Classic throttle cables
GBWFH2010
PostPosted: Wed Jul 01, 2020 1:04 am    Post subject: Classic throttle cables Reply with quote
I had the misfortune to suffer a throttle cable break last week, fortunately whilst on the ground.
It would seem that Europa only stock one size of cable which are designed
for the XS and these are much longer than the original Classic cables. The problem is not the inner as these can be cut, but the outer which is about
30cm too long. At present my only solution is to use the new inners with the
Old outers, but I just wondered if
anyone with a Classic has encountered this problem and if so how you resolved the situation.
Dave at Europa is investigating as he was unaware the Classic required shorter cables, but this does not help at the moment!
Gordon Grant
G-BWFH
ptag.dev(at)talktalk.net
PostPosted: Wed Jul 01, 2020 3:07 am    Post subject: Classic throttle cables Reply with quote
Hi! Gordon,
I never understood it possible to have a Europa throttle cable too long?
Mine went through the firewall and took a huge loop( almost to the front of
the cowl before returning back to the carbs for easy and free operation for
alignment to the carbs point of entry.( no clips or tie wraps needed)
Bob Harrison EX G-PTAG.
peterz(at)zutrasoft.com
PostPosted: Wed Jul 01, 2020 4:00 am    Post subject: Classic throttle cables Reply with quote
Solid core (yes i did, also on the ground, and the friction did not allow the throttle to go full open)? Or original stranded?
I have reverted to teflon coated stranded inners (bicycle brake cable core), and find it is now very smooth and free.
Pete
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497111#497111
GBWFH2010
PostPosted: Thu Jul 02, 2020 12:13 am    Post subject: Re: Classic throttle cables Reply with quote
Thanks Bob. Do you have a picture of your engine compartment showing
How your cables were routed?
Gordon
Gordon Grant
G-BWFH
PostPosted: Thu Jul 02, 2020 3:40 am    Post subject: Classic throttle cables Reply with quote
Hi!Gordon,
No I don't have any pics or the plane any longer but I recall the cables
went forward from the standard quadrant box on the XS cockpit module through
the firewall and curved gently upwards to lay on the top of the engine,
forwards and then aligned backwards to the carb connections. They appeared
ridiculously long but no sharp or forced bends and no ties gave a completely
free movement. Once positioned they stayed throttle set by the friction
clamped on the actual throttle lever. But as you said they need to fail in
full throttle mode.
I also only oiled the actuating ends ......none down the cable length
.....it only makes drag and collects dust. Mine were bicycle multistrand
cables , not the solid single wire type.
Hope this helps.
Bob Harrison Ex G-PTAG.
GBWFH2010
PostPosted: Thu Jul 02, 2020 3:49 am    Post subject: Re: Classic throttle cables Reply with quote
Thanks Bob, that is really useful.
Gordon
Gordon Grant
G-BWFH
wdaniell.longport(at)gmai
PostPosted: Thu Jul 02, 2020 5:23 am    Post subject: Classic throttle cables Reply with quote
while we're on the topic, what is the recommended cable lubricant for South Florida conditions?
thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
On Thu, Jul 2, 2020 at 7:51 AM GBWFH2010 <gaxuk2001(at)gmail.com (gaxuk2001(at)gmail.com)> wrote:
--> Europa-List message posted by: "GBWFH2010" <gaxuk2001(at)gmail.com (gaxuk2001(at)gmail.com)>
Gordon
Gordon Grant
G-BWFH
http://forums.matronics.com/viewtopic.php?p=497138#497138
John Wighton
PostPosted: Thu Jul 02, 2020 10:50 pm    Post subject: Re: Classic throttle cables Reply with quote
Factor 40.
Do not archive.
Laughing
John Wighton
Europa XS trigear G-IPOD
n7188u
PostPosted: Sat Jul 25, 2020 4:43 pm    Post subject: Re: Classic throttle cables Reply with quote
William,
I always used tri-flow for lubricating hinges and control cables with good results.
In many aircraft the recommendation is not to use lubricants except for silicone based dry sprays to prevent accumulation of dirt (its an AD in the Mooneys) but in fiorida you have to use something that protects metal so i found tri-flow to be a good compromise.
Chris
PostPosted: Sun Jul 26, 2020 6:06 am    Post subject: Classic throttle cables Reply with quote
Thanks chris
William Daniell
+1 786 878 0246
On Sat, Jul 25, 2020, 20:48 n7188u <chmgarb(at)gmail.com (chmgarb(at)gmail.com)> wrote:
--> Europa-List message posted by: "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)>
William,
Chris
http://forums.matronics.com/viewtopic.php?p=497411#497411
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
spcialeffects
PostPosted: Mon Jul 27, 2020 3:46 am    Post subject: Re: Classic throttle cables Reply with quote
Hey Gordon.
Just cut the new cables to suit! That’s what I did on my classic with XS FWF (both throttle and choke) and have had no trouble at all.
Frank X
