Cushion for XS
Mallard
PostPosted: Sat Jun 26, 2021 8:32 am    Post subject: Cushion for XS Reply with quote
Does anyone know what the best material is to use for a cushion in the XS to give me a better view over the nose?
Also if anyone could give me dimensions (width x depth) for the pilot's seat cushion as I don't have access to my own aircraft till the end of July.
Thanks in advance
James
Seat of my pants
Peter pender
PostPosted: Mon Jun 28, 2021 12:23 am    Post subject: Re: Cushion for XS Reply with quote
Hi James,
Have a search for confor foam. I have just received some from Wings and Wheels in the US and very happy with their service and price.
They offer standard size of 400 x 450 x 12.5 or 25mm in different density's which fits in the XS seat pan. Everyone will be different but I used 12.5 of green, 25 of blue and 12.5 of pink and that suits me.
cheers Peter
Mallard
PostPosted: Mon Jun 28, 2021 2:31 am    Post subject: Re: Cushion for XS Reply with quote
Thanks for that info Peter.
Are you saying that your cushion has a total thickness of 50mm?
James
Seat of my pants
erichdtrombley(at)juno.co
PostPosted: Mon Jun 28, 2021 11:20 am    Post subject: Cushion for XS Reply with quote
Hi James,
Yes, I believe that is what Peter is saying. 50mm total thickness, which BTW is what I have as well. I am 6’1” and anything thicker resulted in my head contacting the top of the door. My wife who is 5’8” has three 25mm foam sheets, one green, one blue, and one pink for a total thickness of 75mm, which works well for her.
Erich
Classics Mono 914
____________________________________________________________
Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more
Ahead of Major Trial, an E-Cig Maker Settles
http://thirdpartyoffers.juno.com/TGL3131/60da20af64d8d20ae418bst04vuc1
Teen Beat 2 Usain Bolt Records. Now He's Bound for Olympics
http://thirdpartyoffers.juno.com/TGL3131/60da20af8842520ae418bst04vuc2
Supreme Court Move Is a Win for Trans Student
http://thirdpartyoffers.juno.com/TGL3131/60da20afab8b120ae418bst04vuc3
Peter pender
PostPosted: Tue Jun 29, 2021 12:15 am    Post subject: Re: Cushion for XS Reply with quote
Yes James, exactly as Erich has said but bear in mind I have a piece of thin ply as a base sitting on top of the control tube cover.
Cheers Peter
freddythek10(at)gmail.com
PostPosted: Thu Jul 01, 2021 9:45 pm    Post subject: Cushion for XS Reply with quote
Just to add one more bit…I’m 6’-1”, and my seat cushions are made up of 25mm green foam, 25mm blue foam, plus triangular wedges of furniture foam for thigh supports…I find the wedges to enhance comfort significantly,,,
[img]cid:0152C549-DE33-49CF-93D4-1FF0CE738ED6[/img]
[img]cid:C858333E-49CE-403E-BB48-AE99707F1548[/img]
On Jun 29, 2021, at 1:15 AM, Peter pender <ppen(at)live.com.au (ppen(at)live.com.au)> wrote:
--> Europa-List message posted by: "Peter pender" <ppen(at)live.com.au (ppen(at)live.com.au)>Yes James, exactly as Erich has said but bear in mind I have a piece of thin ply as a base sitting on top of the control tube cover.Cheers Peter
 Filesize:  81.57 KB
 Viewed:  6160 Time(s)
 Filesize:  125.93 KB
davidjoyce(at)doctors.org
PostPosted: Fri Jul 02, 2021 1:20 am    Post subject: Cushion for XS Reply with quote
One note of caution - Impact foam is quite heavy. I think it is a great safety feature and worth having in any aircraft. It probably let my friend get away with a non displaced vertebral fracture instead of a paralysis when he had a very heavy crash landing destroying the plane, but it doesn&rsquo;t need fully sculpted seats. A couple of layers of denser foam in the seat well could be covered with removable cushions made of lighter material and be more readily adjustable for differing pilots/passengers, saving quite a few pounds. Regards, David Joyce, GXSDJ
On 2021-07-02 06:44, Fred Klein wrote:
Just to add one more bit...I'm 6'-1", and my seat cushions are made up of 25mm green foam, 25mm blue foam, plus triangular wedges of furniture foam for thigh supports...I find the wedges to enhance comfort significantly,,,
[img]cid:162521760160deda4196006525077131(at)doctors.org.uk[/img]
[img]cid:162521760160deda41979f6782639064(at)doctors.org.uk[/img]
 Filesize:  81.57 KB
 Viewed:  6156 Time(s)
 Filesize:  125.93 KB
 Viewed:  6157 Time(s)
