Unimproved field flying with the Europa
jonthayer(at)sbcglobal.ne
PostPosted: Wed Jun 10, 2020 3:14 am    Post subject: Unimproved field flying with the Europa Reply with quote
Just curious to get some real data on unimproved field access and flying in the Europa. How well does the Tri-gear handle the landings and takeoffs. I've been told the mono is the way to go, but can be a bit finicky during landing and takeoffs on hard pavement not to mention the real world double insurance costs... Thanks for the responses.
Jon
SteveIvell(at)pestproof.c
PostPosted: Wed Jun 10, 2020 7:38 am    Post subject: Unimproved field flying with the Europa Reply with quote
Hi Jon
Those with a mono will tell you they are great (and I know they are a bit faster) but to my mind they are the worst of all types. Not a taildragger and not the equivalent to a glider because there is a big prop at the front waiting to be pranged. I have flown in one as a passenger and the little outrigger wheels make a racket on hard surfaces when taxying.
My old instructor always responded when he was asked about taildragger versus nosewheel…….”how many modern aircraft don’t have nosewheel configuration”? I’m sure you can answer that for yourself.
I’ll now prepare to be shot down in flames by the mono lovers!! Lol
Kind Regards
Steve Ivell
E-mail: steveivell(at)pestproof.co.uk (steveivell(at)pestproof.co.uk)
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Jon Thayer
Sent: 10 June 2020 12:12
Subject: Europa-List: Unimproved field flying with the Europa
Jon
Burrilla
PostPosted: Wed Jun 10, 2020 8:01 am    Post subject: Unimproved field flying with the Europa Reply with quote
I fly a tri-gear from a 500 m grass strip, not the smoothest, and it handles well.
There are those who prefer the Mono, and those the Tri-gear.
Alan Burrill
G-OBJT
Sent from my iPad
On 10 Jun 2020, at 16:41, Steve Ivell <SteveIvell(at)pestproof.co.uk> wrote:
 <![endif]--> <![endif]-->
Hi Jon
Kind Regards
Steve Ivell
Subject: Unimproved field flying with the Europa
Jon
Europa48
PostPosted: Wed Jun 10, 2020 8:14 am    Post subject: Re: Unimproved field flying with the Europa Reply with quote
Jon
Certainly a mono will handle rough fields better than a trigear. Like any aircraft whether mono or trigear every aircraft rehires correct handling otherwise it will bite you. The Cessna "Landamatic" that was advertised in the fifties was just an adpersons slogan.
I pay around ÂŁ740 for my insurance with a hull value of ÂŁ50,000 which I think is fair and not loaded because of the configuration. My three previous trigears were all around the same cost to insure.
Europa48
PostPosted: Wed Jun 10, 2020 8:18 am    Post subject: Re: Unimproved field flying with the Europa Reply with quote
[quote="SteveIvell(at)pestproof.c"]Hi Jon
ďż˝
ďż˝
ďż˝
ďż˝
Kind Regards
Steve, why do you find it necessary to knock the mono aircraft? It would be just as easy to say the same about the trigear variety. Each to their own and leave it at that. There has been too much negative drivel directed at the mono most of it unfounded by folk who haven't even flown one.
Your pestproof email address could do with shortening I think!!
Very Happy
peterz(at)zutrasoft.com
PostPosted: Wed Jun 10, 2020 8:19 am    Post subject: Unimproved field flying with the Europa Reply with quote
Fwiw, the air-tired roller blade wheels make the outriggers almost silent (and likely reduce wear on the pivots etc).
Planes are made to fly, not drive around lol. Just fly it on the ground as well as in the air and all is well. I prefer to extend my flying time, not minimize it lol. Besides, it’s just way more fun.
Cheers,
Pete
On Jun 10, 2020, at 11:47 AM, Steve Ivell <SteveIvell(at)pestproof.co.uk> wrote:
Hi Jon
Kind Regards
Steve Ivell
Jon
PostPosted: Wed Jun 10, 2020 2:32 pm    Post subject: Unimproved field flying with the Europa Reply with quote
Hi Pete
The roller blade wheels look like a real improvement and I agree that planes are for flying  but some airfields have tarmac and concrete taxiway’s.
Kind Regards
Steve Ivell
Mob: 07971 128842
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Pete
Sent: 10 June 2020 17:17
Subject: Re: Europa-List: Unimproved field flying with the Europa
Cheers,
Pete
On Jun 10, 2020, at 11:47 AM, Steve Ivell <SteveIvell(at)pestproof.co.uk (SteveIvell(at)pestproof.co.uk)> wrote:
Hi Jon
Kind Regards
Steve Ivell
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> On Behalf Of Jon Thayer
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Jon
PostPosted: Wed Jun 10, 2020 3:52 pm    Post subject: Unimproved field flying with the Europa Reply with quote
That's all I generally fly off of and luv it Smile The Europa is a packaging
efficiency masterpiece designed around that big fat sprung tire. It's like
landing on a pillow. There are many other purpose-built trigear designs.
On Wed, Jun 10, 2020, 6:48 PM Steve Ivell, <SteveIvell(at)pestproof.co.uk>
wrote:
[quote] Hi Pete
taxiway’s.
Kind Regards
Steve Ivell
Mob: 07971 128842
owner-europa-list-server(at)matronics.com> *On Behalf Of *Pete
*Sent:* 10 June 2020 17:17
*To:* europa-list(at)matronics.com
*Subject:* Re: Unimproved field flying with the Europa
Cheers,
Pete
wrote:
Hi Jon
clivesutton
PostPosted: Wed Jun 10, 2020 11:40 pm    Post subject: Re: Unimproved field flying with the Europa Reply with quote
On the Tri vs Mono point generally, i've owned a Tri and now a Mono and having flown both have found the Tri to be a bit more versatile vs RWY surface (the Mono laps up grass). Potentially the Tri can be at bit heavier wrt TO length (though honestly there is such a wide variation in empty weights, that comment is perhaps academic).
I too have found insurance to be very similar for the two types - so i consider that a non-issue.
But sadly, [my opinion] the perceived issues with Mono handling can and seemingly do impact its resale value. Again, my view - that said, anything less than ÂŁ27k GBP in flying condition is probably a real bargain.
For the recently joined/enquirers on this site; it is entirely possible to convert a Mono to a TriGear (with a 30lb weight penalty/~ÂŁ5k parts cost). John Wighton is also working on offering both the parts and i believe the installation service, to convert (presumably either type) to a conventional Taildragger that uses spring-steel legs. His contact email is:
Mods(at)theeuropaclub.org
