Spark suppression diode on starter MOTOR
tomcostanza
PostPosted: Sat Apr 02, 2022 5:06 am    Post subject: Spark suppression diode on starter MOTOR Reply with quote
It's common (or maybe not so common) knowledge that spark suppression diodes are a good idea on relays and contactor coils. But I've found precious little discussion about putting one on the starter MOTOR (B lead). The motor windings have the same issue of collapsing magnetic fields. Is the battery supposed to absorb that energy? This is more of an academic question than a practical one, since airplanes aren't falling out of the sky without them.
Anyone?
Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project
PostPosted: Sat Apr 02, 2022 9:48 am    Post subject: Re: Spark suppression diode on starter MOTOR Reply with quote
Batteries don't absorb the energy from inductive voltage spikes.
The controlling switch contacts do. As the switch contacts open,
an arc jumps across the opening contacts. The energy is dissipated as heat.
Starter motors have counter EMF that might limit inductive voltage spikes.
Joe Gores
PostPosted: Sun Apr 03, 2022 9:55 am    Post subject: Spark suppression diode on starter MOTOR Reply with quote
At 08:06 AM 4/2/2022, you wrote:
--> AeroElectric-List message posted by: "tomcostanza" <Tom.Costanza(at)gmail.com>
P.S. Heres an article I posted about 22 years
ago on the topic of spike suppression . . .
https://tinyurl.com/y79ht8zm
out of that stuff?"
tomcostanza
PostPosted: Mon Apr 04, 2022 3:44 am    Post subject: Re: Spark suppression diode on starter MOTOR Reply with quote
Thanks for that Bob. I read the article in its entirety. But I didn't see where it answered my question. To be clear...I understand why we put diodes across the coil of a contactor or relay. My question is, why don't we put diodes across the starter MOTOR? That has collapsing magnetic fields also doesn't it?
My conjecture tells me that:
The starter contactor has already disconnected the starter motor from everything. So no harm done if there is a flyback current. But I'm not an engineer, and would very much appreciate your educated explanation.
I did see one or two articles for Ford Mustang owners to add a diode here, but that's all. And it didn't explain why; just do it.
Thanks again Bob for all you have and continue to contribute to our knowledge of all things electronic.
Stay healthy everyone.
Clear Skies,
Tom Costanza
Ceengland
PostPosted: Mon Apr 04, 2022 5:52 am    Post subject: Spark suppression diode on starter MOTOR Reply with quote
On Mon, Apr 4, 2022 at 8:20 AM tomcostanza <Tom.Costanza(at)gmail.com (Tom.Costanza(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "tomcostanza" <Tom.Costanza(at)gmail.com (Tom.Costanza(at)gmail.com)>
Clear Skies,
Tom Costanza
Hoping Bob won't mind if I take a swing at rearranging his answer...
Perhaps it's your starting point that's the problem. It isn't 'everything' that a flyback diode protects; it's the controlling switch's contacts that need protection from the arc that forms as they open.The suppression diode on the coil of the contactor protects the (relatively) weak pair of contacts in the switch that controls it, from the relay coil flyback current. With the starter (obviously a much larger, higher energy device than the relay coil), engineers designed its 'switch' (the starter relay) with *two* pairs of contacts, and a much stronger spring to open them than is seen in other relays. The combination of rapid opening due to the strong spring, and the division of load and arcing between the two pairs of contacts, and the overall extremely robust nature of the contacts, means that a flyback diode isn't needed to protect the relay contacts.
Viewed another way, if we used a robust enough switch to control the relay, with really fast acting contacts, we might be able to eliminate the flyback diode from the relay coil. But the diode is much cheaper/simpler than a switch that could handle the arc issue without damage.
tomcostanza
PostPosted: Mon Apr 04, 2022 6:50 am    Post subject: Re: Spark suppression diode on starter MOTOR Reply with quote
Thanks Charlie. So if I understand you correctly, there still is a flyback current from the motor, it just isn't an issue because the contacts on the starter contactor are more robust than a normal relay or battery contactor. Did I paraphrase your answer correctly?
Clear Skies,
Tom Costanza
Ceengland
PostPosted: Mon Apr 04, 2022 7:24 am    Post subject: Spark suppression diode on starter MOTOR Reply with quote
Clear Skies,
Tom Costanza
Yes, that's a pretty good paraphrase of my paraphrase (which I *hope* is
a good paraphrase) of Bob's original explanation.
Wink
PostPosted: Mon Apr 04, 2022 8:51 am    Post subject: Re: Spark suppression diode on starter MOTOR Reply with quote
If it is desired to put a diode in parallel with the starter motor, the easiest way is to connect the banded
end to the downstream fat terminal of the starter contactor and the other end to ground.
It is really hard on a start contactor to chatter while attempting to crank the engine with a weak battery.
Joe Gores
Ceengland
PostPosted: Mon Apr 04, 2022 12:35 pm    Post subject: Spark suppression diode on starter MOTOR Reply with quote
On 4/4/2022 2:31 PM, Robert L. Nuckolls, III wrote:
http://aeroelectric.com/Pictures/Cessna_Diode_Assy/
  Are we not grateful NOT to own a TC aircraft?
  Competent design is based on properties of materials,
  management of energy and refinement of process.
  But as we may observe in the photos cited above,
  'refinement' hasn't really moved in the
  right direction.
EEYouch!
At those prices, a switch would be cheaper. (Unless it was a 'certified' switch...)
bob.verwey(at)gmail.com
PostPosted: Tue Apr 05, 2022 12:12 am    Post subject: Spark suppression diode on starter MOTOR Reply with quote
..and one should consider duty cycle?
On Mon, 4 Apr 2022 at 23:29, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  Dead on. The only thing I would expand upon
  is the term 'damage'. 'Wear' is the operative
  term. I recall a demonstration I did many moons
  ago where I switched a 1.5 volt flashlight cell
  across a 1 ohms resistor.
  Approx 1+ amps of current flow. I did this with
  a sub-miniature, 'micro' switch with the side
  sanded off so that one might observe the inner
  workings.
  While watching the contacts under a microscope
  in a dark room, I could see a tiny arc between
  the spreading contacts. The color of the arc
  was blue . . . HOT. This suggests that for
  even the smallest energy levels, the potential
  for erosion of metal off the contact surfaces
  is not zero; hence wear is not zero either.
  Engineering applications data for all switches
  will include predicted SERVICE LIFE values
  for switches under various operating conditions.
  See:
http://aeroelectric.com/articles/Switch_Ratings.pdf
  Diodes didn't even start to show up in TC aircraft
  until the late 60's.  I was at Cessna when we
  started fabricating diode assemblies to facilitate
  installation in various places about the systems
  including contactor coils.
  I remember Gordon Wood (PhD in physics)
  bought an HP peak-reading voltmeter and discovered
  that some contactor coil spikes exceeded 400-500
  volts! The fact that such a potential existed
  was contrary to our pledge of compliance with
  Mil-STD-704 . . . so began a program to mitigate
  our 'transgression'. It had nothing to do with
  life of the battery contactor switch . . .
  that astounding spike that just had to be dealt with.
  Don't recall any discussions about ENERGY nor
  how it might have propagated into the system . . .
  but we sure stomped out those spikes. Here's
  a constellation of Cessna diode assemblies
  dating from the 1960's to present day.
  right direction.
  out of that stuff?"
Best Regards,Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
