Kolb Firefly/Firestar fuselage questions
jaydub
PostPosted: Wed Jan 29, 2020 6:24 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
I posted the following at HBA but thought I'd ask here too because of the specialized nature of this list.
I've read the history of Kolb pdf and gathered some info but there are some blurry parts in my mind.
I know the Firestar started out as a UL with a 277. Then they made them heavier with a 447 and 503 in the "fat ultralight" years. Then they differentiated between Firestar 1 & 2. Then, to make a legal UL Kolb did something to lighten them again and made the Firefly model to hit legal weight with a 447.
Does anyone know if the early Firestar fuselages (and even later ones) are the same dimensions and tubing thicknesses as the Firefly? IIRC I read somewhere the weight was reduced in the wings for the Firefly but that might not be true so I'm seeking advice.
What brings about all my strange questions is that I have a lead on everything for an earlier Firestar with everything included but the fuselage. Without a fuselage and serial number I can't determine much as the current owner is at least the 2nd or 3rd owner or even later. I'm wondering if the wing has the same chord between the Firefly/star models or not and would it connect up just fine? In other words, can Firestar wings, tailboom, tail, etc fit on a Firefly fuselage or do I have to stick with the Firestar fuselage? I want to keep it light and under 254 lbs if possible. It comes with a 447 so it's possible it could already be a Firefly but how would I be able to tell? Is the tailboom a different dia or thickness on the Firestar 2? I'm just trying to figure out which of the Firestary/Firefly fuselages would work with the parts I may pick up.
And lastly, does anyone have or know of someone who has a fuselage with landing gear they'd like to part with that will fit the Firestar wings and tail? I have experience cutting out bent tubes and welding in new ones on certificated and homebuilt planes so a wrecked/bent fuselage is OK as I can repair one as long as it's not rusted badly. If you know of one please contact me as I'm interested.
Jay Dub
Richard Pike
PostPosted: Thu Jan 30, 2020 6:15 am    Post subject: Re: Kolb Firefly/Firestar fuselage questions Reply with quote
Don't know if I can answer all your questions, but I can answer some. Back in 2017 I bought a wrecked original Firestar, 1985 vintage, 5 rib wings. Wings and tail and boom tube undamaged, fuselage was totaled.
Herb of this list gave me an upper fuselage tube and a front end off a Firefly. The Firestar wings mated perfectly to the Firefly upper fuselage. The original Firestar wings are longer than the Firefly wings, so probably a bit heavier.
Simuntaneously with this I also had a FSII that had been dismantled and was being sold. The original Firestar had Kolb's original tail folding mechanism, which was cumbersome to say the least. The FSII had the current quick fold mechanism. Did a lot of measuring and could not find any difference between the two, so swapped them out.
Went to the Kolb factory and took lots of pictures of Firefly fuselages and rebuilt our Firestar cage to conform to the current Firefly setup.
Short version; with bicycle disc brakes, a 9 pound hand deployed parachute, and a Rotax 277, it does make legal weight. And flies very well.
https://www.youtube.com/watch?v=aAcfoOJJDpg
https://www.youtube.com/watch?v=ulIJ_WHLMfY
Here is a good resource: http://harnerfarm.net/serenity/serenity.html
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Pfatchantz(at)protonmail.
PostPosted: Thu Jan 30, 2020 6:54 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
Richard,
Good to see that you turned that wrecked fuselage into a nice looking Firefly...I rebuilt the wings that you gave me and they are sitting the barn along with tail feathers and tail boom tube .
I can see that you like a little extra dihedral..Smile
The story that developed around the rebuilding of that firefly is sad.
I met a fellow from Southern Va. at the Kolb Factory , for he was buying a new cage for his Firefly...so he brought his bent cage and sold it to me..Needed very little repair..taxiing accident..
He discussed the desire for flight training which I tried to reinforce...Said he was going to Fla and would check there...Some time later and back in Va...He took off on his maiden flight never to return...likely stalled in...around Staunton as I recall?
By the way...I need some photo's of the 750 Brs canister install on a Firestar II...I took it off of mine and now have a jumble cords from several BRS models and the manual seems to be a bit short of diagrams or pics of the install.. so do not know which is which..
by the way..I have BRS 950 for sale..needs rocket and repack...came off of a challenger..I hear that unit needs factory repack using a hydraulic press..?? Herb
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Thursday, January 30, 2020 8:15 AM, Richard Pike <thegreybaron(at)charter.net> wrote:
Herb of this list gave me an upper fuselage tube and a front end off a Firefly. The Firestar wings mated perfectly to the Firestar upper fuselage. The original Firestar wings are longer than the Firefly wings, so probably a bit heavier.
