M14-P stop position
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
sapril001(at)hotmail.com
PostPosted: Sat Mar 20, 2021 11:48 am    Post subject: M14-P stop position Reply with quote
Hi all,
I would like to know what is the position to leave the engine cranckshaft stop to help with the ol that come out of the exhaust when you do your hand prop checking for an hydraulic lock. I would assume it is with number one cylinder at top dead center, that this position would minimise the oil draining in the lower cylinders
Sometime I have no oil at all coming out even after a month being parked but most other days I make a real mess so I am looking for a way to position the engine crankshaft to minimise that.
Sylvain April
Murphy Moose.
Provenance : Courrier pour Windows 10
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Viperdoc
PostPosted: Sat Mar 20, 2021 3:47 pm    Post subject: M14-P stop position Reply with quote
Without a series 2 nose case with a site window there is no way except opening intake drain and wait 24 hours then pull blades until oil drains . Stop there. Otherwise pull. Ladies weekly if it’s going to sit for a month or more.
On Mar 20, 2021, at 2:53 PM, Sylvain April <sapril001(at)hotmail.com> wrote:
Hi all,
I would like to know what is the position to leave the engine cranckshaft stop to help with the oïl that come out of the exhaust when you do your hand prop checking for an hydraulic lock. I would assume it is with number one cylinder at top dead center, that this position would minimise the oil draining in the lower cylinders
Sylvain April
Murphy Moose.
Viperdoc
Viperdoc
PostPosted: Mon Mar 22, 2021 7:42 am    Post subject: M14-P stop position Reply with quote
Apple auto correct strikes again. That was supposed to be pull blades...
Hi all,
Sylvain April
Murphy Moose.
Viperdoc
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
