freddythek10(at)gmail.com Guest
Posted: Wed Jul 08, 2020 8:54 am Post subject: headrest extension |
Will…yes…here are my sketches and a couple of pixs…assembly tested to 10 G’s…let me know if you would like more info…Best, Fred | Quote: | On Jul 8, 2020, at 5:35 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Fred,
didnt you design a headrest "extension" to raise the shoulder height of the harness? I can find the posts but not the the design/pics on the forum. If it was you would you mind sending me some pics and the design
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
395.87 KB |
4053 Time(s) |
364.09 KB |
4053 Time(s) |
397.72 KB |
4053 Time(s) |
 Download |
| Filename: |
Headrest_1.pdf |
379.77 KB |
| Downloaded: |
414 Time(s) |
 Download |
| Filename: |
Headrest_2.pdf |
1.03 MB |
| Downloaded: |
396 Time(s) |
Posted: Wed Jul 08, 2020 7:25 pm Post subject: headrest extension |
By the way , are you flying yet?
(I almost went tje subaru route but chickened out)
Will
William Daniell
+1 786 878 0246
On Wed, Jul 8, 2020, 13:02 Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com)> wrote:
| Quote: | Will…yes…here are my sketches and a couple of pixs…assembly tested to 10 G’s…let me know if you would like more info…Best, Fred
Fred,
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
Posted: Wed Jul 08, 2020 7:27 pm Post subject: headrest extension |
Sorry
Forgot to say...Thank you!!
Will
William Daniell
+1 786 878 0246
On Wed, Jul 8, 2020, 23:22 William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
| Quote: | By the way , are you flying yet?
Will
William Daniell
+1 786 878 0246
Fred,
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
Posted: Wed Jul 08, 2020 7:46 pm Post subject: headrest extension |
Will…I did have my initial flight back on Nov. 1, ’19; however, it was a short one due to engine overheating. I had fallen in love with my tuned exhaust which placed a lengthy serpentine of exhaust pipe under my cowl, and have believed that, even after wrapping all the pipe & muffler w/ heat shield, I was introducing way too much heat under the cowl and was compromising my cooling system.
After a nasty bout with shingles over the winter, I’ve now gone to straight pipes with twin “Swiss Mufflers”…the installation is just now complete. I’m running 50/50 coolant (265 deg. boiling point) and can now get almost 20 min. on the ground before coolant temps reach 210 deg.
At the moment I’m in the midst of retuning the engine, relocating my OAT, and having another go at sealing some gaps around my radiators…feeling a bit frustrated.
Fred | Quote: | On Jul 8, 2020, at 8:22 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
WillWilliam Daniell+1 786 878 0246
| Quote: | Will…yes…here are my sketches and a couple of pixs…assembly tested to 10 G’s…let me know if you would like more info…Best, Fred | Quote: | On Jul 8, 2020, at 5:35 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Fred,
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
