Richard Pike
![](images/avatars/57903806352d56370bc2be.jpg)
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Wed Nov 25, 2020 3:39 pm Post subject: 3.47:1 gear box |
My trusty old 582 is due for a full rebuild, and as part of the rebuild I have been thinking of either trying to milk a couple more horsepower out of it via some old 2-stroke polishing techniques, or maybe getting one of Rotax Rick's engines.
Either way, I will need either a C or an E gearbox. I have an opportunity to get an E box for a good price, but it is 3.47:1 ratio.
I am in over my head.
I flew a friends MKIII several years ago with a 582 and that ratio, but I don't remember what prop he had, how many blades, prop length, etc.
The gearbox is off a PPG/Trike rig and comes with a beat up 3 blade Warp Drive prop, blades will probably need replacing.
Seems I remember hearing years ago that either the Ivo or the Warp does not like turning slow with a LOT of pitch.
Anybody on the list using that ratio, and if so, what prop are you using and how do you like it?
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
George Alexander
![](images/avatars/160854153346f1128d2f6b9.jpg)
Posted: Wed Nov 25, 2020 5:19 pm Post subject: Re: 3.47:1 gear box |
Richard Pike wrote: |
..S..N..I..P..
Anybody on the list using that ratio, and if so, what prop are you using and how do you like it? |
Richard:
May not be a good comparison, but for what it is worth, pushing my R503, DCDI, dual carb, I have a 'C' Box with the 3.47 ratio, driven by a Powerfin 3 Blade, F Model, 68".
Have no complaints with this set up.
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
Richard Pike
Posted: Wed Nov 25, 2020 8:20 pm Post subject: Re: 3.47:1 gear box |
Thanks George, I am hoping that someone with a 3.47:1 reduction and a 68" three blade prop on a 582 will chime in.
Kingsport, TN 3TN0
Eugene Zimmerman
![](images/avatars/8935710764a8ff779af988.jpg)
Posted: Thu Nov 26, 2020 7:16 am Post subject: Re: 3.47:1 gear box |
Richard,
I’m presently using a 4/1 ration E box on my Mark 3 with a 70” three blade IVO medium prop.
My engine is a 670 rotax engine which I derated by lowering the compression ratio.
The advantage of the deeper ratio is less prop noise from a slower turning prop. [/b]
rickofudall
![](images/avatars/6819866474ce9fe39455d6.jpg)
Posted: Thu Nov 26, 2020 7:34 am Post subject: 3.47:1 gear box |
Richard, The 582 on my MkIII runs through a "C" gearbox at 4.00:1. WOT gets me only 1500 prop rpm. I have the 3.47:1 gearbox on my HKS. I had a MkIIIX with an "E" gearbox with the conventional 2.62:1 gears. As I was swapping around props I was surprised to find that the difference in pitch going from the 4:1 to the 2.62 was only .2 degrees of pitch. I couldn't find that either ratio of gearbox worked better than another except in the category of noise. Swinging a large dia. prop at low rpm's makes for a noticeably quieter aircraft.
Rick
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Wed, Nov 25, 2020 at 5:42 PM Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
Richard Pike
Kolb Firefly Part 103 legal
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=499526#499526
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
neilsenrm(at)gmail.com Guest
Posted: Thu Nov 26, 2020 10:07 am Post subject: 3.47:1 gear box |
Rick/All
I had a direct drive VW on my MKIIIC that had very poor performance. Switching to a reduction drive with a 1.6 to 1 reduction with a longer prop I got a considerable performance boost. Yes it got a lot quieter also. Consider that it takes HP to make noise. You may not be able to measure the difference in performance but It should be there somewhere. You also get more thrust accelerating a lot more air slowly than less air faster. Between the two my plane climbs faster, has a faster cruise, on less power with lower fuel consumption, lower oil and CHT temps.
A bigger part of the equation might be prop diameter. I went from a two blade 66 to a 72" three blade.
As usual, worth what you paid for it.
Rick Neilsen
Redrive VW Powered MKIIIC
On Thu, Nov 26, 2020 at 10:36 AM Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | Richard, The 582 on my MkIII runs through a "C" gearbox at 4.00:1. WOT gets me only 1500 prop rpm. I have the 3.47:1 gearbox on my HKS. I had a MkIIIX with an "E" gearbox with the conventional 2.62:1 gears. As I was swapping around props I was surprised to find that the difference in pitch going from the 4:1 to the 2.62 was only .2 degrees of pitch. I couldn't find that either ratio of gearbox worked better than another except in the category of noise. Swinging a large dia. prop at low rpm's makes for a noticeably quieter aircraft.
Rick
Virus-free. www.avg.com [url=#m_3214241089636315252_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Richard Pike
Kingsport, TN 3TN0
FORUMS -
WIKI -
b Site -
Richard Pike
Posted: Thu Nov 26, 2020 7:37 pm Post subject: Re: 3.47:1 gear box |
You guys are great, that is just what I needed to know, thanks.
