Posted: Sat Jun 06, 2020 6:55 am Post subject: Physical construction of Z101 engine bus & battery bus |
At 08:50 AM 6/6/2020, you wrote:
| Quote: | | Could someone please re-post the link to Z101? Thanks. |
https://tinyurl.com/yc4r5huy
Latest iteration on the next revision level.
I've been sifting through the details and
I think it's 99% 'clean'.
I'm also working on a set of notes that
elaborates on the evolution of concepts
illustrated.
I'm kinda 'distracted' with a bathroom
remodel at the moment but you guys can
massage this thread . . .
Posted: Sun Jun 07, 2020 12:28 pm Post subject: Physical construction of Z101 engine bus & battery bus |
At 11:32 AM 6/7/2020, you wrote:
| Quote: | | Bob, regarding Z101, it seems that auto conversions like the Honda based Viking and Suzuki based Aeromomentum are becoming more and more popular. These engines are electrically dependent, but they do not lend themselves to a dual alternator setup. I wonder if you would consider developing a Z101-B that utilized dual batteries rather than dual alternators? |
Is it not possible/practical to maintain one battery
such that it is capable of supporting the engine
in an alternator-out scenario?
How are the duties of two batteries allocated in what
I presume is a engine manufacturer's recommendation
for dual batteries?
Posted: Sun Jun 07, 2020 6:51 pm Post subject: Physical construction of Z101 engine bus & battery bus |
At 05:26 PM 6/7/2020, you wrote:
| Quote: | I am not speaking to any engine manufacturers recommendation (although the
Honda Viking manufacturer does recommend two batteries. I just thought
I was applying logic -- if dual alternator + battery (triple power source)
is desirable for electrically dependent engines, wouldn't that reasoning
imply that if the second alternator is not practical, a second battery
could be used as the third power source? I could ask you a similar question:
Are not two independent power sources (battery and alternator) sufficient
to meet the needs of the electrically dependent engine. Obviously you
saw value in adding the second alternator. Why no value in adding the second battery? |
Excellent question.
It's a problem in energy budgets combined with
efforts to assure continued airworthiness.
The airplane cannot do without a battery if
you're going to have a starter. Depending on
your planned mission profiles, you will want
to size the battery (1) for cranking then
(2) minimum endurance in alternator-out modes.
This study gave impetus for the creation of
the endurance bus . . . a fast and predictable
way to economically tap known quantity of energy
stored in the battery's chemistry.
Z13/8 was a small but significant amplification
of that idea . . . <b>the second alternator's endurance
had no practical limits.</b> Hence, energy on the chemistry
just might be held completely in reserve for
descent and approach to landing.
Z13/20 (and the aux alternator option on
Z101) expanded the Z13/8 endurance opportunity
by a factor of 2.5 or better.
Okay, suppose the drive pad isn't available.
We are still charged with identifying and the
delivering to energy required to comfortably
terminate a worst-case mission.
This means that as a part of routine maintenance
the ship's chemistry needs to be monitored for
capability. We could certainly store that energy
on TWO devices but to what advantage? If we're laboring
under the notion that a battery can suddenly become
unavailable during one tank of gas, then we have
to assume that EITHER battery can roll over and
die . . . okay, how would that failure be
annunciated . . . how would remaining energy be
managed . . . ?
I think that's the scenario anticipated by the
folks that crafted that battery manager with a
full-wave rectifier that -anded- two, completely
isolated batteries together. Assume the alternator
has quit and some time later one battery
craps out. How does the pilot become aware of the
problem and what kind of energy juggling issues
are presented when the available energy drops
to half? This assuming he really knows that the
two batteries were performing equally and has
recently quantified their condition, he now
has to come up with a new "plan C?" and perhaps
declare an emergency.
This scenario first assumes TWO critical failures
during the consumption of one tank of fuel . . .
about 3-4 hour window. Part 23 certs don't
get concerned with dual failures at all.
Part 25 and heavier will wade into the reliability
quagmire with mountains of computer generated probability
studies that get 'worked' on until somebody
finally sprinkles the holy water and off they
go.
Ask Capt. Sullivan what he thinks about
reliability studies . . .
https://www.youtube.com/watch?v=HKJ1lIh2Cgk
So we're left to our own devices which in reality
are not so bad.
The short answer is: A diligently maintained
battery is the most reliable source of energy
on the airplane. Replacing it when ability
to store energy drops below some benchmark
(generally 75 to 80% of new) means that it
always cranks the engine and will provide a
quantified option for dealing with alternator
failure. Two batteries just doubles your
preventative maintenance labor. Further,
you need to decide if plan-b can reliably
depend on the sum total of energy in two
batteries . . . or will they be sized to
independently step up to the task? The
second option calls for 2X the battery
weight and volume; the first option complicates
calculations and switching operations for
carrying out a plan-b that shouldn't ever
happen. BOTH options still demand good
preventative maintenance.
Just as you KNOW fuel aboard when you launch,
you also need to know Watt-Hours aboard
no matter how many batteries you're carrying.
If you have TWO properly maintained batteries,
in all likelihood, you'll be carrying around
$twice$ the hardware with virtually no value
added to the ship's overall reliability.
Posted: Mon Jun 08, 2020 7:21 am Post subject: Physical construction of Z101 engine bus & battery bus |
At 09:20 PM 6/7/2020, you wrote:
| Quote: | | SDSEFI recommends 2 alternators and a battery. If you have a single battery and alternator they recommend an additional battery that is only connected to the ENG BUS for an emergency. The recommended procedure is to charge that battery on the 1st of the month and load test yearly. |
Not a particularly definitive battery management
philosophy. "Charging once a month" whether needed
or not? "Load test" is not specific . . . what kind
of load and for discovery of what condition? Internal
impedance (cranking) or capacity (endurance)?
How would that knowledge augment the pilot's
prospects for dealing competently with an alternator
failure?
How would these batteries be selected and configured
in the architecture? What would the plan-b checklist
look like? Recall that the ultimate goal for crafting
a failure tolerant architecture is to prevent any
single failure from becoming an emergency.
That goal cannot be realized without first knowing the
ENERGY requirements for the TOTAL constellation
of hardware necessary to conduct a comfortable termination
of flight within some ENDURANCE value determined by
the BUILDER . . . not by some 'authority from afar'
who will never ride in the airplane.
