erichdtrombley(at)juno.co Guest
Posted: Sat Jul 11, 2020 9:48 am Post subject: Europa MT04 engine mounts |
Hello,
Can anyone tell me what the uncompressed length/height of a new uninstalled MT04 is? I measured the ones I recently removed and they vary considerably and obviously have taken a set. I suspect they are something close to .970” or 24.6mm.
As noted in a previous email, I switched to Lord J3608-1 mounts. I contacted Lord for the recommended preload, however, they indicated there were too many variable to take into consideration. That said, they provided me with a drawing for the 0-200 motor, which isn’t very helpful, I am afraid. Interestingly, I noted two very distinct differences in the Lord mounts as compared to the MT04s. First is the hardness, the Lord mounts are quite a bit softer. And the second, which surprised me, is the uncompressed length/height which I had incorrectly assumed to be the same the MT04. You know what they say when you assume something. Anyway the Lord mounts are shorter, by how much I can’t say at the moment as I require the uncompressed dimension of the MT04. Armed with this information I should be able to trim the space by the delta, which I am hoping will provide the necessary preload.
Kind regards,
Erich
N28ET Classic Monowheel 914
Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more
Roger Stone Commutation Ups Outrage to Fever Pitch
http://thirdpartyoffers.juno.com/TGL3131/5f09faa73d807aa66ef8st04vuc1
COVID Surge Worries Experts: 'Early Wave of a Lot of Suffering'
http://thirdpartyoffers.juno.com/TGL3131/5f09faa71e7917aa66ef8st04vuc2
Amid Spread of Misinformation, Whispers on FB's Next Move
http://thirdpartyoffers.juno.com/TGL3131/5f09faa73db847aa66ef8st04vuc3
Posted: Mon Jul 13, 2020 2:09 pm Post subject: Europa MT04 engine mounts |
Karel,
Thank you for providing the dimensions of the MT04 mounts. This is a big help and I very much appreciated it.
Kind regards,
Erich
N28ET Classic Mono 914
Karel wrote: Erich,The 8 MT04's that I have are between 24.30 mm and 24.90 mm.
Top News - Sponsored By Newser- Search for Naya Rivera Has Come to an End
LA, San Diego Won't Reopen Schools in FallPassengers Help Subdue Threatening Man on Flight
