Posted: Tue Jan 28, 2020 7:38 am Post subject: This doesn't seem right, but what do I know |
<snip>
| Quote: | These periods of flow to/from the battery are short
in duration normally lasting only a few seconds.
Is this normal and to be expected, or does it
suggest a problem with the internally regulated
alternator, or perhaps with the current sensor itself?
Any insight explaining what I am seeing will be appreciated. |
The battery's physics reacts to BUS VOLTAGE.
Any period battery energy outflow MUST be
paired with a drop in bus voltage to something
below the battery's present open-circuit
voltage.
The voltage doesn't have to drop to
the battery's natural delivery
level (~12.5 volts for SVLA) . . .
a battery across an operating bus
will support small outflow currents
at voltages higher than 12.5.
What is your normal bus voltage and do
you notice any depression of voltage
that corresponds to battery outflow
events?
