jeffbudner
Joined: 20 Aug 2020 Posts: 18 Location: Rio Vista airport
Posted: Wed Jun 16, 2021 8:56 am Post subject: Can I use the L 2 Antenna for ADSB |
Hi All, I'm reaching out in hopes someone has knowledge of the Advanced Aircraft Electronics L2 antenna. I have this installed in my plane and connected to a Garmin GTX 320 transponder. I would like to install a Garmin GNX 375 which includes ADS-B in/out. I currently do not have ADSB.
I'm trying to discern if this antenna meets the necessary specs required for ADSB. I have had no luck contacting the company over the past few months, I have left many messages and submitted numerous emails but have never received a reply. Quite frankly I'm wondering if they are still in business because there is no way, that I can see, to even place an order on their site. http://www.advancedaircraft.com/
I reached out to Aircraft Spruce, because they are selling the L2 antenna, but they were unable to answer my question. At this point, I guess my two options is wait and see if it works, or replace it with a new one.
Thanks Much,
Jeff
KIS TR-1, #099
randy.ott(at)gmail.com Guest
Posted: Wed Jun 16, 2021 12:42 pm Post subject: Can I use the L 2 Antenna for ADSB |
yes jeff that antenna is the one to use!😊
| Quote: | On Jun 16, 2021, at 9:57 AM, jeffbudner <jeffbudner(at)gmail.com> wrote:
Thanks Much,
Jeff
KIS TR-1, #099
http://forums.matronics.com/viewtopic.php?p=502387#502387
GalinHdz
Posted: Wed Jun 16, 2021 2:37 pm Post subject: Can I use the L 2 Antenna for ADSB |
The AAE L-2 antenna is the same one I have in my KIS4 for both transponder OUT and ADS-B IN. It works extremely well in our fiberglass airplanes. The frequencies involved (1090Mhz & 978Mhz) are so close you will not notice any difference in power without using a sensitive spectrum analyser and are in a lab controlled environment.
I have attached a photo of my installation as reference.
On Wed, Jun 16, 2021 at 12:57 PM jeffbudner <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)> wrote:
| Quote: | --> KIS-List message posted by: "jeffbudner" <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)>
Thanks Much,
Jeff
KIS TR-1, #099
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?KIS-List
141 KB |
10523 Time(s) |
GalinHdz
Posted: Wed Jun 16, 2021 2:43 pm Post subject: Can I use the L 2 Antenna for ADSB |
FWIW; My ADS-B IN comes from a separate module not from my transponder, hence the two antennas.
Thanks Much,
Jeff
KIS TR-1, #099
jeffbudner
Posted: Thu Jun 17, 2021 4:26 am Post subject: Re: Can I use the L 2 Antenna for ADSB |
Thanks so much guys! My shopping list is now complete.
Jeff
