MJKTuck(at)cs.com Guest
Posted: Mon May 13, 2019 6:31 pm Post subject: Engine Start Problem |
Hi Europaphiles,
So it's been a few weeks but I have finished up my panel upgrade to a
Dynon EFIS and it all works great - well it comes on at least and my
avionics shop passed the transponder operation.
I went to do my first flight with it this evening and just could not get
the darn engine (Rotax 912UL) to start. Just lots of cranking from the
freshly charged battery.
Obviously I had removed and replaced the panel but everything seems to
work OK, fuel pump, starter, etc. so I don't think there is anything
wrong there - although I would like to make sure the mags are on. The
best way I can think of is to test for a spark. Any recommendations out
there for testing to see if you have a spark? I believe the removal of a
spark plug is not recommended on a Rotax. I felt the hint of a kick once
or twice so I suspect they are good.
My suspicions lie with the carbs - in particular the choke. It is really
stiff and the geometry is such that it never quite fully opens. I
removed the air box and stuck my nose next to the air intakes.
Considering the amount of cranking and choking I had done you would
think I would be able to smell fuel - but couldn't smell anything.
Anyone used some kind of 'quick start fluid' like the kind I use on my
stubborn lawnmower or is that a bit too extreme?
Anything 'more obvious' I can try?
Martin Tuck
Roland
Posted: Tue May 14, 2019 6:01 am Post subject: Re: Engine Start Problem |
Hi Martin,
here comes my story:
Damn thing wouldn't start, not even with lots of swearing. Removed one spark plug and I could smell fuel. Warmed the ignition boxes with a hairdryer for 3 minutes and the engine would start right away.
I had this problem two times. So if ignition is the problem, there you have (most likely) the culprit.
BTW: ignition boxes for my Rotax (914) are 880 EUR each.
Good luck!
Roland
PH-ZTI
XS TG 914
pete(at)lawless.info Guest
Posted: Tue May 14, 2019 8:52 am Post subject: Engine Start Problem |
Hi
This company in the Netherlands was discussed on the forum a while
back. Rebuilding ignition units is one of their services.
https://www.carmo.nl/index.php?main_page=about_us&zenid=2ehjm35bincu889agim2s56jt0
Pete
G-RMAC Classic #109
On 14/05/2019 15:01, Roland wrote:
Hi Martin,
Good luck!
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=489219#489219
Posted: Tue May 14, 2019 9:55 am Post subject: Engine Start Problem |
Thanks Roland,
It seems to be a choke thing as I sprayed some Quick Start fluid into the air box and it started right up. Oddly enough though, the Alt warning lamp is on all the time. The only thing I have done electrically was to add a diode on to the main solenoid to protect the avionics from spikes when shutting down. I’ve never seen it lit in all the years I have had it.
Martin Tuck
| Quote: | On May 14, 2019, at 9:01 AM, Roland <schmidtroland(at)web.de> wrote:
Hi Martin,
Good luck!
Roland
PH-ZTI
XS TG 914
