Rotax 912ULS External Alt Sense Wire
jnmeade
PostPosted: Mon Mar 08, 2021 5:14 pm    Post subject: Rotax 912ULS External Alt Sense Wire Reply with quote
I plan to run a sense wire from the IG terminal of the Denso 201080-0800 40A alternator to the load side of the 25A CB that is used for a master switch on the Flight Design CTSW. The sense wire will be about 5' long.
1. I'm thinking of using an 18AWG wire for the sense wire. I don't want any voltage loss on this sense circuit.
2. Is there any particular need to insert a fuse? It would call for a 10A fuse. If I need one, I'd probably use an inline automobile fuse but I haven't decided to add a fuse or not. Your thought?
PostPosted: Mon Mar 08, 2021 8:09 pm    Post subject: Re: Rotax 912ULS External Alt Sense Wire Reply with quote
The only way to lose voltage is for current to flow. A sense wire that carries very
little current will have very little voltage drop. A 25 amp circuit breaker is too big
to protect a small gauge wire. So protect the sense wire with a fuse. Wires subject
to engine vibration are more likely to short out than in other places in an airplane.
Joe Gores
