CB polarity?
johnbright
PostPosted: Sun Apr 17, 2022 6:08 pm    Post subject: CB polarity? Reply with quote
I’m not using this type of breaker but curious… why is it marked for polarity?
 Filesize:  1.11 MB
 Viewed:  3652 Time(s)
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
PostPosted: Sun Apr 17, 2022 6:57 pm    Post subject: Re: CB polarity? Reply with quote
Since the circuit breaker is rated for AC, polarity doesn't matter.
Only the Chinese know the answer to your question about the LINE and LOAD labels.
Joe Gores
PostPosted: Mon Apr 18, 2022 9:54 am    Post subject: CB polarity? Reply with quote
At 09:08 PM 4/17/2022, you wrote:
--> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
I'm not using this type of breaker but curious… why is it marked for polarity?
There is a constellation of reasons for marking
the input and output connections for breakers,
switches and relays. On of many explanations can
be found here:
https://tinyurl.com/y5zge76c
Standardization specs call for marking terminals
on such devices if it 'makes a difference'. Instances
where it does make a difference includes specialy
breakers with internal features beyond the
rudimentary need to protect a wire from fault
damage.
A manufacturer can choose not to mark inputs and
outputs if their device doesn't care . . . or if
they want to avoid a qualification test that
demonstrates tolerance to a reversed flow.
In small breakers typical of applications
in aviation, the LINE/LOAD labels would be
significant only if there's a third terminal
common to specialized electronics inside the
breaker (soft fault detection, remote trip,
etc).
out of that stuff?"
