h&jeuropa
Posted: Tue Jan 11, 2022 1:00 pm Post subject: What did you do with your Europa this week, 1/10 - 1/17 |
Starting thread for this week. Bitter cold and a foot of snow in Michigan. Sunny but no flying!
Jim
Posted: Wed Jan 12, 2022 1:12 pm Post subject: What did you do with your Europa this week, 1/10 - 1/17 |
In Florida we have had a rare weather situation - last weekend was not a perfect flying weekend.
Recently I have changed the bushings and all the hoses in front of the firewall. In the process I installed a thermostat because I have the unusual condition of an engine which runs too cold - oil temps down to 55C in winter (florida winter min 65F). The thermostat has definitely cured this issue and the oil temp sits between 85-110C.
I also installed a bandc voltage regulator with built in OVP protection. This is a nice looking unit and now my voltage is steady at 14.3. Better yet I have removed the separate OVP and relay because the bandC unit has OVP built in. This also appears to have cured the occasional runaway amp reading - amps running up to 70A and then shutting down the dynon instrument.
I also installed a new brush unit in my airmaster.
My old style front wheel had a loose bearing and was a bit wobbly. Regreased and tightened up everything.
Next task to change all the hoses aft of the firewall.
it never ends does it?
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Jan 11, 2022 at 4:05 PM h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
| Quote: | --> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Jim
http://forums.matronics.com/viewtopic.php?p=505665#505665
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
