hivanhaecker(at)gmail.com Guest
Posted: Wed Jan 16, 2019 11:07 am Post subject: Battery |
After 35 years of hand propping my C-85 engine, I have decided to install a B & C starter. My plan is to use a light weight lithium battery for starting only. I have no electrical system whatsoever. There will be no alternator to recharge the battery. I would like to choose a battery that will allow me a few starts (perhaps 6?) before needing to be be recharged on the ground. Any suggestions on what size / capacity battery I should be looking for?
Ivan Haecker
n233ee(at)gmail.com Guest
Posted: Wed Jan 16, 2019 11:29 am Post subject: Battery |
Hi Ivan, recommend that you forward this email to Bill at B&C. He will know & he is one of the good guys!
| Quote: | On Jan 16, 2019, at 1:06 PM, Ivan <hivanhaecker(at)gmail.com> wrote:
Ivan Haecker
Posted: Wed Jan 16, 2019 9:40 pm Post subject: Battery |
Thanks Earl. I’ll do that.
On Wed, Jan 16, 2019 at 1:33 PM Earl Schroeder <n233ee(at)gmail.com (n233ee(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Earl Schroeder <n233ee(at)gmail.com (n233ee(at)gmail.com)>
> On Jan 16, 2019, at 1:06 PM, Ivan <hivanhaecker(at)gmail.com (hivanhaecker(at)gmail.com)> wrote:
> --> AeroElectric-List message posted by: Ivan <hivanhaecker(at)gmail.com (hivanhaecker(at)gmail.com)>
> Ivan Haecker
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
echristley(at)att.net Guest
Posted: Thu Jan 17, 2019 6:53 am Post subject: Battery |
Not directly to your question, but to save yourself the hassle of hooking up a charger, you might consider adding a solar panel to your plane. For less than $20, you can get a 6"x12" panel that will deliver 100mA or so. If you're only starting a couple times a week, you'd probably never need to hunt down a charger.
On Wednesday, January 16, 2019, 2:08:15 PM EST, Ivan <hivanhaecker(at)gmail.com> wrote:
<; - The AeroElectric-List Email Forum -
http://forums.matronics.com
</= Add some info to the Matronics Email List Wiki!
John M Tipton
Joined: 07 Aug 2018 Posts: 45 Location: Devon - England
Posted: Thu Jan 17, 2019 11:09 am Post subject: Battery |
How do you regulate the charge with these things, can you over charge a battery
John
Sent from my iPad
----x--O--x----
On 17 Jan 2019, at 2:51 pm, Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
On Wednesday, January 16, 2019, 2:08:15 PM EST, Ivan <hivanhaecker(at)gmail.com (hivanhaecker(at)gmail.com)> wrote:
http://www.matronics.com/Navigator?AeroElectric-List[/url]
Posted: Thu Jan 17, 2019 11:18 am Post subject: Battery |
I like that idea. Of course, the sun never shines in my hangar, but it usually does when I’m flying!
I wrote an e-mail to B&C, but they only said that in general, they recommend Earth X batteries. What I really need to know is what size (capacity) battery I need, i.e., how many cca’s, etc. that I need to accomplish my intended goals. I guess I need to do a little research.
On Thu, Jan 17, 2019 at 8:57 AM Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
email(at)jaredyates.com Guest
Posted: Thu Jan 17, 2019 12:18 pm Post subject: Battery |
Ivan, you might also reach out to Earthx to see what they would recommend. Last I checked Bruce was running a total loss Earthx in his LSA and it was lasting a long time. Let me know if you want help getting in touch with him.
On January 17, 2019 14:23:18 "H. Ivan Haecker" <hivanhaecker(at)gmail.com> wrote: | Quote: | I like that idea. Of course, the sun never shines in my hangar, but it usually does when I’m flying!
Posted: Thu Jan 17, 2019 4:58 pm Post subject: Battery |
They would only output about 14V Max. They don't have enough power to damage anything as I understood it, but that was with a lead acid battery. If you talking to the battery guys, ask them and let us know what they have to say about it.
