david(at)carter.net Guest
Posted: Thu Jun 17, 2021 8:29 am Post subject: Is there a switch configuration that will do this? |
I'd like to have a single switch control both my taxi lights & landing lights. Sounds simple enough, right? Here's the catch. I want to control the taxi lights directly from this switch by making a connection to +12v. The landing lights, however, will be controlled through the Garmin GAD 27 electrical controller "magic box" so that it can provide airspeed-based wig-wag. The GAD 27 light control switch input is active-low.
How I'd like it to work:
1. Switch down - both lights off
2. Middle position - +12v supplied to the taxi lights.
3. Top position - taxi lights no longer connected to +12v, GAD 27 light switch input connected to ground.
I know I can do this with a relay, but I'd rather avoid adding an additional failure point. It's not the end of the world if I use separate switches for these functions, but I'd prefer they are combined on one switch.
David
David Carter
david(at)carter.net (david(at)carter.net)
Posted: Thu Jun 17, 2021 1:59 pm Post subject: Is there a switch configuration that will do this? |
| Quote: | > There MIGHT be a simple way to do this but it
>> depends on the 'pull down' current of the electrical
>> controller. Is there a spec for that device that speaks
>> to parameters of this input?
Here's what I was able to find in the installation manual: (top of page 26-8, or page 342 in Acrobat Reader)
https://static.garmin.com/pumac/190-01115-01_an.pdf
These active-low discrete inputs conform to the following specification:
Low: Vin < 3.5 VDC, or Rin < 375 Ω (input active)
High: Vin > 8 VDC, or Rin> 100k Ω (input inactive)
David Carter
On Thu, Jun 17, 2021 at 5:37 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 11:28 AM 6/17/2021, you wrote:
| Quote: | I'd like to have a single switch control both my taxi lights & landing lights. Sounds simple enough, right? Here's the catch. I want to control the taxi lights directly from this switch by making a connection to +12v. The landing lights, however, will be controlled through the Garmin GAD 27 electrical controller "magic box" so that it can provide airspeed-based wig-wag. The GAD 27 light control switch input is active-low.Â
2. Middle position -Â +12v supplied to the taxi lights.Â
3. Top position - taxi lights no longer connected to +12v, GAD 27 light switch input connected to ground.Â
I know I can do this with a relay, but I'd rather avoid adding an additional failure point. It's not the end of the world if I use separate switches for these functions, but I'd prefer they are combined on one switch. |
out of that stuff?"
Posted: Mon Jun 21, 2021 10:49 am Post subject: Is there a switch configuration that will do this? |
| Quote: | P.S. those 'loose' components present a small
packaging problem. I think I'd fabricate an
assembly-under-heat-shrink of the three compoents
with wires coming out each end.
Use 1/2" dual wall heat shrink . . . that's
how I packaged a few hundred crowbar ov management
modules.
Your finished assembly will be about 1-1/2 inches
long and 3/8" in diameter. It would tie nicely
into an adjacent wire bundle. I've got all the
materials in stock. I could build one up for you.
Bob - thanks for the solution design & for the packaging tip. I was also wondering how much heat the resistor would need to dissipate in this application? I'm guessing not much?
David Carter
On Mon, Jun 21, 2021 at 12:26 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | | Quote: | This switch with addition of two
diodes and the resistor cited above can be configured
to accomplish the switching functions you requested.
See attached: |
modules.
out of that stuff?"
