Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Tue Jun 18, 2019 5:17 pm Post subject: Factory Certified but is this safe? |
Hi all,
I am rebuilding and restoring a 1977 factory certified S1-S Pitts. The electrical system is pretty basic but there is one aspect that I am trying to understand. The battery is located behind the pilot's seat. There is a contactor directly adjacent that energizes the starter. There is a large wire, #8 or so, that goes from the battery that goes down the frame to the console between the pilot's legs where the circuit breakers and switches reside. That wire goes into an ammeter and from there to the main bus, on which the various circuit breakers reside. There is no fuse, contactor or other circuit interruption device between the battery and the console. If that main feed wire were to erode through or otherwise short, there would be nothing to stop the welding action until the battery died.
I wired my RV8 per the excellent instructions in the Aeroelectric Connection. I feel quite safe about it. There is a very short run between the batter and the main contactor but all other wires are protected. Not so with the factory Pitts wiring. Should I be adding a fuse or contactor or something near the battery to protect this circuit?
Michael Wynn
RV8
Pitts S1-S
Livermore, CA
_________________ Michael Wynn
RV 8
San Ramon, CA |
user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Tue Jun 18, 2019 6:04 pm Post subject: Re: Factory Certified but is this safe? |
A pilot should have the ability to shut off electrical power near each source. A 40 amp automotive relay will work for this situation. I would NOT install a fuse or circuit breaker at the battery.
_________________ Joe Gores |
Posted: Thu Jun 20, 2019 4:55 pm Post subject: Factory Certified but is this safe? |
At 08:16 PM 6/18/2019, you wrote:
I wired my RV8 per the excellent instructions in the Aeroelectric Connection. I feel quite safe about it. There is a very short run between the batter and the main contactor but all other wires are protected. Not so with the factory Pitts wiring. Should I be adding a fuse or contactor or something near the battery to protect this circuit? |
Do you have a schematic of the system?
How big is the alternator/generator?
I am surprised that a type certificated
airplane would be configured as you've
described because it does not comply
with Part 23 rules for crew management
of power sources.
You could add a battery contactor for
just that feeder . . .but if you're
going to add ANY contactor, why
not wire per 99.9% of other TC
aircraft?
Add a legacy battery contactor
upstream of the starter contactor
then move the 8AWG feeder to
the junction between those
contactors. Of course, you'll
need to add a battery master
to the panel.
What's your situation with respect
to 'mods'? Do you need to execute
a Form 337 Field Approval?
Michael Wynn
Posted: Sun Jun 23, 2019 6:16 am Post subject: Factory Certified but is this safe? |
In looking at the original published plans, the starter contactor next to the battery and no master is what is published. I am working with my A&P to sort out the legalities of the situation but my decision is to rewire using the Z11 basic form. I changed out the alternator for the TSO'd version of the B&C 40 amp alternator and LRC-3 regulator. In my view, safety trumps legality. I cannot explain how the type certificate was approved this way but the original design was from the 1940's and I'm not sure when the type certificate was given. It certainly wouldn't pass at present.
I have a call in to Aviat to see if there is a service bulletin or something that allows me to legally make the changes. Beyond that, safety first is the byline. If I need the 337, then we will get that done. I cannot believe I am the first Pitts owner to encounter this situation. Thanks for the feedback.
Michael Wynn
RV8
Pitts S1-S
Livermore, CA
RV 8
San Ramon, CA |
Posted: Sun Jun 23, 2019 6:01 pm Post subject: Factory Certified but is this safe? |
At 09:15 AM 6/23/2019, you wrote:
Quote: | In looking at the original published plans, the starter contactor next to the battery and no master is what is published. I am working with my A&P to sort out the legalities of the situation but my decision is to rewire using the Z11 basic form. I changed out the alternator for the TSO'd version of the B&C 40 amp alternator and LRC-3 regulator. In my view, safety trumps legality. I cannot explain how the type certificate was approved this way but the original design was from the 1940's and I'm not sure when the type certificate was given. It certainly wouldn't pass at present. |
Yeah . . . that would have been a CAR3
rules. I'll have to see if I still have
a copy of the light-plane rules in
my archives. I would be interesting
to see what was required back then.
Quote: | I have a call in to Aviat to see if there is a service bulletin or something that allows me to legally make the changes. Beyond that, safety first is the byline. If I need the 337, then we will get that done. I cannot believe I am the first Pitts owner to encounter this situation. Thanks for the feedback.
Is there a type-club that might
have exemplar 337 submissions
that were successful upgrades?
Barring that, consider a
337 that cites an 'upgrade
to the original system with:
(1) architecture patterned after 1968 C172
(2) fully compliant with FAR23 paragraphs
23.1351 thru 23.1367
(3) installed per practices described
in AC43-13 and all applicable
manufacturer's recommendations.
Then attach a drawing of the system (should
be pretty simple). Break it up in page
per system format like that found in the
back of the various Cessna service manuals
available from my website.
I know a DAR type that could help
you craft the document.
Michael Wynn
Posted: Tue Jun 25, 2019 8:49 am Post subject: Factory Certified but is this safe? |
Very good. Thank you for the input. I will keep everyone posted on this.
Michael Wynn,
RV8
Pitts S1-S
Livermore, CA
RV 8
San Ramon, CA |
