suggestions on changing Housai rubber shock mounts?
draftsjust417(at)gmail.co
PostPosted: Mon Apr 01, 2019 6:13 am    Post subject: suggestions on changing Housai rubber shock mounts? Reply with quote
Ok Housai guru's...
It's not necessary soon, but eventually I'll need to replace the rubber shock mounts on my CJ's Housai, around the engine mount ring.
I understand there are (16) total: (Cool on front and (Cool on back?
Are there any special techniques I should be aware of, that anyone has found particularly effective?
Pitfalls to avoid?
Seems like placing a tail stand is wise, and perhaps shoring up the engine to counteract its weight to relieve pressure on the (Cool mounting studs?
Doesn't seem like the studs need to be removed. ?
Planning ahead before I make a costly mistake...
Many thanks all-
Justin Drafts
N280NC
Everett, WA
JL2A
PostPosted: Fri Apr 26, 2019 9:33 pm    Post subject: Re: suggestions on changing Housai rubber shock mounts? Reply with quote
Normal shop engine crane lifting through a fat strap around the gearbox / crankcase interface with tail supported seems to work nicely.
We have given up using the rubber engine mounts. They do not seem to last very long. Instead we use a urethane material that is much more durable. They aren't cheap but then nor is having to change those 16 pesky rubber things every 100 hours.
A35plt
PostPosted: Sat Apr 27, 2019 8:20 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? Reply with quote
JL2A do you have a source for these? I need to change mine soon as well. Thanks Robert
PostPosted: Mon Apr 29, 2019 8:21 am    Post subject: suggestions on changing Housai rubber shock mounts? Reply with quote
Ah good point, THANKS for inputs... this looks like a good summer project for me.Justin/N280NC
On Fri, Apr 26, 2019 at 10:39 PM JL2A <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)> wrote:
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)>
http://forums.matronics.com/viewtopic.php?p=488979#488979
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
stephen.hayne
PostPosted: Mon Apr 29, 2019 8:37 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? Reply with quote
Can you please post a source? I'm facing this when I can get around to it...
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp
stephen.hayne
PostPosted: Mon Apr 29, 2019 8:48 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? Reply with quote
443LM Nanchang CJA
Jacquescj6
PostPosted: Thu Jan 06, 2022 8:06 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? Reply with quote
Hi all
Could any body explain how to replace these rubber shocks.
Do one need to take the hole engine of or can you replace them one at a time with out taking the engine of the ring.
Any help would be appreciated.
