		fly4grins(at)gmail.com Guest
				 Posted: Thu Feb 04, 2021 12:29 am    Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
				 Hi All-  I was under the impression viton was not good for reciprocating applications, like brake pucks.  Is there any experience out there to the contrary?
 Thanks in advance!
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gary.A.Sobek
				 Posted: Thu Feb 04, 2021 5:15 am    Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
				Been using Viton on the calipers for 10+ years.  They last longer than the mil spec o-rings.  They are higher temperature rated BUT the down side is they can leak and not seal as well as lower temperatures.  I typically do not operate my RV at the lower temperature  so it is not a big deal for me.
  https://o-ring.info/en/materials/vitonr--fkm/vitonr-temperature-rating/
  https://www.sealingdevices.com/temperature-ranges
   Gary A. Sobek
  "My Sanity" RV-6 N157GS O-320 Hartzell,
  3,400+ Flying Hours NC25, USA
   From: owner-rv-list-server(at)matronics.com <owner-rv-list-server(at)matronics.com> on behalf of GLEN MATEJCEK <fly4grins(at)gmail.com>
  Sent: Thursday, February 4, 2021 8:28 AM
  To: rv-list <rv-list(at)matronics.com>
  Subject: Re: RV-List Digest: 4 Msgs - 02/03/21
  Thanks in advance!
		arplnplt(at)gmail.com Guest
				 Posted: Thu Feb 04, 2021 6:37 am    Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
				I replaced the stock break seals on my RV10 with viton seals after they failed due to a long taxi at KOSH one year.  Never a problem after that.  Also used ATF for fluid due to higher flash point.
 Dave Leikam
  	  | Quote: | 	 		  On Feb 4, 2021, at 2:32 AM, GLEN MATEJCEK <fly4grins(at)gmail.com> wrote:
 Thanks in advance!
		garyvanremortel(at)gmail. Guest
				 Posted: Thu Feb 04, 2021 7:50 am    Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
				Very little reciprocation occurs in disk brake caliper piston.  I replaced the original leaking Nitrile O-rings in mine with Viton 15 yrs ago and haven't had a problem since.  If you are concerned with the poor low temp performance of Viton in your climate, go with Fluorosilicone.
 -GV
 On Thu, Feb 4, 2021 at 12:32 AM GLEN MATEJCEK <fly4grins(at)gmail.com (fly4grins(at)gmail.com)> wrote:
 Thanks in advance!
