Peter(at)sportingaero.com Guest
Posted: Sun Mar 13, 2022 1:36 am Post subject: Low profile connector plug |
I have installed a new tail light in my rudder and want to improve the connector.
Previously I had the regular Whelen strobe & position moles connectors which made removing the rudder particularly difficult.
I have fitted an LED strobe/position light so have more flexibility in what can be used.
It has 4 terminals – strobe power, position power, ground & strobe sync – I’m using 20 & 22g wire.
The rudder doesn’t have to be removed often but I don’t want to have to cut anything other than the odd cable tie.
I have a 3/8” conduit that penetrates the stern post – the terminals or connector should pass through that.
Currently the favourite is one of these https://uk.farnell.com/cinch-connectivity-solutions/4-140/terminal-block-barrier-4pos-8awg/dp/1608627 with ring terminals.
Does anyone have any easily available (in Europe) alternatives?
Peter
stuart(at)stuarthutchison Guest
Posted: Sun Mar 13, 2022 2:32 am Post subject: Low profile connector plug |
Plenty of 4-pin Molex connectors out there or you could just use a 9-pin D-sub connector. If you don’t have access to a D-sub pin crimper, just get connector halves with solder pins and be sure to use heat shrink for strain relief. The pattern is universal, so easy to make a plate mount for the airframe side., then you can just connect the rudder and secure with a cable tie or use backshells with screw locks.
Regards, Stuart | Quote: | On 13 Mar 2022, at 8:35 pm, Peter Pengilly <Peter(at)sportingaero.com (Peter(at)sportingaero.com)> wrote:
I have installed a new tail light in my rudder and want to improve the connector. Previously I had the regular Whelen strobe & position moles connectors which made removing the rudder particularly difficult. I have fitted an LED strobe/position light so have more flexibility in what can be used. It has 4 terminals – strobe power, position power, ground & strobe sync – I’m using 20 & 22g wire. The rudder doesn’t have to be removed often but I don’t want to have to cut anything other than the odd cable tie. I have a 3/8” conduit that penetrates the stern post – the terminals or connector should pass through that. Currently the favourite is one of these https://uk.farnell.com/cinch-connectivity-solutions/4-140/terminal-block-barrier-4pos-8awg/dp/1608627 with ring terminals.
Peter
werner schneider
Posted: Sun Mar 13, 2022 2:41 am Post subject: Low profile connector plug |
Peter,
I would go CPC connectors, but you might need another tool for crimping:
https://uk.farnell.com/amp-te-connectivity/206061-1/circular-connector-rcpt-11-4-panel/dp/589688?st=cpc
there are plenty of different styles for that you might have to dig into it.
Or use a DB9 and remove the pins to get the cables through the conduit?
good luck
Werner
On 13.03.2022 10:35, Peter Pengilly wrote:
| Quote: | (at)font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;}(at)font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;}p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0cm; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-fareast-language:EN-US;}a:link, span.MsoHyperlink {mso-style-priority:99; color:#0563C1; text-decoration:underline;}span.EmailStyle17 {mso-style-type:personal-compose; font-family:"Calibri",sans-serif; color:windowtext;}.MsoChpDefault {mso-style-type:export-only; font-family:"Calibri",sans-serif; mso-fareast-language:EN-US;}div.WordSection1 {page:WordSection1;} <![endif]--> <![endif]-->
Â
Peter
art(at)zemon.name Guest
Posted: Sun Mar 13, 2022 4:56 am Post subject: Low profile connector plug |
Peter,
I used automobile trailer wiring plugs for my fuel tank senders, which only required three wires. The plugs are cheap, virtually indestructible, and readily available anywhere should I ever need to replace one. You can see my installation in the photo at the bottom of this blog post.
I used the flat kind, like this https://www.etrailer.com/Accessories-and-Parts/Hopkins/HM48235.html
but similar sturdy connectors are available in several form factors. Check the aviation aisle of your local auto parts store.
  -- Art Z.
On Sun, Mar 13, 2022 at 4:51 AM Peter Pengilly <Peter(at)sportingaero.com (Peter(at)sportingaero.com)> wrote:
Â
Peter
My blog:Â CheerfulCurmudgeon.com
The good is already there. Practicing gratitude means being fully aware of the good that is already yours.
Ceengland
Posted: Sun Mar 13, 2022 7:13 am Post subject: Low profile connector plug |
Â
Peter
| Others have mentioned subD connectors. Assuming color coded wires... If you use the machined pins, you can crimp male/female pairs for each wire, and instead of using the housing & shell, just slide a short length of shrink tubing over each joined pair & shrink it. They'll never come apart on their own, and if you need to remove the rudder, just slit the shrink tubing. I think Bob has a cookbook drawing on the AEC website.
_________________ Charlie |
chaskuss(at)yahoo.com Guest
Posted: Sun Mar 13, 2022 7:24 pm Post subject: Low profile connector plug |
Charlie beat me to making his suggestion, so I'll second it. Be sure to stagger where you make these connections, so that you don't have a big wad of connectors in on place to get through to hole in the rudder bottom and the vertical stabilizer spar.
On Sunday, March 13, 2022, 09:15:02 PM EDT, Charlie England <ceengland7(at)gmail.com> wrote:
| Quote: | _filtered {} _filtered {}#yiv3250331820 p.yiv3250331820MsoNormal, #yiv3250331820 li.yiv3250331820MsoNormal, #yiv3250331820 div.yiv3250331820MsoNormal {margin:0cm;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv3250331820 a:link, #yiv3250331820 span.yiv3250331820MsoHyperlink {color:#0563C1;text-decoration:underline;}#yiv3250331820 span.yiv3250331820EmailStyle17 {font-family:"Calibri", sans-serif;color:windowtext;}#yiv3250331820 .yiv3250331820MsoChpDefault {font-family:"Calibri", sans-serif;}#yiv3250331820 div.yiv3250331820WordSection1 {}
Peter
