albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Mon Dec 28, 2020 6:58 am Post subject: Epoxy Resin |
Hello,
Is it critical to use the same epoxy as used when originally manufactured? I need to fill some holes and bond some pieces? After searching the internet I don't think it does, but just wanted to confirm here. I searched locally, but nobody carries it. Aircraft Spruce doesn't show it either.
Tony
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
peterz(at)zutrasoft.com Guest
Posted: Mon Dec 28, 2020 7:07 am Post subject: Epoxy Resin |
Aeropoxy avail at ACS is the NA factory kit epoxy.
Cheers,
Pete
C-GNPZ
| Quote: | On Dec 28, 2020, at 10:04 AM, Tony Braun <albertaflyer(at)gmail.com> wrote:
Hello,
Tony
SteveIvell(at)pestproof.c Guest
Posted: Mon Dec 28, 2020 2:18 pm Post subject: Epoxy Resin |
If it's not structural then I doubt it will be a problem if you use a similar 2 pack epoxy equivalent.
Steve
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Tony Braun <albertaflyer(at)gmail.com>
Sent: Monday, December 28, 2020 2:57:19 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Epoxy Resin
Hello,
Tony
graemeh
Posted: Mon Dec 28, 2020 3:07 pm Post subject: Epoxy Resin |
I was told by Europa that I could use West 105 resin with either the fast or slow hardener by Europa tech support.
On Tue, 29 Dec 2020, 11:23 Steve Ivell, <SteveIvell(at)pestproof.co.uk (SteveIvell(at)pestproof.co.uk)> wrote:
Posted: Mon Dec 28, 2020 3:35 pm Post subject: Epoxy Resin |
In north america its aeropoxy from aircraft spruce:
https://www.aircraftspruce.com/catalog/cmpages/aeropoxy.php
| Quote: | On Dec 28, 2020, at 6:17 PM, Graeme Hart <graeme.hart(at)onecoolkat.com> wrote:
graemeh
Posted: Mon Dec 28, 2020 4:01 pm Post subject: Epoxy Resin |
I should have mentioned mine is a North American kit
On Tue, 29 Dec 2020, 12:40 Pete, <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
