JonathanMilbank
Joined: 14 Apr 2012 Posts: 385 Location: Aberdeen area
Posted: Fri Mar 01, 2019 12:24 pm Post subject: Rotax 912ULS/S suggested "health" warning |
To avoid psychological distress and the unnecessary expensive inconvenience of having to remove your Rotax 912ULS/S engine in order to change the starter sprag clutch prematurely, replace your aircraft's battery at intervals no greater than 2 years. Ensure that the battery is fully charged before any start attempt. This advice is particularly pertinent to engines fitted with the heavier propeller hubs, such as the excellent Airmaster.
Please see: http://forums.matronics.com/viewtopic.php?t=16772462
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Roger Lee
Posted: Sat Mar 09, 2019 6:51 am Post subject: Re: Rotax 912ULS/S suggested "health" warning |
Tens of thousands of Rotax owners go 3-5 years on a battery without any issues and it has nothing to do with the sprag clutch. Flying often and having a good battery maint. program or float charger keeps battery life to its fullest. If all you get is 1-2 years on a battery you're doing something wrong. The sprag clutch is affected because of continuous hard long starts and prop kickback. You should have neither and with the proper setup the engine should start on the first 1-2 prop rotations and NEVER have kickback. Having a good mechanic and understanding of the Rotax mitigates these issues.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
