deuskid
Posted: Mon Aug 21, 2006 3:55 am Post subject: grass strip operations? |
I know the lightning isn't a bush plane but can it operate off a typical grass strip used by other GA aircraft?
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
N1BZRich(at)AOL.COM Guest
Posted: Mon Aug 21, 2006 4:35 am Post subject: grass strip operations? |
John, Buz here,
Certainly the Lightning can be used on grass strips. The main gear wheel tires are 500x5 (Same as I changed my Esqual to) and I have had my airplane into several grass strips. Don't know if Nick has had the prototype into a grass strip yet, but they often took the hybrid into grass strips for fly-ins, etc. One thing to mention is that the Lightning take off roll will be much shorter than most other GA aircraft, so getting out will be no problem at all. Recently I was at a fly-in at a grass strip in Virginia that was attended by many of my Cub friends. Guess which airplane had the shortest take off roll when we departed?
Someone recently asked about luggage space. As I recall the Lightning is good for 50 pounds. The luggage floor can be installed quite a bit below the back of the seats giving lots of room for two people's baggage. I camped at OSH for two weeks and had all camping gear and cloths in my airplane's baggage area. No, I did not take golf clubs. When you sit in the airplane, the shoulder harness are higher and baggage should be under them. Remember, without the emergency chute, there is much more room back there.
Blue Skies,
Buz
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
