OV push to test button, is there a hack for SB1B
johnbright
PostPosted: Tue May 05, 2020 5:06 pm    Post subject: OV push to test button, is there a hack for SB1B Reply with quote
Hi Bob,
Seems like a nice feature that SB1B has an annunciatior light that it has come online but unlike LR3C there is not an OV PTT... is there a way to hack into SB1B for an OV PTT button?
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
kenryan
PostPosted: Wed May 06, 2020 2:06 pm    Post subject: OV push to test button, is there a hack for SB1B Reply with quote
Bob, you say "they worked good and lasted a long time." What was the eventual failure mode? How did one know when they did fail?
On Wed, May 6, 2020 at 12:42 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  If you never tested the thing, you risk for
  failure to perform is exceedingly low.
  A follow up:  I've worked on dozens of
  TC aircraft. I forget how many products
  I've designed and qualified into OV
  management systems. Not one has ever
  included or required a press-to-test
  feature.
  The very first OV management module I designed
  went into the single engine Cessnas back
  in the 70's. This was a three-wire potted
  assembly that was ultimately manufactured
  by the tens of thousands. Worked good, lasted
  a long time.
