Posted: Sun Nov 01, 2020 6:17 am Post subject: DIY LED landing light -- Wing skin as heat sink? |
Quote: |
Let's say we use a 100W LED (~13,000 lumens). We'd have to remove 70 to 80W of heat from the LED.
LED doesn't like more than 150°C and it would be better to keep it cooler. LED area 34x34mm. |
Don't think it's quite that bad. LED efficiency is on the order of
35 to 40% which would dump 60 to 65 watts of heat.
Quote: | I don't have a good grasp of thermal conductivity (conductance?). How thick would the mount
plate have to be? How much area would be needed where the mount plate contacts the wing
skin (using some kind of heat sink compound/adhesive between the plate and skin)? |
The flow of heat energy is analogous to the flow
of electrical energy. Temperature rise is 'Volts'.
Thermal resistance is 'Ohms' and Watts is still
watts. Configuring thermal management for an
LED is identical to that of say a power transistor.
The working part of the LED has a known thermal
resistance between the semiconductor junction
and the heat sinking surface or case. It can
be stated in degrees C per watt. So if you
have a junction dissipating 100 watts of heat
and it's packaged thermal resistance is say
1C/W then the junction is going to operate
at 100C HIGHER than the heat sinking surface.
If the thing is limited to 150C then you have
to maintain the case at 50C.
There will be a thermal resistance associated
with the mounting of the device to the
heat sink . . . add say 0.25C/W. Adding up
the resistances we're at 1.25C/W . . . 100
Watts will drop 125C so now your heatsink
has to operate at 25C.
These resistance numbers are pulled out of
my hat . . . but you get the picture.
Now we get to the proposed 'heat sink'. Just
how good is it. VERY difficult to calculate
if complex like structure of an airplane.
Best way to test it is bolt a power resistor
to the LED mounting surface and cause it
to dissipate X watts. Thermocouple the area
under the resistor to get degrees C/Watt
of thermal resistance.
Now to throw a really big monkey wrench into
the study. AIR FLOW has a PROFOUND influence
on thermal resistance. Those tiny chips in
your computer dissipate a bucket load of heat
in terms of their mass. The heat sink on your
CPU has lots of SURFACE area and a FAN.
The only time your LED nav lights are at
risk for thermal abuse is while sitting
on the ground or taxi. If I were designing
an LED fixture, I'd probably include
over temperature sensing to dim the lighting
to prevent thermal damage. Once airborne,
you'll have plenty of air flow.
I suspect the 'big guys' in aviation lighting
already do this. After all, there are TSO
requirements for thermal robustness that
have to be met and by now, they're very
good at it. If you're looking at a DIY
LED illumination project, start with a study
of how the big guys do it.
When assigned a task for development of
a new product in years past, one of the
first things I would do it search out
the patents on legacy technology. HISTORY
can give you a leg up on avoiding
exercises in re-invention.
Quote: | Am I right in assuming the plate has to be thickest were the LED is mounted and then taper down in thickness as it expands out in width and height? |
No . . . thermal resistance of base material,
surface area and AIRFLOW . . . but without
a doubt, include ELECTRONIC overheat
protection.
Posted: Sun Nov 01, 2020 6:30 am Post subject: DIY LED landing light -- Wing skin as heat sink? |
Quote: | Let's say we use a 100W LED (~13,000 lumens). We'd have to remove 70 to 80W of heat from the LED. |
AND the associated electronics.
See attached:
Description: |
 Download |
Filename: |
Calculate_LED_Efficiency.pdf |
Filesize: |
144.49 KB |
Downloaded: |
190 Time(s) |
