rockitdoc
Posted: Tue Nov 22, 2022 3:25 pm Post subject: Fusible Links in lieu of ANL protectors |
I am building an RV14A. I planned on using ANL current limiters for the two alternators (60A PP and 40AB&C), but have since learned of these fusible link thingys. I would prefer not to drill more holes in my firewall to mount the ANLs an fusible links would foot the bill nicely. That is, if they provide the services necessary to protect stuff.
If they do, where can one obtain, or how does one fabricate relatively largish fusible links? B&C supplies a 20-24ga link kit which nI have, but what about links much larger?
Thanks, in advance, as usual.
Scott
_________________ RV14A
Began 7-23-20
Fuse and tail Completed 2-20-21
Wings 99%
Finish 90%
Engine 99%
Wiring in Process |
Ceengland
Posted: Tue Nov 22, 2022 4:36 pm Post subject: Fusible Links in lieu of ANL protectors |
Scott
RV14A
Began 7-23-20
Wings 99%
Finish 90%
Engine 99%
Wiring in Process
Historically, they've been pretty common in automotive environments, so
they're easy to get.
8 gauge B lead?
https://www.google.com/search?q=12+gauge+fusible+link&rlz=1C1CHBF_enUS843US843&oq=12+gauge+fusible+link&aqs=chrome..69i57.5702j0j7&sourceid=chrome&ie=UTF-8
Big 6 gauge B lead?
https://www.google.com/search?q=10+gauge+fusible+link&rlz=1C1CHBF_enUS843US843&oq=10+gauge+fusible+link&aqs=chrome..69i57.4102j0j7&sourceid=chrome&ie=UTF-8
You can solder, or use bare copper crimps, & heat-shrink for insulation,
or (at least for the smaller lead) you can probably find a Fast-on crimp
that's big enough. The purpose-built link wire has its own flame-proof
insulation to contain the heat long enough for the link to open.
I like them because not only do they reduce the hardware to be mounted,
they also greatly reduce the number of terminations/connectors in the
circuit.
Charlie
www.avast.com
_________________ Charlie |
Eric Page
Posted: Tue Nov 22, 2022 5:40 pm Post subject: Re: Fusible Links in lieu of ANL protectors |
For wrapping your fusible links, search eBay for "silicone fiberglass sleeve". It's similar to fire sleeve, but available in thin-wall versions and small diameters.
Posted: Tue Nov 22, 2022 6:46 pm Post subject: Fusible Links in lieu of ANL protectors |
At 05:25 PM 11/22/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: "rockitdoc" <scott.shuler(at)colostate.edu>
I am building an RV14A. I planned on using ANL current limiters for the two alternators (60A PP and 40AB&C), but have since learned of these fusible link thingys. I would prefer not to drill more holes in my firewall to mount the ANLs an fusible links would foot the bill nicely. That is, if they provide the services necessary to protect stuff. |
Fusible links are the way to go. Just splice them onto the
risk-source end of your protected feeder.
For the big alternator, I suggest an 8AWG (or larger)
feeder with this fusible link.
https://tinyurl.com/2md9xov3
For the little alternator build a 10AWG feeder (or larger)
https://tinyurl.com/2mek723r
These are just a few options. You can buy
BULK fusible link wire but you wind up with
a extra wire you will probably
never need. Buying automotive pre-fab
links is a lot less fussy and nothing
to inventory.
out of that stuff?"
rockitdoc
Posted: Wed Nov 23, 2022 5:12 am Post subject: Re: Fusible Links in lieu of ANL protectors |
nuckolls.bob(at)aeroelect wrote: | At 05:25 PM 11/22/2022, you wrote:
Quote: | --> AeroElectric-List message posted by: "rockitdoc" <scott>
to inventory.
out of that stuff?" |
Thanks, Bob.
Do I need to protect the fusible link with a fire sleeve, or do the ready-made versions come with protection? And, for that matter, does the bulk fusible link wire come with protection?
Scott
Began 7-23-20
Wings 99%
Finish 90%
Engine 99%
Wiring in Process |
rockitdoc
Posted: Wed Nov 23, 2022 5:47 am Post subject: Re: Fusible Links in lieu of ANL protectors |
to inventory.
Thanks, Bob.
Scott
Began 7-23-20
Wings 99%
Finish 90%
Engine 99%
Wiring in Process |