Richard Pike
Kolb Firefly Part 103 legal
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=494525#494525
zeprep251(at)aol.com
PostPosted: Thu Jan 30, 2020 9:56 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
Fire star 1and2 are physicaly similar more ribs in the 2 but firefly is all by itself,dimensional and tubing size
Jay Dub
http://forums.matronics.com/viewtopic.php?p=494521#494521
jaydub
PostPosted: Thu Jan 30, 2020 10:08 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
Hi All,
Thanks for the info.  Good to know the Firefly is it’s own design with different dimensions and different tubing sizes.
I talked with the 2nd owner yesterday and found out the wings are the larger spar and 7 rib design like from a Firestar.  That means I’ll have to LSA whatever I do with the wings and all the other parts.  If I have to LSA maybe I’ll try to do a F2.  Which that thought leads me to another question, would a Firestar 2SS fuselage be possible with the 7 rib wings and tail from a Firstar since I’m going to have to get a fuselage no matter what?
Jay
Sent from Mail for Windows 10
Sent: Thursday, January 30, 2020 10:59 AM
Subject: Re: Kolb Firefly/Firestar fuselage questions
--> Kolb-List message posted by: Gary Aman <zeprep251(at)aol.com>
--> Kolb-List message posted by: "jaydub" <bearhawk(at)gmx.com>
Jay Dub
      (And Get Some AWESOME FREE Gifts!)
Richard Pike
PostPosted: Fri Jan 31, 2020 9:18 am    Post subject: Re: Kolb Firefly/Firestar fuselage questions Reply with quote
List please correct me if I am wrong, but best I know, the MKIII, Kolbra & Slingshot have 6" spars and boom tubes, everything else has a 5" spar and boom tube.
Richard Pike
Kingsport, TN 3TN0
gdhelton(at)gmail.com
PostPosted: Fri Jan 31, 2020 9:37 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
Yup, I believe you are correct.
On Jan 31, 2020, at 12:23 PM, Richard Pike <thegreybaron(at)charter.net> wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=494543#494543
byoungplumbing(at)gmail.c
PostPosted: Fri Jan 31, 2020 9:40 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
 Richard,,,As as far as I know that is exactly correct!
Boyd Young mkiii Utah
Do not archive!
PostPosted: Fri Jan 31, 2020 10:03 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
us,firefly,firestar,MkII all use the same rib also..  the Kolbra,MkIII and slingshot use the same rib also..Herb
by the way,I have a nice set of spars for the Firefly..ready to go...but do have the rivet holes for the ribs...I converted a Firefly to use the Firestar single lift strut...and used the ribs for those..
On Friday, January 31, 2020 11:38 AM, B Young <byoungplumbing(at)gmail.com> wrote:
Do not archive!
twoflyboys(at)aol.com
PostPosted: Fri Jan 31, 2020 10:13 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
The booms are the same thickness the fire fly boom is a foot shorter the cord of the wings are the same but the fire fly wing is 3 feet shorter each , the aileron and flap system are different , the tubing on the fire fly fuselage are smaller in diameter
Sal
Jay Dub
jaydub
PostPosted: Fri Jan 31, 2020 10:49 am    Post subject: Kolb Firefly/Firestar fuselage questions Reply with quote
This is all good information that I couldn’t find in any one place.  It’s quite helpful so thank you to everyone who replied.  It’s going to be a couple of weeks yet before I can go pick up the pile of parts (everything but a fuselage/cage).  I’ll know better when I get everything home and can measure things and verify what I have. Neither the current owner nor the previous owner to him know exactly which model of Firestar the parts came from.  With the 7 rib wings I would assume (from reading the history of Kolb) it was at least a KXP, FS1 or FS2 but that’s assuming things.  Since it has a 447 I would be guessing it might be a bit older because most folks went with a 503 with the heavier wings and most wouldn’t use a 447 with an FS2 I wouldn’t think if they had 2 people aboard.
If I’m understanding correctly (tell me if this is flawed) using the 7 rib wings, tail, boom, etc from the Firestar that I’ll be picking up, it sounds like I have many options for which fuselage I can use.  It sounds like I might be able to use a fuselage from a:
Firefly (although it will have lighter/smaller 4130 tubes and not meet 254lbs because of the heavier wings) but both the strut and wing attach points might be weaker due to it’s designed for shorter wings with less lift but this is an assumption on my part,
Firestar (Original, KX, KXP, FS1 or FS2 and possibly FS2SS),
Twinstar Mk2,
With the assumption (which is dangerous to assume) if these models all use the 5” wing spars, same chord wing, and 5” boom tube with tail feathers.  Is that correct?  If so those are great options.
Bottom line: I will end up with whatever model according to what fuselage I can find for a reasonable price.  I see from the Kolbaircraft website that I can buy new Firefly or Firestar fuselages but the price is a bit higher than I can afford right now.
Jay in Wyoming
Sent: Friday, January 31, 2020 11:07 AM
Subject: Re: Re: Kolb Firefly/Firestar fuselage questions
Do not archive!
