cluros(at)gmail.com Guest
Posted: Sat Nov 24, 2018 7:19 pm Post subject: Ford Voltage Regulator |
Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S terminal of the regulator should go to the Sta terminal on the alternator instead of being tied into the alternator switch going to the A terminal? Can anyone please confirm if this makes sense or not?
millner(at)me.com Guest
Posted: Sat Nov 24, 2018 7:44 pm Post subject: Ford Voltage Regulator |
Nope, don’t do that. The Ford regulator doesn’t use the stator terminal. PlanePower’s regulator does.
Paul
| Quote: | On Nov 24, 2018, at 7:18 PM, Sebastien <cluros(at)gmail.com> wrote:
Posted: Sun Nov 25, 2018 8:42 am Post subject: Ford Voltage Regulator |
At 09:18 PM 11/24/2018, you wrote:
| Quote: | | Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S terminal of the regulator should go to the Sta terminal on the alternator instead of being tied into the alternator switch going to the A terminal? Can anyone please confirm if this makes sense or not? |
The "s" terminal did go to the stator
winding in cars . . . but is best
paralleled with "a" in airplanes.
Ignore the aux, n or s terminals on
the alternator.
http://www.aeroelectric.com/Reference_Docs/Alternator_Data/Legacy_EM_Regulator_(Ford).pdf
This is because the solid state replacement
for the Ford E-M regulator is NOT a
strictly functional replacement. The "S"
terminal does not behave in the same
manner as it did on the E-M products.
Posted: Sun Nov 25, 2018 8:55 am Post subject: Ford Voltage Regulator |
So for any VR166 regulator and Ford type alternator combination wire as per Z-11.
Thank you Bob.
On Sun, Nov 25, 2018, 08:46 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com) wrote:
the alternator.
