Posted: Mon May 25, 2020 6:39 am Post subject: Shunt Questions |
At 07:25 PM 5/24/2020, you wrote:
| Quote: | Bob, I hope you and yours are well!
I have a question on shunts, but for my camper, not an aircraft. I thought maybe you prefer I don't clutter up the AeroElectric list with non-aircraft topics! (But tell me if you'd rather I send this to the list.) |
Not that far off-topic. No doubt there
are other List members with at least
an academic if not practical interest
in DIY data acquisition. A pretty smart
cookie once opined:
"I often say that when you can measure what you
are speaking about, and express it in numbers,
you know something about it; but when you cannot
measure it, when you cannot express it in numbers,
your knowledge is of a meagre and unsatisfactory kind.”
-- Lord Kelvin
| Quote: | I would like to build some data logging for the DC system in my VW camper.
https://sbw.org/sbwsty/
There's a photo of my van's (messy) wiring closet here:
https://sbw.org/westybattery/
I have two lead-acid batteries, starting and house. Right now, just two charging sources, the alternator and a ProSport marine charger. Thinking of adding solar.
I'd like to monitor several current flows:
- From the alternator to the house battery.
- From the ProSport to the house battery.
- From the house battery to the appliances.
- In future, from the solar charge controller to the house battery.
I don't NEED all of those, of course. Just curious. So I'll need several shunts. B&C offers only one, 50mv at 20A, if I understand. So 2.5 milliohms?
I think a different shunt might be better, because I'm planning to use this breakout board:
https://www.adafruit.com/product/904
It comes with a 100 milliohm shunt (a 1% resistor), intended to measure up to 3.2A at the INA219B chip's max differential 320mv. The resolution at 3.2A is .8mA. I would put a shunt in parallel to measure a higher current, ideally one that produces close to 320mv for good resolution.
For example, the if the alternator can produce 60A, would I maybe choose this 20A/100mv shunt (5 milliohms), which would produce 300mv at 60A?
https://www.newark.com/canadian-shunt/la-20-100/shunt/dp/73K4805
Is it silly to give up 300mv just to get higher resolution?
Will it get too hot, dissipating 18W vs. the 2W it's rated for?
B&C sells their shunt for $5, where the shunts from Newark are much more spendy. Is there somewhere better to buy them?
Is there a simpler way to do this?
Another interesting part of the project will be how to get the data up to the cloud: I'm thinking WiFi when it's available and APRS otherwise. And maybe BLE to an app on my phone. Adafruit has lots of radios I can experiment with.
But first I need to gather the data.
Thanks! |
I have all but abandoned metallic shunts for current
measurement - especially when the millivolt data
is to processed in low level digital electronics.
We can revisit your shunt questions but I'll
suggest you consider this product:
https://tinyurl.com/yaxv58ax
These are closed loop, hall-effect sensors priced
about the same as the metallic shunts. Beauty
of these critters is total isolation, very
good linearity, repeatability and accuracy.
Best yet, one device can measure a huge
range of currents.
I stock the 6A version for about all applications.
I can run 5 passes of 22AWG wire through the
aperture and get plus/minus 1.2A full scale.
Alternatively, a single pass of 22AWG 1 foot
long through the aperture spliced in parallel
with 10AWG 1 foot long outside the aperture
gives me approx 10x multiplier for plus/minus
60A full scale.
You can situate the sensor local to the stimulus
of interest and extend the leads on a shielded,
twisted pair for direct interface with your
a/d converter. You don't need those high common
mode gain chips to do achieve an interface.
You WILL need some a/d ports to process your
hall sensor data.
I've acquired high quality data at the ends
of 40' leads in all manner of noisy environments.
The attached photo is one example of one
application. This board includes a 5v, 3-terminal
regulator enabling me to use the device
'barefoot' with a digital VOM at the observation-
end of the leads. For applications such as yours,
I'd probably solder a shielded pair directly to
the module pins and 'pot' the connections with
E-6000.
If you'd like some boards to mount and terminate
the wires in a connector, I think I've got a
few laying around. Also, if you'd like to
go for the metalic shunts, I think I've
got a few dozen 20A shunts available for the
asking . . . but you don't want to overload
these things by much . . . maybe 50%. They're
easy to 'smoke'.
