cofford
Joined: 01 Jan 2018 Posts: 9 Location: Puget Sound, WA
Posted: Fri Feb 14, 2020 10:49 am Post subject: Always hot power for fuel injectors and ignition coils |
Hi everyone,
I'm currently planning the electrical architecture for my RV-8 with EFII and I've been following the recent discussions of fuel injector power with great interest. Does anyone connect the positive side of the injectors and coils to the always-hot battery bus and leave them powered all the time, or are they generally always switched?
I'm leaning towards a dual-feed "engine bus" with diode-protected feeds from the main contactor and a relay on an aux battery, but leaving the injectors and coils "always hot" gives a few more options. I'll post a schematic when I get done drawing it.
Casey
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Mon Feb 17, 2020 6:38 am Post subject: Always hot power for fuel injectors and ignition coils |
Not a minority of two either.
Bob Reed
| Quote: | On Feb 17, 2020, at 8:11 AM, user9253 <fransew(at)gmail.com> wrote:
Charlie, you are not a minority of one. I am on your side. The master switch
should shut off all electrical power except to the engine. The engine bus
should be supplied by two current paths. The pilot should have the ability to
shut off all sources of electrical power as close to the sources as possible.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=494858#494858
foghorn757(at)gmail.com Guest
Posted: Mon Feb 17, 2020 8:06 am Post subject: Always hot power for fuel injectors and ignition coils |
I’m on board with this philosophy too.
Jeff Parker
| Quote: | On Feb 17, 2020, at 09:43, Robert Reed <robertr237(at)att.net> wrote:
Bob Reed
> Joe Gores
