue Aug 22, 2006 1:53 am Post subject: Pullable 80A Circuit Breaker |
On 22 Aug 2006, at 24:37, Speedy11(at)aol.com (Speedy11(at)aol.com) wrote:
| Quote: | Does anybody know a source for a pullable 80A CB to use for the alternator? I've checked several sources and have found 80A CBs that cannot be pulled - they can only be reset, but none that are pullable.
I would have thought that the rating meant the maximum voltage that the CB could be used with. Any lower voltage should be OK. It is measuring amperage, not voltage, and 80A is 80A, no matter what the system voltage is.
Kevin Horton
Ottawa, Canada
aerobubba(at)earthlink.ne Guest
Posted: Tue Aug 22, 2006 6:08 am Post subject: Pullable 80A Circuit Breaker |
Hi Stan-
| Quote: | I bought one at Sun n Fun only to discover later that it is 28v.
28V is the maximum system voltage for that CB. The CB you bought should be
fine for your 14V installation.
glen matejcek
aerobubba(at)earthlink.net
denis.walsh(at)comcast.ne Guest
Posted: Tue Aug 22, 2006 7:01 am Post subject: Pullable 80A Circuit Breaker |
While I am waiting for the real experts to weigh in, I offer the
following unsubstantiated feeling:
I don't think a cb "senses" either volts or amps. Rather it reacts
to heat, whose generation is better measured in watts which is a
function of both.
I would therefore surmise that the cb in question would be well
within its rated range; however would probably not trip a 14 volt
load until 160 amps.
well, where are the electro-experts now that we need them??
Denis Walsh
On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote:
<aerobubba(at)earthlink.net>
Hi Stan-
should be
glen matejcek
nuckollsr(at)cox.net Guest
Posted: Tue Aug 22, 2006 7:38 am Post subject: Pullable 80A Circuit Breaker |
At 10:06 AM 8/22/2006 -0400, you wrote:
Hi Stan-
Glen is correct. I'll amplify his words with the notion
that voltage ratings on switches and breakers are MAXIMUM
level for operating voltage at the cited current level.
There is no practical minimum voltage. See:
http://aeroelectric.com/articles/swtchrat.pdf
While this article speaks specifically to switches,
the same ratings philosophies apply to breakers
that are simply automated switches designed to
sense current.
Hopperdhh(at)aol.com Guest
Posted: Tue Aug 22, 2006 7:58 am Post subject: Pullable 80A Circuit Breaker |
Glen,
CB's are rated in volts only to show what kind of circuit they should be used in. In other words don't use a breaker rated for 28 volts in a 120 volt circuit. A 28 volt breaker would IMHO be fine for use in a 12-14 volt circuit. It is in series with the load, so it can only know the current. It has no way of knowing the voltage or therefore the wattage of the load. It is heat activated by having a small amount of resistance, and the heating power is I*I*R. (I is current, and R is resistance.) This causes it to waste a little power (and voltage) in order to do its job.
Dan Hopper
RV-7A
Playing with electricity since age 2 when I plugged a key into a wall outlet. Nothing happened so I plugged in another key. I'm told it sent me across the room. I've been hooked on the stuff ever since!
In a message dated 8/22/2006 11:03:30 A.M. Eastern Daylight Time, denis.walsh(at)comcast.net writes:
| Quote: | --> AeroElectric-List message posted by: Denis Walsh <denis.walsh(at)comcast.net>
function of both.
Denis Walsh
| Quote: | --> AeroElectric-List message posted by: "glen matejcek"
Hi Stan-
should be
glen matejcek
bsp; --> nbsp; - NEW MATRONICS LIST WIKI -
_-= ; p; - List Contribution Web Site ; =========================
Posted: Tue Aug 22, 2006 8:06 am Post subject: Pullable 80A Circuit Breaker |
Glen,
Sorry, I should have said Stan at the top. I agree with you completely. Bob's post came in after I hit send, so I think we are all in agreement.
Dan
In a message dated 8/22/2006 12:02:38 P.M. Eastern Daylight Time, Hopperdhh(at)aol.com writes:
| Quote: | Glen,
Dan Hopper
RV-7A
function of both.
Denis Walsh
Hi Stan-
should be
glen matejcek
bsp; --> nbsp; - NEW MATRONICS LIST WIKI tion Web Site ; =========================
.matronics.com/">http://forums.matronics.com
ronics.com/">http://wiki.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
mprather(at)spro.net Guest
Posted: Tue Aug 22, 2006 8:16 am Post subject: Pullable 80A Circuit Breaker |
Err.. I am not an expert, but I don't think that is completely correct.
Heat generated is correct, but the heat is generated solely by the current
passing through the CB. The system voltage has no bearing on how much
heat is generated. Draw the circuit and you can see why. The CB goes in
series with the load. Beit a 2V or 200V system, a particular current
through the CB causes a corresponding voltage drop across the CB while the
CB is closed.
The voltage rating is more related to the ability of the CB to open an
operating (overloaded) circuit. The higher the system voltage the harder
it is to open the circuit (break the current) for a given current.
Voltage rating is likely about contact speed and distance (maybe not
both). A larger system voltage implies the need for faster contacts
and/or larger contact distance.
Matt-
function of both.
Denis Walsh
> Hi Stan-
> should be
> glen matejcek
N1DeltaWhiskey(at)comcast Guest
Posted: Wed Aug 23, 2006 8:16 am Post subject: Pullable 80A Circuit Breaker |
Matt,
I am not an expert either, but I*R is not the only source of heat that might
affect a CB. For thermally activated (TA) CB, it is quite possible for
external heat sources to reduce the load carrying capacity of the TACB by
providing "pre-heating."
Say a TACB will trip when the sensing element reaches 600F (I have no idea
what the actual temperature is - it may be much less than that). At ambient
temperature of 70F, we have to provide enough heating to elevate the sensor
temperature by 530F. However, if a situation arises which causes the
ambient temp of the unit to rise, say to 300F, the amount of current the
TACB to elevate the temp of the sensor an additional 300F is decreased
(i.e., reduced capacity).
I visited a client just this week where they were having nuisance trips of a
circuit breaker. Cause: determined to be a bad connection of the CB to the
bus. Remedy: the bus was flipped over to get the pitting away from the CB
contacts and a secure connection was then made.
Doug Windhorn
