Brake hose
JonathanMilbank
PostPosted: Wed Oct 23, 2019 12:07 pm    Post subject: Brake hose Reply with quote
My good friend and fellow Europa tri-gear owner has recently noticed a slight hydraulic leak in a brake hose where it bends inside the baggage bay. He asked Karen at the Scottow Enterprise Park and she kindly sent him two samples; one black and one clear. But they both seem slightly too small in diameter, compared with what the late Neville Eyre supplied with the Matco brakes.
The hoses which Neville fitted seem to be 1/4" = 6.3 mm.
The question to you guys is "Where should we look to find the right thickness of brake hose? A go-kart spares shop?" My hoses are older than my friend's and I would likely soon need this info as well. Thanks.
SPURPURA
PostPosted: Wed Oct 23, 2019 12:33 pm    Post subject: Re: Brake hose Reply with quote
If Matco fittings are used, Aircraft Spruce has their brake systems.
N951EU - Tri-gear & 912ULS, N77EU- Tri-gear & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY.
