Europa Trailer specifications
John Kirkgaard
PostPosted: Tue Aug 06, 2019 8:05 am    Post subject: Europa Trailer specifications Reply with quote
I have purchased a Europa XS where an original Europa trailer is included.
To get permission to use it in Denmark I have asked Europa Aircraft for the specifications (empty weight - design load etc), but all I got from Europa after asking 3 times was this:
John,
Unfortunately we have no records of these early trailers any more.
Also we would have no record if it has been modified or not so we cannot be of help with this.
David Stanbridge.
Well hard to understand that Europa don't know to which specifications they have designed their 5000 GBP trailer.
I would be very grateful if one of you could help me getting the specs.
regards John Kirkegaard
tennant
PostPosted: Thu Aug 08, 2019 6:49 am    Post subject: Re: Europa Trailer specifications Reply with quote
Hi John,
Is it a Mono trailer?
If so, I have the German registration and test documents somewhere in my files that I could pull out for you.
I had more problems getting the trailer tested & registered than the plane!!
Barry Tennant
Barry Tennant
D-EHBT
At EDLM - Germany
italianjon
PostPosted: Thu Aug 08, 2019 11:08 pm    Post subject: Re: Europa Trailer specifications Reply with quote
Absolutely second what Barry said.
Barry's information helped me a to getting mine registered.
If it does help the TÜV in Germany used Barry's info as a start and did a full survey on the trailer. I think I have a copy of the TÜV report that I can send through next week once I'm back home, if you need it in addition.