Sent from Yahoo Mail on Android
| Quote: | On Thu, Jan 17, 2019 at 2:10 PM, John Tipton
John
Sent from my iPad
----x--O--x----
yellowduckduo(at)gmail.co Guest
Posted: Thu Jan 17, 2019 7:39 pm Post subject: Battery |
Might not be needed with a small panel but Ebay has solar charging
modules specifically for charging 12 volt batteries. Bought one last
year for 3 or 4 dollars. Optimizes solar cell output and won't overcharge.
Ken
On 17/01/2019 6:30 PM, Ernest Christley wrote:
| Quote: | They would only output about 14V Max. They don't have enough power to
<https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature>
charge a battery
John
Sent from my iPad
----x--O--x----
> http://www.matronics.com/contribution
Posted: Fri Jan 18, 2019 9:20 am Post subject: Battery |
At 05:30 PM 1/17/2019, you wrote:
| Quote: | | They would only output about 14V Max. They don't have enough power to damage anything as I understood it, but that was with a lead acid battery. If you talking to the battery guys, ask them and let us know what they have to say about it. |
Solar battery chargers are at best, unpredictable
'trickle' chargers. Their output almost never meets
nameplate numbers. Output is subject to vagaries
of the sunshine. Output is not controlled to prevent
overcharging of the battery.
My recommendation for a battery-only electrical
system, particularly if the battery is a light
weight and relatively expensive lithium device
is to take it home between flights and put it
on a charger-maintainer recommended by the
battery's manufacturer.
I had readers doing this with SVLA batteries
25 years ago who reported excellent performance
and longevity from the battery. This was common
to both sail plane owners and owners of powered
ships with electrical needs but no engine
driven power sources.
ceengland7(at)gmail.com Guest
Posted: Fri Jan 18, 2019 12:54 pm Post subject: Battery |
On Fri, Jan 18, 2019 at 11:26 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| As a data point, a friend who sells rides in a 1929 TravelAir biplane did it for years with a battery-only starting system. He did finally have a generating system installed for convenience, but the fact that he ran a commercial operation with a 'total loss' system shows it can work well. I wish I could tell you the size of the battery he used, but I can't remember and he never knew (good pilot, but mechanic, not so much...).
Charlie
Posted: Sat Jan 19, 2019 8:18 am Post subject: Battery |
I contacted EarhX, and given the parameters of my engine and the fact that there will be no onboard charging, they recommend,at minimum, an EarthX 24C which is 7.8Ah with 270 CCA. Of course, the larger the battery, the more engine starts available before recharge. I meant to ask them about a solar cell for charging, but forgot to do that. I’ll call again next week and post their response.
Ivan
On Fri, Jan 18, 2019 at 2:59 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
Posted: Sat Jan 19, 2019 8:31 am Post subject: Battery |
No doubt all true for unregulated solar arrays. However there are
chargers similar to this $3.25 module that I have found to be more
accurate and consistent than the AC powered Schumacher chargers for lead
acid VRLA batteries. These are not unregulated trickle chargers but
rather multi mode optimized chargers that adhere to best practical
charging protocols. The Max Power Point Tracking (MPPT) input lets the
input voltage and power stay optimum for power transfer. All for a
couple of dollars delivered.
ebay item 183558004137
It looks like this particular one works with a solar input of 6 to 18
volts. There are definitely some cheap viable options available for the
Do-It-Yourselfer. Even more are available for Lithium batteries.
Ken
Eric Page
Posted: Sat Jan 19, 2019 5:47 pm Post subject: Re: Battery |
| yellowduckduo(at)gmail.co wrote: | chargers similar to this $3.25 module that I have found to be more accurate and consistent than the AC powered Schumacher chargers for lead acid VRLA batteries. These are not unregulated trickle chargers but rather multi mode optimized chargers that adhere to best practical charging protocols. The Max Power Point Tracking (MPPT) input lets the input voltage and power stay optimum for power transfer. All for a couple of dollars delivered.
