C of G measurements
davidjoyce(at)doctors.org
PostPosted: Sun Oct 18, 2020 3:15 am    Post subject: C of G measurements Reply with quote
Can any of you trike guys let me know the CoG arm measurements of the nose and main wheels on a trigear , please. In case any of you are concerned I am not planning to invest in extra wheels but just doing some calculations for a friend.
Regards, David Joyce, GXSDJ
wdaniell.longport(at)gmai
PostPosted: Sun Oct 18, 2020 4:22 am    Post subject: C of G measurements Reply with quote
Just sent a spreadaheet to youWill
William Daniell
+1 786 878 0246
On Sun, Oct 18, 2020, 07:18 <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
PostPosted: Sun Oct 18, 2020 4:43 am    Post subject: C of G measurements Reply with quote
Many thanks, David
On 2020-10-18 13:21, William Daniell wrote:
Just sent a spreadaheet to you Will William Daniell+1 786 878 0246
JonathanMilbank
PostPosted: Mon Oct 19, 2020 8:36 am    Post subject: Re: C of G measurements Reply with quote
Dear Nev Eyre used to tell me and another Europa owner who also converted his mono to tri-gear, to accept/assume that the arm for both main wheels was 70". However I did very careful measurements and found the arms to be 69.75" for the mains and 14.75" for the nose. These measurements involved levelling the aircraft, using string and plumb bob and very carefully marking the hangar floor, double checked by a friend.
