				 Posted: Tue Jan 17, 2006 9:52 pm    Post subject: Monowheel Starter switch |
				We have a ACS ignition switch without a starter contact.
 It seems that a extra hand may be useful when starting a monowheel.
 Anyone come up with placement of starter switch that does not require
 using a hand?
 Thx.
 Ron Parigoris
		pete(at)lawless.info Guest
				 Posted: Wed Jan 18, 2006 4:56 am    Post subject: Monowheel Starter switch |
				Ron
 My mono starts fine with just 2 hands, one to hold the choke out and the
 other to press the starter button.  What is the third hand for?  Or do
 you not have a parking brake?
 Pete
				 Posted: Wed Jan 18, 2006 8:03 am    Post subject: Monowheel Starter switch |
				Thx. for the reply.
 No official parking brake, I was going to try the wedge approach.
 Even with the parking brake applied, I figured it may be useful to have a
 free hand when starting in cold, or with a finikey motor on a hot start,
 to begin cranking with mags off, then turn on either 1 or 2 ignitions to
 help with preventing kickbacks.
 May be a non issue with 914 and HD starter, but figured now is the time to
 scheme?
 Thx.
 Ron Parigoris
 "My mono starts fine with just 2 hands, one to hold the choke out and the
  	  | Quote: | 	 		   other to press the starter button.  What is the third hand for?  Or do
  you not have a parking brake?"
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Wed Jan 18, 2006 8:43 am    Post subject: Monowheel Starter switch |
				Ron,
 Given what I know now, I probably would install a parking brake.  Starting
 the aircraft isn't the only time you need to lock your brakes.
 It's not uncommon to be in a situation where you have to stop where the
 ground isn't level.  For example when I taxi up for fuel at my airport it
 apron isn't level and the aircraft rolls.
 Paul
		n3eu(at)comcast.net Guest
				 Posted: Wed Jan 18, 2006 10:27 am    Post subject: Monowheel Starter switch |
				rparigor(at)suffolk.lib.ny.us wrote:
  	  | Quote: | 	 		   Even with the parking brake applied, I figured it may be useful
  to have a free hand when starting in cold, or with a finikey motor....
 An awful long time ago, cars had a foot switch for the starter.  Wild
 suggestion or not, how you jury-rigged this wouldn't matter, as it would
 be out of sight.  Making your plane virtually theft-proof.
 For 100% theft-proofing, use a reed switch.  Then install one of them
 little, super-powerful neodymium magnets in your shoe.  Perhaps then an
 insurance discount, like with cars today?
 Reg,
 Fred F.
		N914VA(at)starband.net Guest
				 Posted: Wed Jan 18, 2006 11:14 am    Post subject: Monowheel Starter switch |
				Novel idea, just don't wear them on a day when you are flying commercial
 airlines.
 Vaughn T.
		tony.bale(at)virgin.net Guest
				 Posted: Thu Jan 19, 2006 12:37 pm    Post subject: Monowheel Starter switch |
				Ron,
         We have an XS Mono 912S with about 110 hours. We have installed
 individual high quality ignition switches with a micro switch (guarded) on
 the throttle quadrant housing for the starter, this allows one hand to hold
 the choke open and activate the starter. This set up also allows us to
 achieve oil pressure with a higher cranking speed prior to first ignition
 followed by the second (both switches on check is included in the vital
 actions prior to take off) on. One ignition at a time shutdown also helps
 the clutch (he said hopefully). We also have a parking brake
 It works well, and leaves you a spare hand just incase its needed (no idea
 what for mind you) we have found the only two ways to start the engine are
 either when fully hot just a touch of throttle and zero choke, or cold, zero
 throttle full choke and then tickle choke shut with very gentle throttle
 opening once its running, both instances preceded by 3 or 4 seconds of
 electric fuel pump to prime the circuit. So far starting has been reliable,
 including a few very hot and very cold starts.
 Thats our thoughts anyway, hope it helps.
 ATB
 Tony
		william(at)wrmills.plus.c Guest
				 Posted: Thu Jan 19, 2006 10:45 pm    Post subject: Monowheel Starter switch |
				Hi Tony,
 I can't quite work out where the ignition switches are located, where the
 starter button is located (must be somewhere near the choke) and what the
 guarded micro switch is for.  Perhaps you could explain, because the system
 seems quite sprag clutch friendly.
 Best wishes,
 William