It looks like this particular one works with a solar input of 6 to 18 volts. There are definitely some cheap viable options available for the Do-It-Yourselfer. Even more are available for Lithium batteries. |
A little digging reveals some concerns about this charger. The IC used on the module is the Consonance CN3767 (datasheet here). While it *is* a true MPPT charger (a rarity on eBay at this price point), it's probably not going to function as you would like, for a couple of reasons.
First, the seller's claim that the module can accept solar panel inputs between 6 and 18V, while true, is misleading. The CN3767 uses a buck topology, not buck-boost. This means that it can only *reduce* the input voltage. Any time the solar panel's output falls below the battery voltage minus a diode drop, the battery will not be charged at all. So to charge a battery that's sitting at 12V, the minimum solar panel output will be >12.7V (perhaps a bit less with a Schottky diode).
Second, the photos of the module show that the maximum power point voltage (Vmpp) is set lower than it should be for a low-power (<50W) solar panel. R1 is marked "25D" (178kΩ) and R2 is marked 13C (13.3kΩ). These values produce a Vmpp of just over 16V (see pages 6-7 of the datasheet):
1.205 x ((1 + 178,000) / 13300) = 16.13V
Virtually all solar panels in the 10-50W range have a Vmpp of 17-18V (at 4A max output, this module can handle up to a 50W panel). In solar charging, where system efficiency of 25% or less is common, a few tenths of a volt in Vmpp tracking can make a significant difference.
Another case of eBay buyer beware!
Eric
Posted: Sun Jan 20, 2019 9:05 am Post subject: Battery |
| Quote: | >All for a couple of dollars delivered.
A little digging reveals some concerns about this charger. The IC used on the module is the Consonance CN3767 (datasheet here ([url=http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)).%A0] http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)). [/url] While it *is* a true MPPT charger (a rarity on eBay at this price point), it's probably not going to function as you would like, for a couple of reasons.
First, the seller's claim that the module can accept solar panel inputs between 6 and 18V, while true, is misleading. The CN3767 uses a buck topology, not buck-boost. This means that it can only *reduce* the input voltage. Any time the solar panel's output falls below the battery voltage minus a diode drop, the battery will not be charged at all. So to charge a battery that's sitting at 12V, the minimum solar panel output will be >12.7V.
Second, the photos of the module show that the maximum power point voltage (Vmpp) is set lower than it should be for a low-power |
Good put Eric. I would like to qualify my
earlier assertions about 'solar chargers'
in that my comments targeted the generic
solar arrays some with built in isolation
diodes and NO active electronics. I've got
a couple of panels laying around here that
I was considering for use on farm equipment
that sits idle for long periods of time . . .
generally allowing battery(ies) to self-destruct.
Usually very EXPENSIVE batteries I might add.
Popular devices like this
https://tinyurl.com/y7x2wbfu
which is better than nothing but too small
to be a serious charger . . . and if it were
larger like this one
https://tinyurl.com/y9zy4zjs
perhaps too big to be allowed un-controlled
access to the battery in maintenance.
I have one of those '18w' devices . . . and
it's really closer to a 10 watt. Yeah, it
will put 1+ amps into an SVLA battery in
full, direct sunlight . . . but output falls
of markedly with changes in sun angle and
clouds.
To be sure, solar arrays CAN be adapted to
charging and maintaining batteries but
they require the addition of electronic
'smarts' to competently craft a set-it-and-
forget-it maintenance system.
The eBay item cited is interesting. I've
ordered a couple. I'll team one up with
a pair of my not-quite-18w panels and
put a data acquisition system on it.
MEASUREMENT will tell the story. Thanks
for the heads-up!
