JonathanMilbank
Joined: 14 Apr 2012 Posts: 395 Location: Aberdeen area
Area-51
Posted: Sat Apr 01, 2023 10:42 pm Post subject: Re: Canopy ball stud |
Most gas struts will have a C strap clip at each end (some have a wire spring clip); extend the strut all the way and remove the clip; the socket will come away from the ball.
Give the shaft a light coating of silicone grease to affect smooth op.
rparigoris
Posted: Sun Apr 02, 2023 5:19 pm Post subject: Re: Canopy ball stud |
Hi Jonathan
Ends up I have a spare ball stud and just measured it for you.
A little difficult, I measured across threads and got .186". A 10-32 die wouldn't go on by hand.I tried a 5 x .8mm tap into the nut and it wouldn't go in?
OK got it figured. The threads are 10-32. They plated after they ran a die on them. I ran die on threads and just a tad of plating came off.
So:
** The threads are 10-32
** The length of threaded portion is .390" with a rounded tip
** There is a shoulder on the .390" which is .194" diameter and ~.062" long which isn't threaded
** Where you grab with a wrench (circle with 2 flats) has the circle diameter at .312" and the flats .270" (7 mm)
** The ball is .314" in diameter
Hope that helps
Ron P.
