december29(at)bellsouth.n Guest
Posted: Tue Jul 18, 2006 10:40 am Post subject: Landing Gear Bolts |
Hi there,
Going through and finishing up stuff on my -8. Since I borrow a torque
wrench, tightening the gear bolts had to wait. Now the problem! I have the
wiring in my gear towers as well as the fuel vent line directly over the aft
bolt (NAS 6206-27/ NAS679A6 nut). Yeah, excellent planning- I know. Any
ideas on getting those aft nuts- anything at all, strange combinations that
involve forging my own tools.........I'm stuck.
#80002
PS If the answer involves MOGAS, AOA, or "my things bigger than yours", I'm
not listening. Ha, ha
Larry Bowen
Posted: Tue Jul 18, 2006 6:20 pm Post subject: Landing Gear Bolts |
If I can't get a wrench/socket on the nut, I've wedged a chisel or wrench or
whatever in-between a flat on the nut and the weldment to prevent the nut
from turning. Then the bolt is torqued from below. Not ideal, but...
Larry Bowen. RV-8, 201 Hrs.
Larry(at)BowenAero.com
http://BowenAero.com
[quote] --
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Tue Jul 18, 2006 6:52 pm Post subject: Landing Gear Bolts |
Larry,
You know that will work! Didn't even think about it. I will let you know
how it worked.
rv8striker(at)hotmail.com Guest
Posted: Wed Jul 19, 2006 6:00 am Post subject: Landing Gear Bolts |
I had the same problem on my 8. I ended up grinding off one side of a cheap
socket so it will fit over the forward nuts in the tower. For the aft nuts I
fabricated a spacer form .250 stock that will just fit between the weldment
and the flat of the nut keeping it from turning. Then It's torqued form
below. I tried various screwdrivers and tools to jam the nut against the
weldment but the gap was too big for any tools I tried, and not big enough
for a socket to fit. I know, not ideal to torque from the bottom, but the
only option I had. The "trick" with the spacer is getting it into position
(and out) by brail. My two cents worth.
Steve Struyk
RV-8 50 hrs.
rv8ch
Posted: Wed Jul 19, 2006 10:23 am Post subject: Landing Gear Bolts |
I'm not sure where I got the idea, probably here.
You can buy metal locking nuts at ACS that go on
the RV8 gear legs and have much smaller heads,
which allow you to easily get a socket on.
I thought I had some pics on my website, but I
can't find them.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
low pass
Posted: Wed Jul 19, 2006 6:23 pm Post subject: Re: Landing Gear Bolts |
Don't forget to retorque after about 50 hours flying time.