Posted: Mon Jan 21, 2019 5:46 pm Post subject: Battery |
I learned today from EarthX that they are ok with using a small solar charger to charge their batteries, as long as it will NEVER exceed 14.6 volts. Their emphasis, not mine.They also stated that many solar units commonly are 15 volts or more and therefore not to be used with their batteries.
Ivan Haecker
On Sun, Jan 20, 2019 at 11:10 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | | Quote: | >All for a couple of dollars delivered.
clouds.
for the heads-up!
Posted: Tue Jan 22, 2019 6:06 pm Post subject: Battery |
At 07:44 PM 1/21/2019, you wrote:
| Quote: | | I learned today from EarthX that they are ok with using a small solar charger to charge their batteries, as long as it will NEVER exceed 14.6 volts. Their emphasis, not mine.They also stated that many solar units commonly are 15 volts or more and therefore not to be used with their batteries. |
Virtually ALL solar arrays offered to charge
12v batteries will have a full-sun, open-circuit
voltage in excess of 16 volts.
The 'small' arrays also have a rather large
internal impedance . . . meaning that the
output voltage falls off as load is increased.
But as any battery being charged with a 'barefoot'
solar array achieves full charge, flow of current
into the battery is not moderated.
The short story is that any solar array
being considered needs to have a significant
current capability . . . the wall-wart maintainers
are good for about 0.8A and WILL eventually
top off a rather large battery.
But to deliver 0.8A under marginal sun-light
conditions, the full-sun capability needs to
be 2x to 3x that amount . . . say 2.5A at
14 volts or about 35 watts.
Those cute little solar panels with cigar
lighter plugs are good for about 1-2 watts
and will MAINTAIN a fully charged battery.
But it takes a more robust device to serve
as replacement for the ship's engine driven
power source . . . i.e. top off a partially
discharged battery while hangared.
The more robust arrays need some form of
electronics to keep their full-sun performance
from beating up an already full-charge battery.
sha664817
Posted: Sun Jan 27, 2019 10:54 pm Post subject: Re: Battery |
chargers like this $3.25 module that I have observed to be more
precise and reliable than the air conditioner fueled Schumacher chargers for lead
corrosive VRLA batteries.� These are not unregulated stream chargers but rather
Or maybe multi-mode enhanced chargers that hold fast to best functional
charging conventions. The Maximum Power Point Following (MPPT) input lets the
input voltage and power remain ideal for power transfer.� Just for a
couple of dollars conveyed.
eBay thing 183558004137
It would appear that this specific one works with a sun-based contribution of 6 to 18
volts. There are unquestionably some shabby reasonable choices accessible for the
Do-It-Yourselfer.� Much more are accessible for Lithium batteries.
_________________ Electrical engineering is a professional engineering deals with the study and application of electricity, electronics, and electromagnetism. |
Posted: Mon Jan 28, 2019 12:03 pm Post subject: Battery |
Do-It-Yourselfer.� Much more are accessible for Lithium batteries. |
These do look intereseting . . . I've got
some on order.
Posted: Mon Jan 28, 2019 1:32 pm Post subject: Battery |
Consider the following in conjunction with the charge controller. I'm limited to day-VFR, and my bladder keeps my flying legs down to 2 hours. My running current draw is somewhere down around 10 amps. With a couple of these plastered to the top of my wings, and a battery appropriately sized for a couple hours of runtime, would I EVER run out of electrons before fuel? At around $110, these would definitely be cheaper than a mechanical electron pusher. Without relays and crowbars, et. al., I would expect the wiring to be MUCH simpler. The weight is quoted as "less than 5 lbs", so lighter than all but the smallest of generators (?).
This would be a major departure from years of lessons learned in the aircraft community, but. . .
WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar Cells | eBay
<![endif]--><![endif]-->$114.99
<![endif]--> WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar...
WindyNation 1 00Watt (12 volt) Flexible Monocyrstalline Solar Panel with Monocrystalline Solar Cells. WindyNatio...
On Monday, January 28, 2019, 3:05:17 PM EST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
some on order.