So now it looks like the only real task is fabricating new taller motor mounts to fit the 72" prop?
Anybody want to send some pictures of how you did it?
Kingsport, TN 3TN0
jhauck
Posted: Fri Nov 27, 2020 5:00 am Post subject: 3.47:1 gear box |
I flew with a 72" WARP Drive Prop on my 912 powered MKIII. Had 3/4" prop to tail boom clearance. Was not a problem.
I personally do not recommend raising the thrust line. High thrust line in the pusher configuration is a problem to start with. Increasing thrust line height increases that problem.
Is there a difference between center of thrust of a 912 and 582 on a MKIII? I flew with both engines on my MKIII, but cannot remember.
Richard Pike
Posted: Fri Nov 27, 2020 8:42 pm Post subject: Re: 3.47:1 gear box |
jhauck wrote: | I flew with a 72" WARP Drive Prop on my 912 powered MKIII. Had 3/4" prop to tail boom clearance. Was not a problem.
Thanks for checking in John, I was planning to try and contact you tomorrow.
For a number of years I have been using a 68" prop with 1.5" of clearance between the prop tips and the boom tube. The motor mounts have 1.5" spacers which you can see in two of the pictures here: http://oh2fly.net/oldpoops/pg2.htm
Obviously I do not want to raise the engine any higher, but going from a 68" to a 72", the prop blades are 2" longer and I don't see any way around it.
Just went out and measured both the B box and the E box, and each seems to have 3" between the crank centerline and the hub centerline so that would be a constant.
Open to suggestions - thanks.
Kingsport, TN 3TN0
jhauck
Posted: Sat Nov 28, 2020 5:31 am Post subject: 3.47:1 gear box |
Must be a difference in prop shaft location on the 582 and 912.
I'm fresh out of ideas right now.
Richard Pike
Posted: Sun Nov 29, 2020 6:03 am Post subject: Re: 3.47:1 gear box |
I'm good here: Bryan messaged me some pictures on FB and I can raise the engine enough to have the starter motor clear the motor mounts w/o having any problems. Raising it any higher than that is bad for the thrust line.
Kingsport, TN 3TN0
rickofudall
Posted: Tue Dec 01, 2020 9:55 pm Post subject: 3.47:1 gear box |
Richard, Try this, mount the fwd dampers upside (short side up) and the aft dampers as normal. This will give you another inch and a half or so.
Rick
On Thu, Nov 26, 2020 at 9:39 PM Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=499543#499543
FORUMS -
WIKI -
b Site -
Richard Pike
Posted: Wed Dec 02, 2020 6:30 am Post subject: Re: 3.47:1 gear box |
rickofudall wrote: | Richard, Try this, mount the fwd dampers upside (short side up) and the aft dampers as normal. This will give you another inch and a half or so.
Rick |
Yeah it would. I am thinking it would also change the thrust line/angle, how would that work?
Kingsport, TN 3TN0
rickofudall
Posted: Wed Dec 02, 2020 6:47 am Post subject: 3.47:1 gear box |
I never noticed any effect that wouldn't trim out easily. It doesn't require any physical change to the aircraft and it's reversible. Just eight AN-3 bolts and the two AN-6's.
Rick
PS Trying to fix the need for the huge trim tab on the rudder I made a motor mount plate that turned the engine 5 degrees out of line to the boom C/L. Didn't make any difference whether I turned the mount over to get that offset to the opposite side. The only thing I found that did work was the lower prop rpm of the 4:1 gearbox. My Mk IIIC had a rudder trim tab that was only 6 inches long and barely had a bend in it. I kept adjusting until I needed just a touch of left rudder while climbing and a touch of right rudder in cruise.
On Wed, Dec 2, 2020 at 8:34 AM Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
> Rick
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=499586#499586
FORUMS -
WIKI -
b Site -
Posted: Wed Dec 02, 2020 8:28 am Post subject: 3.47:1 gear box |
Richard
When I switched from a direct drive VW to reduction drive VW I had a 72" prop with 7 inch clearance because of reduction drive. It was trimmable but the first flight was exciting. This added new meaning to power/pitch trim with the new set up also having about twice the thrust. To be clear the reduction drive raised the thrust line 6". I flew it that way for about a year. It is best to keep the trust line as low as possible because it flys better. I wouldn't be concerned about a 1.5 inch change. Also consider that the prop to boom clearance would be about the same so maybe the effective total thrust line change might be less than 1.5.
Rick Neilsen
On Wed, Dec 2, 2020 at 9:50 AM Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Quote: | I never noticed any effect that wouldn't trim out easily. It doesn't require any physical change to the aircraft and it's reversible. Just eight AN-3 bolts and the two AN-6's.
Rick
Virus-free. www.avg.com [url=#m_-3005434832982732249_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
