Eric Page
Posted: Sat Aug 12, 2023 8:51 am Post subject: Bob's Email Outage - Missed Threads? |
Posted in another thread:
nuckollsr wrote: | Sorry for the relative silence. My email service has been on the fritz (on account of new Google 'security' features) for several weeks. I think we're close to resolving the issues. So for you folks that are missing replies from me . . . especially those with gmail accounts . . . I expect to be up and running shortly. |
Hi Bob -- sorry to hear that you've been incommunicado lately. I posted a couple of threads recently on which I was hoping to get your feedback. Perhaps they appeared during your comms outage? Links to those threads follow.
Overvoltage Protection for Rotax 9-Series Engines
http://forum.matronics.com/viewtopic.php?t=16780921
Starter Circuit: Verner 7U Radial
http://forum.matronics.com/viewtopic.php?t=16780986
Eric
Posted: Mon Aug 14, 2023 8:19 am Post subject: Bob's Email Outage - Missed Threads? |
Quote: | Hi Bob -- sorry to hear that you've been incommunicado lately. I posted a couple of threads recently on which I was hoping to get your feedback. Perhaps they appeared during your comms outage? Links to those threads follow.
http://forum.matronics.com/viewtopic.php?t=16780921 |
In a forum thread that I started in October 2021 about using a Rotax 912iS on my Kitfox, there was some discussion about my use of crowbar overvoltage protection (OVP). In that thread, Joe Gores asked, "Can it be designed to just open the relay without blowing a 1 amp fuse?" It turns out that, yes, it can. After several prototypes, I have a non-crowbar OVP Module for Rotax 9-series engines. See the attached PDF document.
Good work Eric!
Of course, this becomes a classic ov protection relay that simply
latches off in response to an ov event and needs to be reset
by action of the pilot.
My very first task at Electro-Mech back
in the dark ages was for just such a device.
If memory serves, the trip response for that first effort was
sd in the Cessna procurement specification was:
A step response from nominal bus voltage of 14.2 to
20.0 would produce a shutdown in 60 +/- 10 milliseconds.
As a matter of fact, this was an unnecessarily short-
coupled requirement.
DO-160/Mil-STD-704 dictates even back then called for
a certifiable appliance to withstand a 20V excursion
for 1 Second; a 40V excursion for 100 milliseconds.
The 60Ms requirement led to some 'twitchy' designs.
Nonetheless, design goals for ov protection were
pretty similar across the industry. Tens of thousands
of such devices were manufactured and successfully
operated in the GA fleet.
I don't recall the exact time-frame but
around 1980, while crafting a response to a
request for proposal from Beech, I suggested that
their response profile be adjusted to 500+/-50
Milliseconds for a 16V setpoint. With trip
time being independent of magnitude of ov
event. Further, if bus voltage dropped below
16v at any time before the 500 Ms trip target,
the timer resets to zero.
That produced a vociferous barrage of 'incoming'
from various factions at Beech. While all the
electron-herders agreed that the change would
produce a perfectly adequate and less twitchy
design, making such a change would generate
a boat load of re-certification efforts across
several venues.
A classic example of "Once certified: carved
in stone" mentality. I can cite a goodly number
of similar incidents in my GA career when a
marginal (if not poor) condition was allowed
to persist due to cost of running the re-cert
guantlet.
Just for grins, I've sketched up a somewhat
modernized version of that proposal and attached
it to this posting. Input to the voltage sense
comparator need not be filtered for short
transients/noise due to the auto reset feature.
The two comparators are 'open collector' devices
so voltage sense need only pull down on the RC
timing capacitor. If the voltage sense comparator
stays 'open' for the requisite time, the second
comparator will trip and turn on a beefy FET
to supply the crowbar effect. Replacing the
SCR with the FET eliminates one of the 'problem
children' of the legacy design.
With a little shuffling of the schematic,
this might be convertable to a relay driver
that would control the AC side of a PM
Dynamo system. I'll pray over that idea
a bit.
