Posted: Sun Oct 04, 2020 8:47 am Post subject: field current supplied from B lead instead of from main bu |
At 11:11 PM 10/3/2020, you wrote:
| Quote: | --> AeroElectric-List message posted by: "johnbright" <john_s_bright(at)yahoo.com>
Hi Bob,
Someone in my sphere suggested getting field current from the B lead instead of from the main bus.
This way if the B lead shorts to ground and the fuselink opens, the field will be de-energized.
Marked up snip of Z101B attached.
Comments? |
If there is a fault that opens the fusible
link, then the alternator is isolated from
the ship's systems. While the field would
still be energized, the resulting condition
is internal to the alternator and not a
threat to the rest of the airplane.
If the regulator senses bus voltage through
the breaker, then you will depress bus voltage
by whatever drop occurs in the b-lead. Further,
the b-terminal to field breaker lead becomes and extension
of the bus and would need to get a fusible
link at the b-lead.
Presently, I see no particular advantage
for doing this.
johnbright
Joined: 14 Dec 2011 Posts: 166 Location: Newport News, VA
Posted: Sun Oct 04, 2020 10:45 am Post subject: Re: field current supplied from B lead instead of from mai |
link at the b-lead.
for doing this.
Bob . . . |
Thanks Bob.
_________________ John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links |