LONG time no hear my friend! Pleased to know
that you're still alive, kicking and curious!
648.91 KB |
3053 Time(s) |
Eric Page
Posted: Mon May 25, 2020 10:44 am Post subject: Shunt Questions |
Gents,
Another good option is Allegro MicroSystems' line of Hall effect sensors. You can get them from all of the usual suspects on eBay, Amazon, AliExpress, etc., mounted on a small PCB. You just feed your current of interest through the screw terminals, connect the output to an ADC input on your micro and scale the reading in your code. They work well, are very small, generate virtually no heat and cost very little.
The unidirectional sensors output 0V with no current flow, while the bidirectional sensors output half the supply voltage with no current flow (5V supply = 2.5V no-current output; current in one direction produces output >2.5V and current in the other direction produces output <2.5V).
A couple of caveats. 1. Avoid laying another current-carrying wire over the surface of the sensor IC, as it can disturb the Hall sensor inside. 2. The zero-current output of the bidirectional ICs is ratiometric with the supply voltage, so be sure your sensor supply is the same as your ADC reference.
Search links for sensor modules on eBay:
-- ACS712 (5A, 20A and 30A sensors): https://preview.tinyurl.com/ybc556k5
-- ACS724 (40A and 50A sensors): https://preview.tinyurl.com/y9xfbehu
-- ACS758 (50A and 100A sensors): https://preview.tinyurl.com/ybqcwoqt
Sensor IC datasheets:
-- ACS712: https://preview.tinyurl.com/ybbckmf5
-- ACS724: https://preview.tinyurl.com/yafr2oms
--ACS758: https://preview.tinyurl.com/yxoukcv4
Eric
| Quote: | I'd like to monitor several current flows:
Posted: Mon May 25, 2020 2:06 pm Post subject: Shunt Questions |
At 01:40 PM 5/25/2020, you wrote:
| Quote: | Gents,
I've used these with success. They are
not quite so 'tight' for accuracy, etc. but
if your error budget will tolerate them, they
perform as advertised.
sbw(at)sbw.org Guest
Posted: Tue May 26, 2020 9:40 am Post subject: Shunt Questions |
Bob and Eric, thanks for pointing out a much more elegant solution than
a shunt farm!
Bob, I re-read the section of Chapter 7 on Hall effect sensors. I'm
sure I read it around 30 years ago, but I had forgotten.
One way this is more elegant is that it can be inserted into the ground
path without disrupting the ground, which makes the physical wiring
safer. (The shunt and fuse block in my van's wiring closet are a bit
vulnerable right now.)
The microcontrollers I'm planning to use have lots of A/D pins, so
that's not a problem. They're Arduino compatible, but at 3.3V, so I
wonder whether the LTS 6-NP must have a 5V supply voltage? If so,
that'll factor in to the multiplier produced by the parallel wires, to
make full scale no more than 3.3V.
I skimmed the data sheet on the LTS 6-NP. I'll have to read it more
closely before I'll be able to put it to use! I believe I understand
how the six primary leads are configured to the application, but not so
much passing a conductor (or turns!) through the aperture.
Other than your clever 10X scaling, how does one choose between a
conductor through the aperture vs. the primary leads?
And I'll want to understand more about the physical considerations: Does
this device require some minimum clearance from other wiring/components?
I assume you specify a 1 foot length for each of the parallel 22AWG and
10AWG wires because 10AWG has a cross section about 9X 22AWG? Why 1
foot? What about just a shorter length of each, from one side of the
sensor to the other? (I'm picturing a printed circuit board with the 22
AWG soldered near Fast-Ons or threaded studs to attach the 10AWG and the
wires to ground and load/battery. Or, heck, just a bolt through to the
chassis, like the ground block.)
I wonder whether one could achieve the same multiplier (and current
capacity) using a shorter wire through the aperture together with a
generous area of printed circuit foil to carry the other 90% of the
current? (I've never learned anything about the current capacity of
printed circuit foil or how to predict its resistance.) Could that
assembly be calibrated somehow? Would it be stable?
Thanks, as always, for being so generous with your time!
On 5/25/2020 7:38 AM, Robert L. Nuckolls, III wrote:
| Quote: | I have all but abandoned metallic shunts for current
range of currents.
60A full scale.
hall sensor data.
E-6000.
easy to 'smoke'.
