Snazpappy
Posted: Sun Jan 24, 2021 12:15 pm Post subject: OIL PRESSURE |
My oil pressure in the front cockpit shows good pressure, but in flight the indication is constantly erratic and the needle jumps around (plus and minus 20 psi from normal pressure) I had a passenger the other day and asked her to take a quick video of the panel in the back cockpit, when I checked out the video the oil pressure was constant but indicating only about 31 PSI?
Where are the sending units located? I am guessing there are two sending units? Also how can I test which one is indicating the proper pressure? I have a YAK 52TW.
Todd
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
Posted: Sun Jan 24, 2021 6:40 pm Post subject: OIL PRESSURE |
Follow the oil pressure line from the oil pump to the firewall. It should go to the firewall under the center of the oil tank where there is a U shaped fitting. The “legs” of the U go to 2 fittings on the firewall. Now guess what’s on the other side of the firewall? Yep! You guessed it. 2 oil pressure senders.
Given the fact you have a TW and the instruments and senders are UMA, you may just want to call UMA and ask them what the normal output should be from the senders. Test them IAW UMA’s instructions and go from there.
Dennis
Quote: | On Jan 24, 2021, at 3:17 PM, Snazpappy <snazman1(at)hotmail.com> wrote:
Todd
http://forums.matronics.com/viewtopic.php?p=500412#500412
