OVM14 MkIII, rev P3
PostPosted: Mon Oct 02, 2023 9:09 am    Post subject: OVM14 MkIII, rev P3 Reply with quote
At 01:42 PM 10/1/2023, you wrote:
Bob, I can't argue with your logic. However, airplanes are toys for many of
us. And builders like to equip their toys with more toys. Take for instance
the VP-X Electronic Circuit Breaker System. It has lots of nice features. But a
builder could install fuses for much less money than the sales tax on the VP-X.
Even so, many builders elect to install the VP-X because they want the
extra features. It is the same with the over-voltage module. Some pilots
want the extra feature of an over-voltage indicator light. Others might elect
to not install the light or reset button.
No argument there my friend. Certainly everyone here on
the list is encouraged to fabricate the airplane
of their dreams.
I hope that what I bring to the List is several
decades of experience in keep it simple, light
as possible, low cost as possible, absolute
conformance to a well stated design goal,
more than passing homage to lessons learned
and human factors.
Yeah . . . the VPX system is a good case study.
I'm recalling conversations with pilots while
working the GP180 project at Lear. Over lunch
one day, we were discussing the features of
the latest EFIS/Navigation system being
integrating into the proposed new airplane.
One fellow opined that he was really pleased
with some of our proposals, "Yeah, all that
stuff gives us something to pass the time
during hours of watching the ground
crawl slowly below."
I was tempted to suggest a pocket video game
but I kept my mouth shut.
I may come off as curmudgeonly in these
discussions. For every one participating
there are 10x present and future readers
perhaps not so confident/capable of sorting
out the issues. Some of these readers might
be better served by crafting an airplane
that behaves very much like their grandpa's
C170. Not trying to be a hard-ass . . . just
encouraging everyone to achieve personal
goals with a foundation of understanding.
Speaking of the test switch 'option', I
have incorporated it onto the ECB as a
maintenance aid. Latest iteration of the
schematic attached. Also did a real estate
survey. I think I can get this critter
assembled and packaged it only 1/4" longer
than the legacy design. Further, it has
retained the simple, two wire integration
feature of the older offerings. One can
ignore the switch and have it work just
like the first few hundred examples did.
Opps, already spotted a 'bug'. R10 calculated
value is 56.2K
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
9003-620-1P3,_OVM-14_Mk_III,_SCHEMATIC.pdf
 Filename:  9003-620-1P3,_OVM-14_Mk_III,_SCHEMATIC.pdf
 Filesize:  167.18 KB
 Downloaded:  531 Time(s)
PostPosted: Mon Oct 02, 2023 10:46 am    Post subject: Re: OVM14 MkIII, rev P3 Reply with quote
Suggestion: Instead of having a wire or wires exiting the over-voltage module
for an external switch, use an internal solid state switch that is magnetically
operated. These devices are small like a transistor and go by various names:
digital magnetoresistive sensors, Unipolar Hall-effect sensor ICs, unipolar
switches, Hall effect IC, Hall switch. Some of these devices require either a
north or south magnetic pole. Others are bipolar. They cost from less than a
dollar on up. For the annual OVM test, a magnet is held near a certain spot
on the OVM. The OVM could be mounted on one side of aluminum skin and
the magnet held on the other side. No external wires or switch required
Joe Gores
Eric Page
PostPosted: Mon Oct 02, 2023 12:34 pm    Post subject: Re: OVM14 MkIII, rev P3 Reply with quote
Bob, did my questions about your Rev P1 schematic slip by unnoticed? See the second post in this thread: http://forums.matronics.com/viewtopic.php?t=16781079
My 2nd question is resolved by Rev P3 but I'm still curious about questions 1, 3 and 4.
Please ignore my last question, below the dashes. I found the answer.
-Eric
PostPosted: Mon Oct 02, 2023 1:49 pm    Post subject: OVM14 MkIII, rev P3 Reply with quote
operated.
<snip>
Hadn't considered that but it could probably
work. Perhaps a reed switch. They'll operate
on either magnetic polarity.
Opted for the dip-switch. Gold, low-level
contacts, environmentally robust. No external
'tools' needed.
(o o)