Did a quick pass at a board layout and I think
all the parts fit on the same size board as
our original 9003 CBOV module; about 1.1 x
0.5 inches. Out here in Podunk Kansas I think
I might find some kids who would like to learn
how to assemble the critters. We may just resurrect
the 9003 program with a modernized version of
the design I proposed 40+ years ago.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
Description: |
 Download |
Filename: |
OVM14-3_cartoon.pdf |
Filesize: |
22.11 KB |
Downloaded: |
169 Time(s) |
finn.lassen(at)verizon.ne Guest
Posted: Mon Aug 14, 2023 12:33 pm Post subject: Bob's Email Outage - Missed Threads? |
On 8/14/2023 12:18 PM, Robert L. Nuckolls, III wrote:
Quote: | Quote: | Hi Bob -- sorry to hear that you've been incommunicado lately.� I posted a couple of threads recently on which I was hoping to get your feedback. Perhaps they appeared during your comms outage?� Links to those threads follow.
��� Good work Eric!
��� Of course, this becomes a classic ov protection relay that simply
��� latches off in response to an ov event and needs to be reset
��� by action of the pilot.
��� My very first task at Electro-Mech back
��� in the dark ages was for just such a device.
��� If memory serves, the trip response for that first effort was
��� sd in the Cessna procurement specification was:
��� A step response from nominal bus voltage of 14.2 to
��� 20.0 would produce a shutdown in 60 +/- 10 milliseconds.
��� As a matter of fact, this was an unnecessarily short-
��� coupled requirement.
��� DO-160/Mil-STD-704 dictates even back then called for
��� a certifiable appliance to withstand a 20V excursion
��� for 1 Second; a 40V excursion for 100 milliseconds.
��� The 60Ms requirement led to some 'twitchy' designs.
��� Nonetheless, design goals for ov protection were
��� pretty similar across the industry. Tens of thousands
��� of such devices were manufactured and successfully
��� operated in the GA fleet.
��� I don't recall the exact time-frame but
��� around 1980, while crafting a response to a
��� request for proposal from Beech, I suggested that
��� their response profile be adjusted to 500+/-50
��� Milliseconds for a 16V setpoint. With trip
��� time being independent of magnitude of ov
��� event. Further, if bus voltage dropped below
��� 16v at any time before the 500 Ms trip target,
��� the timer resets to zero.
��� That produced a vociferous barrage of 'incoming'
��� from various factions at Beech. While all the
��� electron-herders agreed that the change would
��� produce a perfectly adequate and less twitchy
��� design, making such a change would generate
��� a boat load of re-certification efforts across
��� several venues.
��� A classic example of "Once certified: carved
��� in stone" mentality. I can cite a goodly number
��� of similar incidents in my GA career when a
��� marginal (if not poor) condition was allowed
��� to persist due to cost of running the re-cert
��� guantlet.
��� Just for grins, I've sketched up a somewhat
��� modernized version of that proposal and attached
��� it to this posting. Input to the voltage sense
��� comparator need not be filtered for short
��� transients/noise due to the auto reset feature.
��� The two comparators are 'open collector' devices
��� so voltage sense need only pull down on the RC
��� timing capacitor. If the voltage sense comparator
��� stays 'open' for the requisite time, the second
��� comparator will trip and turn on a beefy FET
��� to supply the crowbar effect. Replacing the
��� SCR with the FET eliminates one of the 'problem
��� children' of the legacy design.
��� With a little shuffling of the schematic,
��� this might be convertable to a relay driver
��� that would control the AC side of a PM
��� Dynamo system. I'll pray over that idea
��� a bit.
��� Did a quick pass at a board layout and I think
��� all the parts fit on the same size board as
��� our original 9003 CBOV module; about 1.1 x
��� 0.5 inches.� Out here in Podunk Kansas I think
��� I might find some kids who would like to learn
��� how to assemble the critters. We may just resurrect
��� the 9003 program with a modernized version of
��� the design I proposed 40+ years ago.
� Bob . . .
����������������� (o o)
�� ===========o00o=(_)=o00o=========
�� < Go ahead, make my day . . .�� >
�� < show me where I'm wrong.����� >
�� In the interest of creative evolution
�� of the-best-we-know-how-to-do based
�� on physics and good practice.
Looks promising. Do you have a schematic with part numbers? I'm not familiar with the zener diode symbol with a third pin (input) which appear to stabilize the 10V reference.
Finn
Eric Page
Posted: Mon Aug 14, 2023 9:13 pm Post subject: Re: Bob's Email Outage - Missed Threads? |
Thank you, Bob. Much appreciated!
Did you have a second to look at the other thread too?
Cheers,
Eric
